[PATCH 1/1] testsuites: Added tests for sig2str/str2sig methods
Matt Joyce mfjoyce2004 at gmail.com
Tue Aug 3 04:18:38 UTC 2021
Added psxsignal09 in psxtests and compile only test in psxhdrs in order to evaluate
newly added POSIX standard methods in Newlib.
 spec/build/testsuites/psxtests/grp.yml        |   2 +
 spec/build/testsuites/psxtests/libpsxhdrs.yml |   1 +
 .../build/testsuites/psxtests/psxsignal09.yml |  21 ++
 testsuites/psxtests/Makefile.am               |  11 +
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxhdrs/signal/sig2str.c  |  58 ++++
 testsuites/psxtests/psxsignal09/init.c        | 288 ++++++++++++++++++
 .../psxtests/psxsignal09/psxsignal09.doc      |  35 +++
 .../psxtests/psxsignal09/psxsignal09.scn      |  44 +++
 9 files changed, 461 insertions(+)
 create mode 100644 spec/build/testsuites/psxtests/psxsignal09.yml
 create mode 100644 testsuites/psxtests/psxhdrs/signal/sig2str.c
 create mode 100644 testsuites/psxtests/psxsignal09/init.c
 create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.doc
 create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.scn
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index fb7ce465ae..f61f45dbe9 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -205,6 +205,8 @@ links:
   uid: psxsignal07
 - role: build-dependency
   uid: psxsignal08
+- role: build-dependency
+  uid: psxsignal09
   uid: psxspin01
diff --git a/spec/build/testsuites/psxtests/libpsxhdrs.yml b/spec/build/testsuites/psxtests/libpsxhdrs.yml
index 6a0ab6d4f7..5767bcdacd 100644
--- a/spec/build/testsuites/psxtests/libpsxhdrs.yml
+++ b/spec/build/testsuites/psxtests/libpsxhdrs.yml
@@ -513,6 +513,7 @@ source:
 - testsuites/psxtests/psxhdrs/signal/sigtimedwait.c
 - testsuites/psxtests/psxhdrs/signal/sigwait.c
 - testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c
+- testsuites/psxtests/psxhdrs/signal/sig2str.c
 - testsuites/psxtests/psxhdrs/stddef/offsetof.c
 - testsuites/psxtests/psxhdrs/stdio/clearerr.c
 - testsuites/psxtests/psxhdrs/stdio/ctermid.c
diff --git a/spec/build/testsuites/psxtests/psxsignal09.yml b/spec/build/testsuites/psxtests/psxsignal09.yml
new file mode 100644
index 0000000000..08a29c7c5b
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxsignal09.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_POSIX_API
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxsignal09/init.c
+stlib: []
+target: testsuites/psxtests/psxsignal09.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a35f00b665..b62d5cab59 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -924,6 +924,17 @@ psxsignal08_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal08) \
 endif
 endif
+if HAS_POSIX
+if TEST_psxsignal09
+psx_tests += psxsignal09
+psx_screens += psxsignal09/psxsignal09.scn
+psx_docs += psxsignal09/psxsignal09.doc
+psxsignal09_SOURCES = psxsignal09/init.c
+psxsignal09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal09) \
+	$(support_includes) -I$(top_srcdir)/include
+endif
+endif
 if TEST_psxspin01
 psx_tests += psxspin01
 psx_screens += psxspin01/psxspin01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 3f95010cd3..7b9a1027ca 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -138,6 +138,7 @@ RTEMS_TEST_CHECK([psxsignal05])
 RTEMS_TEST_CHECK([psxsignal06])
 RTEMS_TEST_CHECK([psxsignal07])
 RTEMS_TEST_CHECK([psxsignal08])
+RTEMS_TEST_CHECK([psxsignal09])
 RTEMS_TEST_CHECK([psxspin01])
 RTEMS_TEST_CHECK([psxstack01])
 RTEMS_TEST_CHECK([psxstack02])
diff --git a/testsuites/psxtests/psxhdrs/signal/sig2str.c b/testsuites/psxtests/psxhdrs/signal/sig2str.c
index 0000000000..d4932c1961
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/signal/sig2str.c
@@ -0,0 +1,58 @@
+ * @file
+ * @brief Header File Conformance Test
+ * This test file is used to verify that the header files associated with
+ * invoking this function are correct.
