[PATCH v1 1/4] GcovData.cc: Fix formatting
    Ryan Long
    ryan.long at oarcorp.com
    Tue Aug  3 20:30:56 UTC 2021
 tester/covoar/GcovData.cc | 198 +++++++++++++++++++++++++---------------------
 1 file changed, 106 insertions(+), 92 deletions(-)
diff --git a/tester/covoar/GcovData.cc b/tester/covoar/GcovData.cc
index 59963b6..6b18fa3 100644
--- a/tester/covoar/GcovData.cc
+++ b/tester/covoar/GcovData.cc
@@ -77,44 +77,45 @@ namespace Gcov {
       return false;
-    // Read and validate the gcnoPreamble (magic, version, timestamp) from the file
+    // Read and validate the gcnoPreamble (magic, version, timestamp)
+    // from the file
     status = readFilePreamble( &gcnoPreamble, gcovFile, GCNO_MAGIC );
-    if ( status <= 0 ){
+    if ( status <= 0 ) {
       std::cerr << "Unable to read " << gcnoFileName << std::endl;
       return false;
     //Read all remaining frames from file
-    while( readFrame(gcovFile) ){}
+    while( readFrame( gcovFile ) ) {}
     return true;
-  bool GcovData::writeGcdaFile ()
+  bool GcovData::writeGcdaFile()
-    gcov_preamble         preamble;
-    gcov_frame_header     header;
-    std::ofstream         gcdaFile;
-    functions_iterator_t  currentFunction;
-    arcs_iterator_t       currentArc;
-    uint32_t              buffer;
-    uint32_t              countersFound;
-    uint32_t              countersFoundSum;
-    uint64_t              countersSum;
-    uint64_t              countersMax;
-    uint64_t              llBuffer[4096];    // TODO: Use common buffer
-    gcov_statistics       objectStats;
-    gcov_statistics       programStats;
-    long int              bytes_before;
+    gcov_preamble        preamble;
+    gcov_frame_header    header;
+    std::ofstream        gcdaFile;
+    functions_iterator_t currentFunction;
+    arcs_iterator_t      currentArc;
+    uint32_t             buffer;
+    uint32_t             countersFound;
+    uint32_t             countersFoundSum;
+    uint64_t             countersSum;
+    uint64_t             countersMax;
+    uint64_t             llBuffer[4096];    // TODO: Use common buffer
+    gcov_statistics      objectStats;
+    gcov_statistics      programStats;
+    long int             bytes_before;
     // Debug message
     //std::cerr << "Writing file: " <<  gcdaFileName << std::endl;
     // Lets clear counters sumators
-    countersSum     = 0;
-    countersMax     = 0;
-    countersFoundSum   = 0;
+    countersSum      = 0;
+    countersMax      = 0;
+    countersFoundSum = 0;
     // Open the data file.
     gcdaFile.open( gcdaFileName );
@@ -124,9 +125,9 @@ namespace Gcov {
     //Form preamble
-    preamble.magic  = GCDA_MAGIC;
-    preamble.version  = gcnoPreamble.version;
-    preamble.timestamp  = gcnoPreamble.timestamp;
+    preamble.magic     = GCDA_MAGIC;
+    preamble.version   = gcnoPreamble.version;
+    preamble.timestamp = gcnoPreamble.timestamp;
     //Write preamble
     gcdaFile.write( (char *) &preamble , 4 * sizeof( preamble ) );
@@ -140,8 +141,7 @@ namespace Gcov {
       currentFunction = functions.begin();
       currentFunction != functions.end();
       currentFunction++
       //Write function announcement frame header (length always equals 2)
       header.tag = GCOV_TAG_FUNCTION;
       header.length = 2;
@@ -170,7 +170,12 @@ namespace Gcov {
       // Determine how many counters there are
       // and store their counts in buffer
       countersFound = 0;
-      (*currentFunction).getCounters( llBuffer, countersFound, countersSum, countersMax );
+      (*currentFunction).getCounters(
+        llBuffer,
+        countersFound,
+        countersSum,
+        countersMax
       countersFoundSum += countersFound;
       //Write info about counters
@@ -192,14 +197,14 @@ namespace Gcov {
     // Prepare frame with object file statistics
-    header.tag = GCOV_TAG_OBJECT_SUMMARY;
-    header.length = 9;
-    objectStats.checksum = 0;      // TODO: have no idea hov to calculates it :)
+    header.tag           = GCOV_TAG_OBJECT_SUMMARY;
+    header.length        = 9;
+    objectStats.checksum = 0;           // TODO: have no idea hov to calculates it :)
     objectStats.counters = countersFoundSum;
-    objectStats.runs = 1;        // We are lying for now, we have no means of figuring this out
