[PATCH v2 04/13] Remove Verbose global variable
Ryan Long ryan.long at oarcorp.com
Mon Aug 2 20:44:20 UTC 2021
Replaced Verbose in app_common with local variables that are passed
as a parameter into numerous functions
 tester/covoar/DesiredSymbols.cc   | 17 ++++++++--------
 tester/covoar/DesiredSymbols.h    | 13 +++++++++---
 tester/covoar/ExecutableInfo.h    |  1 +
 tester/covoar/ObjdumpProcessor.cc | 23 ++++++++++++++-------
 tester/covoar/ObjdumpProcessor.h  |  5 +++--
 tester/covoar/ReportsBase.cc      | 15 +++++++-------
 tester/covoar/ReportsBase.h       |  4 +++-
 tester/covoar/TraceConverter.cc   |  5 +++--
 tester/covoar/TraceWriterBase.h   |  4 +++-
 tester/covoar/TraceWriterQEMU.cc  |  7 ++++---
 tester/covoar/TraceWriterQEMU.h   |  4 +++-
 tester/covoar/app_common.cc       |  1 -
 tester/covoar/app_common.h        |  1 -
 tester/covoar/covoar.cc           | 43 ++++++++++++++++++++-------------------
 14 files changed, 85 insertions(+), 58 deletions(-)
diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
index caa6acd..5d5e637 100644
--- a/tester/covoar/DesiredSymbols.cc
+++ b/tester/covoar/DesiredSymbols.cc
@@ -189,7 +189,7 @@ namespace Coverage {
-  void DesiredSymbols::computeUncovered( void )
+  void DesiredSymbols::computeUncovered( bool verbose )
     // Look at each symbol set.
     for (const auto& kv : setNamesToSymbols) {
@@ -308,7 +308,7 @@ namespace Coverage {
                   CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN,
                   1
-                if (Verbose)
+                if (verbose)
                   std::cerr << "Branch always taken found in" << symbol
                             << std::hex
                             << " (0x" << info.baseAddress + la
@@ -326,7 +326,7 @@ namespace Coverage {
                   CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN,
                   1
-                if (Verbose)
+                if (verbose)
                   std::cerr << "Branch never taken found in " << symbol
                             << std::hex
@@ -350,7 +350,8 @@ namespace Coverage {
     const std::string& exefileName,
     const std::string& symbolName,
     uint32_t           size,
-    uint32_t           sizeWithoutNops
+    uint32_t           sizeWithoutNops,
+    bool               verbose
     CoverageMapBase* aCoverageMap;
@@ -403,7 +404,7 @@ namespace Coverage {
       aCoverageMap = new CoverageMap( exefileName, 0, highAddress );
-      if ( Verbose )
+      if ( verbose )
         fprintf(
           stderr,
           "Created unified coverage map for %s (0x%x - 0x%x)\n",
@@ -440,7 +441,7 @@ namespace Coverage {
       return &set[ symbolName ];
-  void DesiredSymbols::findSourceForUncovered( void )
+  void DesiredSymbols::findSourceForUncovered( bool verbose )
     // Process uncovered ranges and/or branches for each symbol.
     for (auto& d : SymbolsToAnalyze->set) {
@@ -448,7 +449,7 @@ namespace Coverage {
       CoverageRanges* theRanges = d.second.uncoveredRanges;
       if (theRanges != nullptr) {
         if (!theRanges->set.empty()) {
-          if (Verbose)
+          if (verbose)
             std::cerr << "Looking up source lines for uncovered ranges in "
                       << d.first
                       << std::endl;
@@ -459,7 +460,7 @@ namespace Coverage {
         CoverageRanges* theBranches = d.second.uncoveredBranches;
         if (theBranches != nullptr) {
           if (!theBranches->set.empty()) {
-            if (Verbose)
+            if (verbose)
               std::cerr << "Looking up source lines for uncovered branches in "
                         << d.first
                         << std::endl;
diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
index 411b818..791b4ea 100644
--- a/tester/covoar/DesiredSymbols.h
+++ b/tester/covoar/DesiredSymbols.h
@@ -222,8 +222,10 @@ namespace Coverage {
      *  This method analyzes each symbols coverage map to determine any
      *  uncovered ranges or branches.
