[PATCH] pwdgrp.c: Removed unused variable
Gedare Bloom
gedare at rtems.org
Thu Apr 29 00:22:20 UTC 2021
ok
On Wed, Apr 28, 2021 at 2:25 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> The 'sc' variable was originally storing the return value of mkdir().
> This was causing an issue, so it was changed to make it to where we
> ignored the return value with (void). The 'sc' variable was left in
> by mistake.
> cpukit/libcsupport/src/pwdgrp.c | 2 --
> 1 file changed, 2 deletions(-)
> diff --git a/cpukit/libcsupport/src/pwdgrp.c b/cpukit/libcsupport/src/pwdgrp.c
> index aac31f4..d686829 100644
> --- a/cpukit/libcsupport/src/pwdgrp.c
> +++ b/cpukit/libcsupport/src/pwdgrp.c
> @@ -63,8 +63,6 @@ static void init_file(const char *name, const char *content)
> static void pwdgrp_init(void)
> - int sc;
> * Do the best to create this directory.
> 1.8.3.1
> devel mailing list
> devel at rtems.org