-    objectStats.sum = countersSum;    // Sum of all counters
-    objectStats.max = countersMax;    // max value for counter on last run, we have no clue
-    objectStats.sumMax = countersMax;    // we have no clue
+    objectStats.runs     = 1;           // // We are lying for now, we have no clue
+    objectStats.sum      = countersSum; // Sum of all counters
+    objectStats.max      = countersMax; // max value for counter on last run, we have no clue
+    objectStats.sumMax   = countersMax; // we have no clue
     // Write data
     gcdaFile.write( (char *) &header, sizeof( header ) );
@@ -216,14 +221,14 @@ namespace Gcov {
     // Prepare frame with program statistics
-    header.tag = GCOV_TAG_PROGRAM_SUMMARY;
-    programStats.checksum = 0;      // TODO: have no idea hov to calculate it :)
+    header.tag            = GCOV_TAG_PROGRAM_SUMMARY;
+    programStats.checksum = 0;           // TODO: have no idea hov to calculate it :)
     programStats.counters = countersFoundSum;
-    programStats.runs = 1;      // We are lying for now, we have no clue
-    programStats.sum = countersSum;    // Sum of all counters
-    programStats.max = countersMax;    // max value for counter on last run, we have no clue
-    programStats.sumMax = countersMax;    // we have no clue
+    programStats.runs     = 1;           // We are lying for now, we have no clue
+    programStats.sum      = countersSum; // Sum of all counters
+    programStats.max      = countersMax; // max value for counter on last run, we have no clue
+    programStats.sumMax   = countersMax; // we have no clue
     // Write data
@@ -243,22 +248,21 @@ namespace Gcov {
   bool GcovData::readFrame( std::ifstream& gcovFile )
-    char                buffer[512];
-    char                intBuffer[16384];
-    uint32_t            tempBlockId;
-    blocks_iterator_t   tempBlockIterator;
-    int                 status;
-    status = readFrameHeader( &header, gcovFile);
+    char              buffer[512];
+    char              intBuffer[16384];
+    uint32_t          tempBlockId;
+    blocks_iterator_t tempBlockIterator;
+    int               status;
+    status = readFrameHeader( &header, gcovFile );
       // Not printing error message because this
       // happenns at the end of each file
       return false;
-    switch (header.tag){
+    switch ( header.tag ) {
       case GCOV_TAG_FUNCTION:
@@ -266,13 +270,13 @@ namespace Gcov {
           numberOfFunctions++;
           GcovFunctionData newFunction;
-          if ( !readFunctionFrame(header, gcovFile, &newFunction) ){
+          if ( !readFunctionFrame( header, gcovFile, &newFunction ) ) {
             std::cerr << "Error while reading FUNCTION from gcov file..."
                       << std::endl;
             return false;
-          functions.push_back(newFunction);
+          functions.push_back( newFunction );
         break;
@@ -289,8 +293,9 @@ namespace Gcov {
           return false;
-        for( uint32_t i = 0; i < header.length; i++ )
-          functions.back().addBlock(i, intBuffer[i], "");
+        for( uint32_t i = 0; i < header.length; i++ ) {
+          functions.back().addBlock( i, intBuffer[i], "" );
         break;
@@ -301,8 +306,13 @@ namespace Gcov {
           return false;
-        for ( int i = 1; i < (int) header.length; i += 2 )
-          functions.back().addArc(intBuffer[0], intBuffer[i], intBuffer[i+1]);
+        for ( int i = 1; i < (int) header.length; i += 2 ) {
+          functions.back().addArc(
+            intBuffer[0],
+            intBuffer[i],
+            intBuffer[i+1]
         break;
@@ -318,9 +328,9 @@ namespace Gcov {
         header.length -= 2;
         // Find the right block
-        tempBlockIterator =functions.back().findBlockById(tempBlockId);
+        tempBlockIterator = functions.back().findBlockById( tempBlockId );
-        header.length -= readString(buffer, gcovFile);
+        header.length -= readString( buffer, gcovFile );
         functions.back().setBlockFileName( tempBlockIterator, buffer );
         gcovFile.read( intBuffer, header.length );
@@ -328,11 +338,11 @@ namespace Gcov {
           std::cerr << "Error while reading LINES from gcov file..."
