RTEMS source builder: can't find RTEMS include files but then can?
dufault at hda.com dufault at hda.com
Fri Apr 30 09:03:29 UTC 2021
I lied.  I had /usr/local/bin in my path to pick up "cmake3" instead of the system "cmake".  I thought I repeated the test with PATH set to just /usr/bin and /usr/sbin, but I hadn't.
Can I override what to use as "cmake" in RSB to specify "cmake3"?
> On Apr 30, 2021, at 04:41 , Peter Dufault <dufault at hda.com> wrote:
> I verified my environment is squeaky-clean with a simple path and no environment variables set that affect RTEMS or "make".
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210430/9a523428/attachment.bin>
