[PATCH] riscv/start: Startup sequence update.
Sebastian Huber
Fri Apr 30 13:34:45 UTC 2021
On 30/04/2021 15:32, Hesham Almatary wrote:
> The noinit attributes is a bit broken in GCC:
> I guess we can go for a separate custom section then? Or we can just
> assign it a magic value so that it doesn’t go into BSS.
I propose to add something like this:
+/* Generated from spec:/rtems/basedefs/if/noinit */
+ * @ingroup RTEMSAPIBaseDefs
+ * @brief Instructs the compiler to place the variable in a section
which is
+ * not initialized.
+#define RTEMS_NOINIT RTEMS_SECTION( ".noinit" )
I work currently on a support for this in the linker command files.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