                     << std::endl;
           return false;
-        else
-          for (int i = 0; i < (int) (header.length - 2); i++)
+        } else {
+          for ( int i = 0; i < (int) (header.length - 2); i++ ) {
             functions.back().addBlockLine( tempBlockIterator, intBuffer[i] );
         break;
@@ -349,7 +359,7 @@ namespace Gcov {
   int GcovData::readString( char* buffer, std::ifstream& gcovFile )
-    int          length;
+    int length;
     gcovFile.read( (char *) &length, sizeof( int ) );
     if ( gcovFile.gcount() != sizeof( int ) ) {
@@ -371,13 +381,13 @@ namespace Gcov {
   int GcovData::readFrameHeader(
-    gcov_frame_header*   header,
-    std::ifstream&       gcovFile
+    gcov_frame_header* header,
+    std::ifstream&     gcovFile
-    int          length;
+    int length;
-    length = sizeof(gcov_frame_header);
+    length = sizeof( gcov_frame_header );
     gcovFile.read( (char *) header, length );
     if ( gcovFile.gcount() != length ) {
       std::cerr << "ERROR: Unable to read frame header from gcov file"
@@ -389,12 +399,12 @@ namespace Gcov {
   int GcovData::readFilePreamble(
-     gcov_preamble*       preamble,
-     std::ifstream&    gcovFile,
-     uint32_t        desiredMagic
+     gcov_preamble* preamble,
+     std::ifstream& gcovFile,
+     uint32_t       desiredMagic
-    int          length;
+    int length;
     length = sizeof( gcov_preamble );
     gcovFile.read( (char *) &preamble, 4 * sizeof( gcov_preamble ) );
@@ -414,33 +424,37 @@ namespace Gcov {
   bool GcovData::readFunctionFrame(
-    gcov_frame_header   header,
-    GcovFunctionData*  function
+    gcov_frame_header header,
+    GcovFunctionData* function
-    char         buffer[512];    //TODO: use common buffers
+    char buffer[512];
     gcovFile.read( (char *) &intBuffer, 8 );
     if ( gcovFile.gcount() != 8 ) {
       std::cerr << "ERROR: Unable to read Function ID & checksum" << std::endl;
       return false;
     header.length -= 2;
     function->setId( intBuffer[0] );
     function->setChecksum( intBuffer[1] );
     function->setFunctionName( buffer, symbolsToAnalyze_m );
     function->setFileName( buffer );
     gcovFile.read( (char*) &intBuffer, 4 * header.length );
     if (gcovFile.gcount() != 4 * header.length ) {
       std::cerr << "ERROR: Unable to read Function starting line number"
                 << std::endl;
       return false;
     function->setFirstLineNumber( intBuffer[0] );
     return true;
@@ -448,9 +462,9 @@ namespace Gcov {
   bool GcovData::writeReportFile()
-    uint32_t               i = 1;          //iterator
-    std::ofstream          textFile;
+    uint32_t             i = 1;          //iterator
+    std::ofstream        textFile;
     // Debug message
     // std::cerr << "Writing file: " << textFileName << std::endl;
@@ -468,8 +482,7 @@ namespace Gcov {
       currentFunction++
       (*currentFunction).printFunctionInfo( textFile, i );
       (*currentFunction).printCoverageInfo( textFile, i );
       i++;
@@ -491,30 +504,31 @@ namespace Gcov {
              << std::endl << std::endl;
-  void GcovData::writeGcovFile( )
+  void GcovData::writeGcovFile()
     //std::cerr << "Attempting to run gcov for: " << cFileName << std::endl;
     std::ostringstream command;
-    command << "( cd " << rld::path::dirname (cFileName)
-            << " && gcov " << rld::path::basename (cFileName)
+    command << "(  cd " << rld::path::dirname( cFileName )
+            << " && gcov " << rld::path::basename( cFileName )
             << " &>> gcov.log)";
     //std::cerr << "> " << command << std::endl;
-    system( command.str ().c_str () );
+    system( command.str().c_str() );
-  bool GcovData::processCounters(  )
+  bool GcovData::processCounters()
-    bool                  status = true;
+    bool                 status = true;
     for (
       currentFunction++
-      if ( !(*currentFunction).processFunctionCounters(  ) )
+      if ( !(*currentFunction).processFunctionCounters() ) {
         status = false;
     return status;
1.8.3.1