+     *  @param[in] verbose specifies whether to be verbose with output
-    void computeUncovered( void );
+    void computeUncovered( bool verbose );
      *  This method creates a coverage map for the specified symbol
@@ -234,12 +236,15 @@ namespace Coverage {
      *  @param[in] symbolName specifies the symbol for which to create
      *             a coverage map
      *  @param[in] size specifies the size of the coverage map to create
+     *  @param[in] sizeWithoutNops specifies the size without no ops
     void createCoverageMap(
       uint32_t           size,
+      bool               verbose
@@ -256,8 +261,10 @@ namespace Coverage {
      *  This method determines the source lines that correspond to any
-    void findSourceForUncovered( void );
+    void findSourceForUncovered( bool verbose );
      *  This method returns the total number of branches always taken
diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
index dfc71aa..1f977a0 100644
--- a/tester/covoar/ExecutableInfo.h
+++ b/tester/covoar/ExecutableInfo.h
@@ -40,6 +40,7 @@ namespace Coverage {
      *  @param[in] theExecutableName specifies the name of the executable
      *  @param[in] theLibraryName specifies the name of the executable
     ExecutableInfo(
       const char* const theExecutableName,
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index c2ed3d5..2bf1685 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -29,7 +29,8 @@ namespace Coverage {
   void finalizeSymbol(
     ExecutableInfo* const            executableInfo,
-    ObjdumpProcessor::objdumpLines_t instructions
+    ObjdumpProcessor::objdumpLines_t instructions,
+    bool                             verbose
     // Find the symbol's coverage map.
     try {
@@ -105,7 +106,11 @@ namespace Coverage {
       // Create a unified coverage map for the symbol.
       SymbolsToAnalyze->createCoverageMap(
-        executableInfo->getFileName().c_str(), symbolName, size, sizeWithoutNops
+        executableInfo->getFileName().c_str(),
+        symbolName,
+        size,
+        sizeWithoutNops,
+        verbose
     } catch (const ExecutableInfo::CoverageMapNotFoundError& e) {
       // Allow execution to continue even if a coverage map could not be
@@ -317,7 +322,8 @@ namespace Coverage {
   void ObjdumpProcessor::load(
     ExecutableInfo* const    executableInformation,
     rld::process::tempfile&  objdumpFile,
-    rld::process::tempfile&  err
+    rld::process::tempfile&  err,
+    bool                     verbose
     std::string     currentSymbol = "";
@@ -353,7 +359,8 @@ namespace Coverage {
           finalizeSymbol(
             currentSymbol,
-            theInstructions
+            theInstructions,
+            verbose
           fprintf(
             stderr,
@@ -408,7 +415,8 @@ namespace Coverage {
           finalizeSymbol(
             currentSymbol,
-            theInstructions
+            theInstructions,
+            verbose
@@ -450,8 +458,9 @@ namespace Coverage {
           finalizeSymbol(
             currentSymbol,
-            theInstructions
+            theInstructions,
+            verbose
         processSymbol = false;
diff --git a/tester/covoar/ObjdumpProcessor.h b/tester/covoar/ObjdumpProcessor.h
index c75755d..d60a768 100644
--- a/tester/covoar/ObjdumpProcessor.h
+++ b/tester/covoar/ObjdumpProcessor.h
@@ -120,9 +120,10 @@ namespace Coverage {
      *  the specified executable.
     void load(
-      ExecutableInfo* const executableInformation,
+      ExecutableInfo* const   executableInformation,
       rld::process::tempfile& dmp,
+      bool                    verbose
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index 62229c0..8947f58 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -564,7 +564,8 @@ void  ReportsBase::WriteSummaryReport(
 void GenerateReports(
   const std::string&      symbolSetName,
-  Coverage::Explanations& allExplanations
+  Coverage::Explanations& allExplanations,
+  bool                    verbose
   typedef std::list<ReportsBase *> reportList_t;
@@ -586,37 +587,37 @@ void GenerateReports(
     reports = *ritr;
     reportName = "index" + reports->ReportExtension();
-    if ( Verbose ) {
+    if ( verbose ) {
       std::cerr << "Generate " << reportName << std::endl;
     reports->WriteIndex( reportName );
     reportName = "annotated" + reports->ReportExtension();
-    if ( Verbose ) {
+    if ( verbose ) {
     reports->WriteAnnotatedReport( reportName );
     reportName = "branch" + reports->ReportExtension();
-    if ( Verbose ) {
+    if ( verbose ) {
     reports->WriteBranchReport( reportName );
     reportName = "uncovered" + reports->ReportExtension();
-    if ( Verbose ) {
+    if ( verbose ) {
     reports->WriteCoverageReport( reportName );
     reportName = "sizes" + reports->ReportExtension();
-    if ( Verbose ) {
+    if ( verbose ) {
     reports->WriteSizeReport( reportName );
     reportName = "symbolSummary" + reports->ReportExtension();
-    if ( Verbose ) {
+    if ( verbose ) {
     reports->WriteSymbolSummaryReport( reportName );
diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
index efc110d..41ac7ef 100644
--- a/tester/covoar/ReportsBase.h
+++ b/tester/covoar/ReportsBase.h
@@ -400,10 +400,12 @@ class ReportsBase {
  *  @param[in] symbolSetName is the name of the symbol set to report on.
  *  @param[in] allExplanations is the explanations to report on.
