[PATCH v2 12/13] app_common: Remove functions and macros
Ryan Long
ryan.long at oarcorp.com
Mon Aug 2 20:44:28 UTC 2021
- Moved functions from app_common to the file they are used
- Got rid of FileIsNewer() since it's not being used
- Removed macros
tester/covoar/TraceReaderLogQEMU.cc | 14 +++++++++
tester/covoar/app_common.cc | 58 -------------------------------------
tester/covoar/app_common.h | 3 --
tester/covoar/covoar.cc | 20 +++++++++++++
4 files changed, 34 insertions(+), 61 deletions(-)
diff --git a/tester/covoar/TraceReaderLogQEMU.cc b/tester/covoar/TraceReaderLogQEMU.cc
index 37952a3..e65628e 100644
--- a/tester/covoar/TraceReaderLogQEMU.cc
+++ b/tester/covoar/TraceReaderLogQEMU.cc
@@ -63,6 +63,20 @@
#define MAX_LINE_LENGTH 512
+bool ReadUntilFound( FILE *file, const char *line )
+ char discardBuff[100];
+ size_t len = strlen( line );
+ do {
+ if ( !fgets( discardBuff, 99, file ) )
+ return false;
+ if ( strncmp( discardBuff, line, len ) == 0 )
+ return true;
+ } while (1);
namespace Trace {
TraceReaderLogQEMU::TraceReaderLogQEMU()
diff --git a/tester/covoar/app_common.cc b/tester/covoar/app_common.cc
index 568d108..9fece7b 100644
--- a/tester/covoar/app_common.cc
+++ b/tester/covoar/app_common.cc
@@ -40,68 +40,10 @@
#include "app_common.h"
#include "DesiredSymbols.h"
#include "Explanations.h"
-#if HAVE_STAT64
-#define STAT stat64
-#else
-#define STAT stat
-#endif
-#if HAVE_OPEN64
-#define OPEN fopen64
-#else
-#define OPEN fopen
-#endif
* Global variables for the program
-bool FileIsNewer(
- const char *f1,
- const char *f2
- struct STAT buf1, buf2;
- if (STAT( f2, &buf2 ) == -1)
- return true;
- if (STAT( f1, &buf1 ) == -1)
- exit (1);
- if (buf1.st_mtime > buf2.st_mtime)
- return true;
- return false;
-bool FileIsReadable( const char *f1 )
- struct STAT buf1;
- return false;
- if (buf1.st_size == 0)
- return false;
- // XXX check permission ??
- return true;
-bool ReadUntilFound( FILE *file, const char *line )
- char discardBuff[100];
- size_t len = strlen( line );
- do {
- if ( !fgets( discardBuff, 99, file ) )
- return false;
- if ( strncmp( discardBuff, line, len ) == 0 )
- return true;
- } while (1);
diff --git a/tester/covoar/app_common.h b/tester/covoar/app_common.h
index 454d389..5da4bb3 100644
--- a/tester/covoar/app_common.h
+++ b/tester/covoar/app_common.h
@@ -14,8 +14,5 @@
-bool FileIsNewer( const char *f1, const char *f2 );
-bool FileIsReadable( const char *f1 );
-bool ReadUntilFound( FILE *file, const char *line );
#endif
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index e0dc341..25724b5 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -30,6 +30,12 @@
#include "TargetFactory.h"
#include "GcovData.h"
+#if HAVE_STAT64
+#define STAT stat64
+#else
+#define STAT stat
+#endif
#if defined(_WIN32) || defined(__CYGWIN__)
#define kill(p,s) raise(s)
#endif
@@ -40,6 +46,20 @@ typedef std::list<std::string> CoverageNames;
typedef std::list<Coverage::ExecutableInfo*> Executables;
typedef std::string option_error;
+bool FileIsReadable( const char *f1 )
+ struct STAT buf1;
+ if (STAT( f1, &buf1 ) == -1)
+ return false;
+ if (buf1.st_size == 0)
+ return false;
+ // XXX check permission ??
+ return true;
* Create a build path from the executable paths. Also extract the build prefix
* and BSP names.
1.8.3.1
