[PATCH] riscv/console: console-config.c update
Somesh Deshmukh
someshdeshmukh07 at gmail.com
Fri Apr 30 09:35:48 UTC 2021
- Parsing the sub-node should be available generic not specific to Freedom
Arty310 board. If we remove the Freedom Arty macro now, it will lose
backward compatibility.The proposed change will retain the backward
compatibility and also adds the necessary fix for parsing sub-node.
- Restored ns16550_handler_interrupt in console_initialize() as per
review comments.
bsps/riscv/riscv/console/console-config.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
index d962a5a418..797506a31b 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -91,7 +91,7 @@ static int riscv_get_console_node(const void *fdt)
stdout_path = "";
-#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
+#if ((RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0) || (RISCV_CONSOLE_MAX_NS16550_DEVICES > 0))
int root;
int soc;
root = fdt_path_offset(fdt, "/");
2.25.1
