[PATCH] score: Add _Thread_Dispatch_direct_no_return()
Sebastian Huber
Fri Apr 30 15:02:29 UTC 2021
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
cpukit/include/rtems/score/threaddispatch.h | 11 +++++++++++
cpukit/posix/src/pthreadexit.c | 2 +-
cpukit/rtems/src/taskexit.c | 2 +-
cpukit/score/src/threaddispatch.c | 3 +++
cpukit/score/src/threadrestart.c | 4 ++--
5 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/cpukit/include/rtems/score/threaddispatch.h b/cpukit/include/rtems/score/threaddispatch.h
index 707b449771..7f3673a0d5 100644
--- a/cpukit/include/rtems/score/threaddispatch.h
+++ b/cpukit/include/rtems/score/threaddispatch.h
@@ -125,6 +125,17 @@ void _Thread_Dispatch( void );
void _Thread_Dispatch_direct( Per_CPU_Control *cpu_self );
+ * @brief Directly do a thread dispatch and do not return.
+ * @param cpu_self is the current processor.
+ * @see _Thread_Dispatch_direct().
+RTEMS_NO_RETURN void _Thread_Dispatch_direct_no_return(
+ Per_CPU_Control *cpu_self
* @brief Performs a thread dispatch on the current processor.
diff --git a/cpukit/posix/src/pthreadexit.c b/cpukit/posix/src/pthreadexit.c
index 502476d141..657497010b 100644
--- a/cpukit/posix/src/pthreadexit.c
+++ b/cpukit/posix/src/pthreadexit.c
@@ -35,6 +35,6 @@ void pthread_exit( void *value_ptr )
_Thread_Exit( executing, THREAD_LIFE_TERMINATING, value_ptr );
- _Thread_Dispatch_direct( cpu_self );
+ _Thread_Dispatch_direct_no_return( cpu_self );
RTEMS_UNREACHABLE();
diff --git a/cpukit/rtems/src/taskexit.c b/cpukit/rtems/src/taskexit.c
index c08089e956..4c8420d255 100644
--- a/cpukit/rtems/src/taskexit.c
+++ b/cpukit/rtems/src/taskexit.c
@@ -42,6 +42,6 @@ void rtems_task_exit( void )
NULL
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 2fd125dd76..fd3f4eda4d 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -358,6 +358,9 @@ void _Thread_Dispatch_direct( Per_CPU_Control *cpu_self )
_Thread_Do_dispatch( cpu_self, level );
+RTEMS_ALIAS( _Thread_Dispatch_direct ) void
+_Thread_Dispatch_direct_no_return( Per_CPU_Control * );
void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
uint32_t disable_level = cpu_self->thread_dispatch_disable_level;
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 3c0190164e..364d67d04e 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -288,7 +288,7 @@ void _Thread_Life_action_handler(
if ( _Thread_Is_life_terminating( previous_life_state ) ) {
cpu_self = _Thread_Wait_for_join( executing, cpu_self );
_Thread_Make_zombie( executing );
@@ -610,7 +610,7 @@ void _Thread_Restart_self(
_Thread_Wait_release_default( executing, lock_context );
_Thread_Priority_update( &queue_context );
2.26.2
