[PATCH 1/2] covoar: Store only the file name in ExecutableInfo
Alex White alex.white at oarcorp.com
Fri Apr 30 20:01:34 UTC 2021
This changes the ExecutableInfo class to only store the executable
file's name rather than an entire instance of rld::files::object. This
allows the rld::files::object to be cleaned up in the ExecutableInfo
constructor.
Updates #4383
 tester/covoar/ExecutableInfo.cc | 12 +++++-------
 tester/covoar/ExecutableInfo.h  | 10 +++++-----
 2 files changed, 10 insertions(+), 12 deletions(-)
diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
index fc368ce..861e60d 100644
--- a/tester/covoar/ExecutableInfo.cc
+++ b/tester/covoar/ExecutableInfo.cc
@@ -21,7 +21,7 @@ namespace Coverage {
     const char* const theExecutableName,
     const char* const theLibraryName,
     bool              verbose
-    ) : executable(theExecutableName),
+    ) : fileName(theExecutableName),
         loadAddress(0)
     if (theLibraryName != nullptr)
@@ -34,6 +34,8 @@ namespace Coverage {
       std::cerr << std::endl;
+    rld::files::object executable(theExecutableName);
     executable.open();
     executable.begin();
     executable.load_symbols(symbols);
@@ -82,8 +84,6 @@ namespace Coverage {
     } catch (...) {
       debug.end();
-      executable.end();
-      executable.close();
       throw;
@@ -95,8 +95,6 @@ namespace Coverage {
   ExecutableInfo::~ExecutableInfo()
     debug.end();
-    executable.end();
   void ExecutableInfo::dumpCoverageMaps( void ) {
@@ -132,9 +130,9 @@ namespace Coverage {
     return aCoverageMap;
-  const std::string ExecutableInfo::getFileName ( void ) const
+  const std::string& ExecutableInfo::getFileName ( void ) const
-    return executable.name().full();
+    return fileName;
   const std::string ExecutableInfo::getLibraryName( void ) const
diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
index d5ccb19..5d5a595 100644
--- a/tester/covoar/ExecutableInfo.h
+++ b/tester/covoar/ExecutableInfo.h
@@ -77,7 +77,7 @@ namespace Coverage {
      *  @return Returns the executable's file name
-    const std::string getFileName( void ) const;
+    const std::string& getFileName( void ) const;
      *  This method returns the library name associated with the executable.
@@ -158,14 +158,14 @@ namespace Coverage {
-     *  The ELF executable.
+     *  The DWARF data to the ELF executable.
-    rld::files::object executable;
+    rld::dwarf::file debug;
-     *  The DWARF data to the ELF executable.
+     *  The executable's file name.
-    rld::dwarf::file debug;
+    std::string fileName;
      *  The executable's symbol table.
2.27.0