+  bool                    verbose
diff --git a/tester/covoar/TraceConverter.cc b/tester/covoar/TraceConverter.cc
index cd64faf..89e0736 100644
--- a/tester/covoar/TraceConverter.cc
+++ b/tester/covoar/TraceConverter.cc
@@ -90,6 +90,7 @@ int main(
   rld::process::tempfile       objdumpFile( ".dmp" );
   rld::process::tempfile       err( ".err" );
   Coverage::ObjdumpProcessor   objdumpProcessor;
+  bool                         verbose = false;
   setup_signals();
@@ -105,7 +106,7 @@ int main(
       case 'l': logname = optarg;        break;
       case 'L': dynamicLibrary = optarg; break;
       case 't': tracefile = optarg;      break;
-      case 'v': Verbose = true;          break;
+      case 'v': verbose = true;          break;
       default:  usage();
@@ -141,5 +142,5 @@ int main(
   objdumpProcessor.loadAddressTable( executableInfo, objdumpFile, err );
   log.processFile( logname, objdumpProcessor );
-  trace.writeFile( tracefile, &log );
+  trace.writeFile( tracefile, &log, verbose );
diff --git a/tester/covoar/TraceWriterBase.h b/tester/covoar/TraceWriterBase.h
index 41307d1..070dcca 100644
--- a/tester/covoar/TraceWriterBase.h
+++ b/tester/covoar/TraceWriterBase.h
@@ -36,12 +36,14 @@ namespace Trace {
      *  @param[in] file specifies the name of the file to write
      *  @param[in] log structure where the trace data was read into
      *  @return Returns TRUE if the method succeeded and FALSE if it failed.
      virtual bool writeFile(
        const char* const          file,
-       Trace::TraceReaderBase    *log
+       Trace::TraceReaderBase    *log,
+       bool                       verbose
      ) =  0;
diff --git a/tester/covoar/TraceWriterQEMU.cc b/tester/covoar/TraceWriterQEMU.cc
index 26447af..01d9cbc 100644
--- a/tester/covoar/TraceWriterQEMU.cc
+++ b/tester/covoar/TraceWriterQEMU.cc
@@ -73,7 +73,8 @@ namespace Trace {
   bool TraceWriterQEMU::writeFile(
+    bool                       verbose
     struct trace_header header;
@@ -120,7 +121,7 @@ namespace Trace {
       return false;
-    if (Verbose)
+    if (verbose)
       std::cerr << "magic = " << header.magic << std::endl
                 << "version = " << header.version << std::endl
                 << "kind = " << header.kind << std::endl
@@ -157,7 +158,7 @@ namespace Trace {
           break;
-      if ( Verbose )
+      if ( verbose )
         std::cerr << std::hex << std::setfill('0')
                   << entry.pc << ' ' << entry.size << ' ' << entry.op
                   << std::dec << std::setfill(' ')
diff --git a/tester/covoar/TraceWriterQEMU.h b/tester/covoar/TraceWriterQEMU.h
index 89fca5e..09c2ddf 100644
--- a/tester/covoar/TraceWriterQEMU.h
+++ b/tester/covoar/TraceWriterQEMU.h
@@ -39,12 +39,14 @@ namespace Trace {
      bool writeFile(
+       bool                       verbose
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index 1c49c72..9dfe81e 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -57,7 +57,6 @@
  *  Global variables for the program
 Coverage::DesiredSymbols*   SymbolsToAnalyze    = NULL;
-bool                        Verbose             = false;
 const char*                 outputDirectory     = ".";
 bool                        BranchInfoAvailable = false;
 Target::TargetBase*         TargetInfo          = NULL;
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index eb250e8..ac66eda 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -13,7 +13,6 @@
 #include "TargetBase.h"
 extern Coverage::DesiredSymbols*    SymbolsToAnalyze;
-extern bool                         Verbose;
 extern const char*                  outputDirectory;
 extern bool                         BranchInfoAvailable;
 extern Target::TargetBase*          TargetInfo;
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 46ba348..9c88b00 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -176,6 +176,7 @@ int covoar(
   int                           opt;
   Coverage::Explanations        allExplanations;
   // Process command line options.
@@ -193,7 +194,7 @@ int covoar(
       case 'S': symbolSet           = optarg; break;
       case 'T': target              = optarg; break;
       case 'O': outputDirectory     = optarg; break;
                 rld::verbose_inc ();          break;
       case 'p': projectName         = optarg; break;
       case 'd': debug               = true;   break;
@@ -243,7 +244,7 @@ int covoar(
     buildTarget = target;
-  if (Verbose) {
+  if (verbose) {
     if (singleExecutable) {
       std::cerr << "Processing a single executable and multiple coverage files"
                 << std::endl;
@@ -277,7 +278,7 @@ int covoar(
   // Read symbol configuration file and load needed symbols.
