[PATCH rtems-libbsd 1/5] libbsd: Quick Start Guide for RTEMS LibBSD
Husni Faiz
ahamedhusni73 at gmail.com
Sun Aug 1 19:25:42 UTC 2021
This guide has instructions to build the RTESM LibBSD
manually for Beagle BSP.
Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
libbsd/quick_start.rst | 51 ++++++++++++++++++++++++++++++++++++++++++
1 file changed, 51 insertions(+)
create mode 100644 libbsd/quick_start.rst
diff --git a/libbsd/quick_start.rst b/libbsd/quick_start.rst
new file mode 100644
index 0000000..ec8500d
--- /dev/null
+++ b/libbsd/quick_start.rst
@@ -0,0 +1,51 @@
+.. COMMENT: Written by Husni Faiz
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+Quick Start
+The LibBSD is a standalone repository and needs to be built
+separately.
+The repository can be found here: https://git.rtems.org/rtems-libbsd/
+Manual LibBSD Build
+Pre-requisites:
+- Built the tool set for your BSP
+- Built and installed RTEMS for your BSP with networking disabled and
+ POSIX API enabled.
+The following guide uses the Beagle BSP.
+Get the RTEMS LibBSD source
+ .. code-block:: shell
+ git clone https://git.rtems.org/rtems-libbsd/
+ cd rtems-libbsd
+Get the RTEMS Waf build systems
+ git submodule init
+ git submodule update rtems_waf
+Configure the build.
+ ./waf configure --prefix=/path/to/rtems/prefix \
+ --rtems-bsps=arm/beagleboneblack \
+ --buildset=buildset/default.ini
+Build and Install
+ ./waf
+ ./waf install
2.25.1