+ * Copyright (C) 2021 Matthew Joyce
+ * are met:
+/* Defined to have access to SIG2STR_MAX and function prototypes in signal.h*/
+#define _GNU_SOURCE
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <signal.h>
+int test( void );
+int test( void )
+  int result;
+  int signal_number;
+  char signal_name[SIG2STR_MAX];
+  signal_number = SIGALRM;
+  result = sig2str(signal_number, signal_name);
+  return result;
diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
index 0000000000..79be957883
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/init.c
@@ -0,0 +1,288 @@
+ * @file
+ * @brief Test of sig2str and str2sig methods
+ * This test file is used to verify that the methods sig2str and str2sig
+ * are functioning as expected
+ * are met:
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <rtems/test.h>
+#include "test_support.h"
+//#include <sys/signal.h>
+const char rtems_test_name[] = "SIG2STR AND STR2SIG";
+static rtems_task Init(
+  rtems_task_argument ignored
+  rtems_print_printer_fprintf_putc(&rtems_test_printer);
+  TEST_BEGIN();
+  char test_str1[SIG2STR_MAX];
+  char test_str2[SIG2STR_MAX];
+  char test_str3[SIG2STR_MAX];
+  char test_str4[SIG2STR_MAX];
+  char test_str5[SIG2STR_MAX];
+  int res1;
+  int res2;
+  int retval;
+  int min = SIGRTMIN;
+  int max = SIGRTMAX;
+  printf( "\n" );
+  printf( "SIG2STR_MAX is %d\n", SIG2STR_MAX );
+  printf( "\n" );
+  printf( "SIGRTMIN is %d and SIGRTMAX is %d\n", min, max );
+  printf( "\n" );
+  printf( "Calling sig2str: \n" );
+  /* Expected pass */
+  retval = sig2str( 1, test_str1 );
+  rtems_test_assert( SIGHUP == 1 );
+  rtems_test_assert( retval == 0 );
+  rtems_test_assert( strcmp( test_str1, "HUP" ) == 0 );
+  printf( "The string for test1 is: %s\n", test_str1 );
+  retval = sig2str( 3, test_str2 );
+  rtems_test_assert( SIGQUIT == 3 );
+  rtems_test_assert( strcmp( test_str2, "QUIT" ) == 0 );
+  printf( "The string for test2 is: %s\n", test_str2 );
+  retval = sig2str( 27, test_str3 );
+  rtems_test_assert( SIGRTMIN == 27 );
+  rtems_test_assert( strcmp( test_str3, "RTMIN" ) == 0 );
+  printf( "The string for test3 is: %s\n", test_str3 );
+  retval = sig2str( 29, test_str4 );
+  rtems_test_assert( SIGRTMIN+2 == 29 );
+  rtems_test_assert( strcmp( test_str4, "RTMIN+2" ) == 0 );
+  printf( "The string for test4 is: %s\n", test_str4 );
+  retval = sig2str( 31, test_str4 );
+  rtems_test_assert( SIGRTMAX == 31 );
+  rtems_test_assert( strcmp( test_str4, "RTMAX" ) == 0);
+  printf( "The string for test5 is: %s\n", test_str4 );
+  retval = sig2str( 30, test_str4 );
+  rtems_test_assert( SIGRTMAX-1 == 30 );
+  rtems_test_assert( strcmp( test_str4, "RTMAX-1" ) == 0);
+  printf( "The string for test6 is: %s\n", test_str4 );
+  retval = sig2str( 9, test_str4 );
+  rtems_test_assert( SIGKILL == 9 );
+  rtems_test_assert(strcmp( test_str4, "KILL" ) == 0 );
+  printf( "The string for test7 is: %s\n", test_str4 );
+  retval = sig2str( 0, test_str4 );
+  rtems_test_assert( strcmp( test_str4, "EXIT" ) == 0);
+  printf( "The string for test8 is: %s\n", test_str4 );
+  /* Expected fail, invalid signal number */
+  retval = sig2str( 201, test_str5 );
+  rtems_test_assert( retval == -1);
+  rtems_test_assert( strcmp( test_str5, "" ) == 0);
+  printf( "The string for test9 is: %s\n", test_str5 );
+  /* Expected fail, max signal number + 1 */
+  retval = sig2str( 32, test_str5 );
+  rtems_test_assert( retval == -1 );
+  printf( "The string for test10 is: %s\n", test_str5 );
+  retval = sig2str( 2147483647, test_str5 );
+  printf( "The string for test11 is: %s\n", test_str5 );
+  printf( "\n" );
+  printf( "Calling str2sig: \n" );
+  retval = str2sig( "PIPE", &res1 );
+  rtems_test_assert( SIGPIPE == 13 );
+  rtems_test_assert( retval == 0);
