[PATCH v2 00/13] Remove app_common
Ryan Long
ryan.long at oarcorp.com
Mon Aug 2 20:44:16 UTC 2021
Hi,
In this iteration I:
- Removed the typedef in ObjdumpProcessor.h
- Changed targetInfo to be a shared pointer
- Got rid of some of the get & set methods for targetInfo_m
- Added lastState_m to initialization list in ReportsHtml.cc
Thanks,
Ryan
Ryan Long (13):
Remove AllExplanations global variable
ReportsHtml.cc: Initialize lastState_m
Remove objdumpProcessor global variable
Remove Verbose global variable
Remove dynamicLibrary global variable
Remove projectName global variable
Remove outputDirectory global variable
Remove input buffer global variables
Remove SymbolsToAnalyze global variable
Remove BranchInfoAvailable global variable
Remove TargetInfo global variable
app_common: Remove functions and macros
Remove app_common and all references to it
tester/covoar/CoverageReaderBase.cc | 5 ++
tester/covoar/CoverageReaderBase.h | 15 ++++
tester/covoar/CoverageReaderQEMU.cc | 7 +-
tester/covoar/CoverageReaderTSIM.cc | 5 +-
tester/covoar/DesiredSymbols.cc | 28 +++---
tester/covoar/DesiredSymbols.h | 27 ++++--
tester/covoar/ExecutableInfo.cc | 23 ++---
tester/covoar/ExecutableInfo.h | 17 +++-
tester/covoar/Explanations.cc | 21 ++---
tester/covoar/GcovData.cc | 7 +-
tester/covoar/GcovData.h | 12 ++-
tester/covoar/GcovFunctionData.cc | 15 ++--
tester/covoar/GcovFunctionData.h | 6 +-
tester/covoar/Makefile | 6 +-
tester/covoar/ObjdumpProcessor.cc | 68 ++++++++++-----
tester/covoar/ObjdumpProcessor.h | 113 +++++++++++++++---------
tester/covoar/ReportsBase.cc | 166 +++++++++++++++++++++++-------------
tester/covoar/ReportsBase.h | 69 +++++++++++++--
tester/covoar/ReportsHtml.cc | 64 +++++++++-----
tester/covoar/ReportsHtml.h | 10 ++-
tester/covoar/ReportsText.cc | 28 ++++--
tester/covoar/ReportsText.h | 10 ++-
tester/covoar/SymbolTable.cc | 1 -
tester/covoar/TraceConverter.cc | 39 ++++++---
tester/covoar/TraceReaderBase.h | 7 +-
tester/covoar/TraceReaderLogQEMU.cc | 25 +++++-
tester/covoar/TraceReaderLogQEMU.h | 6 +-
tester/covoar/TraceWriterBase.h | 9 +-
tester/covoar/TraceWriterQEMU.cc | 12 +--
tester/covoar/TraceWriterQEMU.h | 4 +-
tester/covoar/app_common.cc | 118 -------------------------
tester/covoar/app_common.h | 34 --------
tester/covoar/coverage_converter.cc | 1 -
tester/covoar/covmerge.cc | 8 +-
tester/covoar/covoar.cc | 125 ++++++++++++++++++---------
tester/covoar/wscript | 3 +-
36 files changed, 659 insertions(+), 455 deletions(-)
delete mode 100644 tester/covoar/app_common.cc
delete mode 100644 tester/covoar/app_common.h
1.8.3.1
