[PATCH v1 05/13] Remove dynamicLibrary global variable
Ryan Long ryan.long at oarcorp.com
Sun Aug 1 23:23:39 UTC 2021
- Replaced dynamicLibrary in app_common with local variables
- Changed data type to string
  - Changed conditionals to reflect this
 tester/covoar/ExecutableInfo.cc | 10 +++++-----
 tester/covoar/ExecutableInfo.h  |  6 +++---
 tester/covoar/TraceConverter.cc |  5 +++--
 tester/covoar/app_common.cc     |  1 -
 tester/covoar/app_common.h      |  1 -
 tester/covoar/covoar.cc         |  9 +++++----
 6 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
index a6184e7..9c3031e 100644
--- a/tester/covoar/ExecutableInfo.cc
+++ b/tester/covoar/ExecutableInfo.cc
@@ -18,18 +18,18 @@
 namespace Coverage {
   ExecutableInfo::ExecutableInfo(
-    const char* const theExecutableName,
-    const char* const theLibraryName,
-    bool              verbose
+    const char* const  theExecutableName,
+    const std::string& theLibraryName,
+    bool               verbose
     ) : fileName(theExecutableName),
         loadAddress(0)
-    if (theLibraryName != nullptr)
+    if ( !theLibraryName.empty() )
       libraryName = theLibraryName;
     if (verbose) {
       std::cerr << "Loading executable " << theExecutableName;
         std::cerr << " (" << theLibraryName << ')';
       std::cerr << std::endl;
diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
index 1f977a0..851a59d 100644
--- a/tester/covoar/ExecutableInfo.h
+++ b/tester/covoar/ExecutableInfo.h
@@ -43,9 +43,9 @@ namespace Coverage {
      *  @param[in] verbose specifies whether to be verbose with output
     ExecutableInfo(
-      const char* const theLibraryName = NULL,
-      bool              verbose = false
+      const std::string& theLibraryName = "",
+      bool               verbose = false
diff --git a/tester/covoar/TraceConverter.cc b/tester/covoar/TraceConverter.cc
index 89e0736..c997702 100644
--- a/tester/covoar/TraceConverter.cc
+++ b/tester/covoar/TraceConverter.cc
@@ -91,6 +91,7 @@ int main(
   rld::process::tempfile       err( ".err" );
   Coverage::ObjdumpProcessor   objdumpProcessor;
   bool                         verbose = false;
+  std::string                  dynamicLibrary;
   setup_signals();
@@ -130,13 +131,13 @@ int main(
   // Create toolnames.
   TargetInfo = Target::TargetFactory( cpuname );
-  if (dynamicLibrary)
+  if ( !dynamicLibrary.empty() )
     executableInfo = new Coverage::ExecutableInfo( executable, dynamicLibrary );
   else
     executableInfo = new Coverage::ExecutableInfo( executable );
   // If a dynamic library was specified, determine the load address.
     executableInfo->setLoadAddress(
       objdumpProcessor.determineLoadAddress( executableInfo )
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index 9dfe81e..587af1a 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -60,7 +60,6 @@ Coverage::DesiredSymbols*   SymbolsToAnalyze    = NULL;
 const char*                 outputDirectory     = ".";
 bool                        BranchInfoAvailable = false;
 Target::TargetBase*         TargetInfo          = NULL;
-const char*                 dynamicLibrary      = NULL;
 const char*                 projectName         = NULL;
 char                        inputBuffer[MAX_LINE_LENGTH];
 char                        inputBuffer2[MAX_LINE_LENGTH];
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index ac66eda..6cb8577 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -16,7 +16,6 @@ extern Coverage::DesiredSymbols*    SymbolsToAnalyze;
 extern const char*                  outputDirectory;
 extern bool                         BranchInfoAvailable;
 extern Target::TargetBase*          TargetInfo;
-extern const char*                  dynamicLibrary;
 extern const char*                  projectName;
 #define MAX_LINE_LENGTH             512
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 9c88b00..3894867 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -177,6 +177,7 @@ int covoar(
   Coverage::Explanations        allExplanations;
   // Process command line options.
@@ -303,13 +304,13 @@ int covoar(
       // If there was at least one coverage file, create the
       // executable information.
       if (!coverageFileNames.empty()) {
-        if (dynamicLibrary) {
+        if ( !dynamicLibrary.empty() ) {
             singleExecutable, dynamicLibrary, verbose
         } else {
-            singleExecutable, nullptr, verbose
+            singleExecutable, "", verbose
@@ -333,7 +334,7 @@ int covoar(
                     << std::endl;
         } else {
-            argv[i], nullptr, verbose
+            argv[i], "", verbose
           executablesToAnalyze.push_back( executableInfo );
           coverageFileNames.push_back( coverageFileName );
@@ -373,7 +374,7 @@ int covoar(
                 << std::endl;
       exe->setLoadAddress( objdumpProcessor.determineLoadAddress( exe ) );
1.8.3.1
