[PATCH rtems] cpukit/Makefile.am: Remove remaining LIBNETWORKING files
Vijay Kumar Banerjee
vijay at rtems.org
Thu Apr 29 16:07:17 UTC 2021
cpukit/Makefile.am | 43 -------------------------------------------
cpukit/configure.ac | 1 -
2 files changed, 44 deletions(-)
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index b0df610bed..44ab945778 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1372,15 +1372,6 @@ librtemscpu_a_SOURCES += libmisc/shell/main_pci.c
endif
-if LIBNETWORKING
-librtemscpu_a_SOURCES += libmisc/shell/main_ifconfig.c
-librtemscpu_a_SOURCES += libmisc/shell/main_route.c
-librtemscpu_a_SOURCES += libmisc/shell/main_netstats.c
-librtemscpu_a_SOURCES += libmisc/shell/main_ping.c
-endif
endif
if LIBUTF8PROC
@@ -1813,40 +1804,6 @@ libz_a_SOURCES += zlib/trees.c
libz_a_SOURCES += zlib/uncompr.c
libz_a_SOURCES += zlib/zutil.c
-if LIBNETWORKING
-project_lib_LIBRARIES += libnfs.a
-libnfs_a_SOURCES =
-libnfs_a_SOURCES += libfs/src/nfsclient/proto/mount_prot_xdr.c
-libnfs_a_SOURCES += libfs/src/nfsclient/proto/nfs_prot_xdr.c
-libnfs_a_SOURCES += libfs/src/nfsclient/src/nfs.c
-libnfs_a_SOURCES += libfs/src/nfsclient/src/rpcio.c
-libnfs_a_SOURCES += libfs/src/nfsclient/src/sock_mbuf.c
-libnfs_a_SOURCES += libfs/src/nfsclient/src/xdr_mbuf.c
-project_lib_LIBRARIES += libpppd.a
-libpppd_a_SOURCES =
-libpppd_a_SOURCES += pppd/auth.c
-libpppd_a_SOURCES += pppd/ccp.c
-libpppd_a_SOURCES += pppd/chap.c
-libpppd_a_SOURCES += pppd/chap_ms.c
-libpppd_a_SOURCES += pppd/chat.c
-libpppd_a_SOURCES += pppd/demand.c
-libpppd_a_SOURCES += pppd/fsm.c
-libpppd_a_SOURCES += pppd/ipcp.c
-libpppd_a_SOURCES += pppd/lcp.c
-libpppd_a_SOURCES += pppd/magic.c
-libpppd_a_SOURCES += pppd/options.c
-libpppd_a_SOURCES += pppd/rtemsmain.c
-libpppd_a_SOURCES += pppd/rtemspppd.c
-libpppd_a_SOURCES += pppd/sys-rtems.c
-libpppd_a_SOURCES += pppd/upap.c
-libpppd_a_SOURCES += pppd/utils.c
-endif
if HACK_TO_AVOID_LONG_ARG_LIST
librtemscpu.a: $(librtemscpu_a_OBJECTS) $(librtemscpu_a_DEPENDENCIES) $(EXTRA_librtemscpu_a_DEPENDENCIES)
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 9c25c3770d..e3c039383c 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -293,7 +293,6 @@ AM_CONDITIONAL(HAS_MP,test x"$enable_multiprocessing" = x"yes" )
AM_CONDITIONAL(HAS_SMP,[test "$RTEMS_HAS_SMP" = "yes"])
AM_CONDITIONAL(HAS_PTHREADS,test x"$rtems_cv_HAS_POSIX_API" = x"yes")
-AM_CONDITIONAL(LIBNETWORKING,test x"$rtems_cv_HAS_NETWORKING" = x"yes")
AM_CONDITIONAL([LIBSHELL],[test x"$HAVE_ASSIGNABLE_STDIO" = x"yes"])
AM_CONDITIONAL([LIBSERDBG],[test x"$rtems_cv_cc_attribute_weak" = x"yes"])
2.26.2