-  SymbolsToAnalyze->load( symbolSet, buildTarget, buildBSP, Verbose );
+  SymbolsToAnalyze->load( symbolSet, buildTarget, buildBSP, verbose );
   // If a single executable was specified, process the remaining
   // arguments as coverage file names.
@@ -304,11 +305,11 @@ int covoar(
       if (!coverageFileNames.empty()) {
         if (dynamicLibrary) {
           executableInfo = new Coverage::ExecutableInfo(
-            singleExecutable, dynamicLibrary, Verbose
+            singleExecutable, dynamicLibrary, verbose
         } else {
-            singleExecutable, nullptr, Verbose
+            singleExecutable, nullptr, verbose
@@ -332,7 +333,7 @@ int covoar(
                     << std::endl;
         } else {
-            argv[i], nullptr, Verbose
+            argv[i], nullptr, verbose
           executablesToAnalyze.push_back( executableInfo );
           coverageFileNames.push_back( coverageFileName );
@@ -351,7 +352,7 @@ int covoar(
   if (executablesToAnalyze.size() != coverageFileNames.size())
     throw rld::error( "executables and coverage name size mismatch", "covoar" );
-  if ( Verbose )
+  if ( verbose )
     std::cerr << "Analyzing " << SymbolsToAnalyze->allSymbols().size()
               << " symbols" << std::endl;
@@ -367,7 +368,7 @@ int covoar(
   // Prepare each executable for analysis.
   for (auto& exe : executablesToAnalyze) {
-    if (Verbose)
+    if (verbose)
       std::cerr << "Extracting information from: " << exe->getFileName()
                 << std::endl;
@@ -377,7 +378,7 @@ int covoar(
     // Load the objdump for the symbols in this executable.
-    objdumpProcessor.load( exe, objdumpFile, err );
+    objdumpProcessor.load( exe, objdumpFile, err, verbose );
@@ -388,7 +389,7 @@ int covoar(
   Executables::iterator eitr = executablesToAnalyze.begin();
   for (const auto& cname : coverageFileNames) {
     Coverage::ExecutableInfo* exe = *eitr;
-    if (Verbose)
+    if (verbose)
       std::cerr << "Processing coverage file " << cname
                 << " for executable " << exe->getFileName()
                 << std::endl;
@@ -408,7 +409,7 @@ int covoar(
   // Do necessary preprocessing of uncovered ranges and branches
-  if (Verbose)
+  if (verbose)
     std::cerr << "Preprocess uncovered ranges and branches" << std::endl;
   SymbolsToAnalyze->preprocess();
@@ -417,7 +418,7 @@ int covoar(
   // Generate Gcov reports
   if (gcnosFileName) {
-    if (Verbose)
+    if (verbose)
       std::cerr << "Generating Gcov reports..." << std::endl;
     gcnosFile = fopen ( gcnosFileName , "r" );
@@ -429,7 +430,7 @@ int covoar(
         gcovFile = new Gcov::GcovData();
         strcpy( gcnoFileName, inputBuffer );
-        if ( Verbose )
+        if ( verbose )
           std::cerr << "Processing file: " << gcnoFileName << std::endl;
         if ( gcovFile->readGcnoFile( gcnoFileName ) ) {
@@ -447,32 +448,32 @@ int covoar(
   // Determine the uncovered ranges and branches.
-  if (Verbose)
+  if (verbose)
     std::cerr << "Computing uncovered ranges and branches" << std::endl;
-  SymbolsToAnalyze->computeUncovered();
+  SymbolsToAnalyze->computeUncovered( verbose );
   // Calculate remainder of statistics.
-  if (Verbose)
+  if (verbose)
     std::cerr << "Calculate statistics" << std::endl;
   SymbolsToAnalyze->calculateStatistics();
   // Look up the source lines for any uncovered ranges and branches.
-  if (Verbose)
+  if (verbose)
     std::cerr << "Looking up source lines for uncovered ranges and branches"
               << std::endl;
-  SymbolsToAnalyze->findSourceForUncovered();
+  SymbolsToAnalyze->findSourceForUncovered( verbose );
   // Report the coverage data.
-  if (Verbose)
+  if (verbose)
     std::cerr << "Generate Reports" << std::endl;
   for (const auto& setName : SymbolsToAnalyze->getSetNames()) {
-    Coverage::GenerateReports( setName, allExplanations );
+    Coverage::GenerateReports( setName, allExplanations, verbose );
   // Write explanations that were not found.
@@ -483,7 +484,7 @@ int covoar(
     notFound += "/";
     notFound += "ExplanationsNotFound.txt";
-    if (Verbose)
+    if (verbose)
       std::cerr << "Writing Not Found Report (" << notFound<< ')' << std::endl;
     allExplanations.writeNotFound( notFound.c_str() );
1.8.3.1