+  rtems_test_assert( res1 == 13 );
+  printf( "Result 1 is: %d\n", res1 );
+  retval = str2sig( "TSTP", &res1 );
+  rtems_test_assert( SIGTSTP == 18 );
+  rtems_test_assert( res1 == 18 );
+  printf( "Result 2 is: %d\n", res1 );
+  retval = str2sig( "KILL", &res1 );
+  rtems_test_assert( res1 == 9 );
+  printf( "Result 3 is: %d\n", res1 );
+  /* Expected pass, String representation of valid integer */
+  retval = str2sig( "10", &res1 );
+  rtems_test_assert( res1 == 10 );
+  printf( "Result 4 is: %d\n", res1 );
+  retval = str2sig( "RTMIN", &res1 );
+  rtems_test_assert( res1 == 27 );
+  printf( "Result 5 is: %d\n", res1 );
+  retval = str2sig( "RTMIN+1", &res1 );
+  rtems_test_assert( SIGRTMIN+1 == 28 );
+  rtems_test_assert( res1 == 28 );
+  printf( "Result 6 is: %d\n", res1 );
+  retval = str2sig( "RTMAX-2", &res1 );
+  rtems_test_assert( SIGRTMAX-2 == 29 );
+  rtems_test_assert( res1 == 29 );
+  printf( "Result 7 is: %d\n", res1 );
+  /* Expected fail, invalid signal name */
+  retval = str2sig( "BOSS", &res2 );
+  printf( "Result 8 is: %d\n", res2 );
+  retval = str2sig( "RTMIN+1000", &res2 );
+  printf( "Result 9 is: %d\n", res2 );
+  retval = str2sig( "12xyz", &res2 );
+  printf( "Result 10 is: %d\n", res2 );
+  retval = str2sig( "xyz12", &res2 );
+  printf( "Result 11 is: %d\n", res2 );
+  retval = str2sig( "xyz12xyz", &res2 );
+  printf( "Result 12 is: %d\n", res2 );
+  /* Expected pass, string representation of valid integer */
+  retval = str2sig( "15", &res1 );
+  rtems_test_assert( res1 == 15 );
+  printf( "Result 13 is: %d\n", res1 );
+  /* Expected fail, string representation of invalid integer */
+  retval = str2sig( "40", &res2 );
+  printf( "Result 14 is: %d\n", res2 );
+  retval = str2sig( "EXIT", &res1 );
+  rtems_test_assert( res1 == 0 );
+  printf( "Result 15 is: %d\n", res1 );
+  printf( "\n" );
+  printf( "Calling str2sig using the result from previous call to sig2str\n" );
+  retval = str2sig( test_str1, &res1 );
+  rtems_test_assert( res1 == 1 );
+  retval = str2sig( test_str2, &res1 );
+  rtems_test_assert( res1 == 3 );
+  retval = str2sig( test_str3, &res1 );
+  /* Expected fail, calling using string from invalid sig2str call */
+  retval = str2sig( test_str5, &res2 );
+  printf( "Result 4 is: %d\n", res2 );
+  TEST_END();
+  rtems_test_exit( 0 );
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS            1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.doc b/testsuites/psxtests/psxsignal09/psxsignal09.doc
index 0000000000..c90ee805f0
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.doc
@@ -0,0 +1,35 @@
+ * @file
+ * are met:
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.scn b/testsuites/psxtests/psxsignal09/psxsignal09.scn
index 0000000000..344784bd2c
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.scn
@@ -0,0 +1,44 @@
+*** BEGIN OF TEST SIG2STR AND STR2SIG ***
+SIG2STR_MAX is 17
+SIGRTMIN is 27 and SIGRTMAX is 31
+Calling sig2str:
+The string for test1 is: HUP
+The string for test2 is: QUIT
+The string for test3 is: RTMIN
+The string for test4 is: RTMIN+2
+The string for test5 is: RTMAX
+The string for test6 is: RTMAX-1
+The string for test7 is: KILL
+The string for test8 is: EXIT
+The string for test9 is:
+The string for test10 is:
+The string for test11 is:
+Calling str2sig:
+Result 1 is: 13
+Result 2 is: 18
+Result 3 is: 9
+Result 4 is: 10
+Result 5 is: 27
+Result 6 is: 28
+Result 7 is: 29
+Result 8 is: 0
+Result 9 is: 0
+Result 10 is: 0
+Result 11 is: 0
+Result 12 is: 0
+Result 13 is: 15
+Result 14 is: 0
+Result 15 is: 0
+Calling str2sig using the result from previous call to sig2str
+Result 1 is: 1
+Result 2 is: 3
+Result 3 is: 27
+Result 4 is: 0
+*** END OF TEST SIG2STR AND STR2SIG ***
2.31.1
