[PATCH rtems-libbsd 0/5] RTEMS LibBSD Documentation
Christian MAUDERER
christian.mauderer at embedded-brains.de
Wed Aug 4 15:05:12 UTC 2021
Hello Gedare,
Am 04.08.21 um 16:55 schrieb Gedare Bloom:
> On Wed, Aug 4, 2021 at 4:18 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de> wrote:
>> Hello Chris,
>> Am 04.08.21 um 11:17 schrieb Chris Johns:
>>> On 4/8/21 6:34 pm, Christian MAUDERER wrote:
>>>> Hello Chris,
>>>> Am 04.08.21 um 09:28 schrieb Chris Johns:
>>>>> On 3/8/21 5:00 pm, Christian MAUDERER wrote:
>>>>>> Hello,
>>>>>> Am 03.08.21 um 04:07 schrieb Chris Johns:
>>>>>>> On 3/8/21 3:24 am, Sebastian Huber wrote:
>>>>>>>> On 02/08/2021 18:37, Vijay Kumar Banerjee wrote:
>>>>>>>>> I think there should be a high-level user manual subsection for
>>>>>>>>> networking that describes how the selection of the network stack
>>>>>>>>> works. We can then add another subsection about lwip since legacy
>>>>>>>>> already has one, and libbsd is getting added now.
>>>>>>>> This sounds like a good approach.
>>>>>>> I agree.
>>>>>>> Chris
>>>>>> Just so that we are all on the same page:
>>>>>> That would be a number of new subsections in
>>>>>> https://docs.rtems.org/branches/master/user/index.html:
>>>>>> - 15. Selecting a Network Stack
>>>>>> - 16. Add-on: libbsd Stack
>>>>>> - 17. Add-on: lwIP
>>>>>> - 18. Add-on: Legacy Network Stack
>>>>>> Or was it meant to be only a section
>>>>> I think a single section so all things networking are grouped.
>>>> That will result in either a deep nesting for the chapters or in very hard to
>>>> organize information because two levels are used up already.
>>>> For example the current legacy network manual has a
>>>> 5.3.1. Additional include files
>>>> If we make one "networking" group, that would be
>>>> 15. Networking
>>>> 15.3 Legacy Network Stack
>>>> 15.3.5 Using Networking in an RTEMS application
>>>> 15.3.5.3 Initialization
>>>> 15.3.5.3.1 Additional include files
>>>> And please also note: I think we should see libbsd more as an Add-on package and
>>>> less as a pure network stack.
>>> Yes this is true and if your top level is LibBSD you do not see networking and
>>> then networking becomes confusing if spread out in pieces. What would LibBSD and
>>> Legacy Networking mean if you are new RTEMS? Is Legacy networking some form of
>>> old embedded realtime protocol we support? :)
>>> Maybe Networking is about the history, features and options available in each
>>> package (Selection) and the LibBSD part is a link to the networking section of
>>> that package? This would mean the lwIP and Legacy network stack is still under
>>> Networking.
>> Hm. You are right that we have to somehow make it clear what features
>> can be provided by the libraries.
>>> Does "Additional includes" etc need to be a numbered section? Why not just make
>>> a heading in the block without it being a section?
>> It was more or less an example that I just took from the current legacy
>> networking manual. I think that manual should be about at the same
>> location and I don't think that anyone wants to do a detailed re-write.
>> So most likely we will just move the levels down.
>>>> It provides a lot more than just networking. It
>>>> has USB, it can add HDMI (on beagle for example), it includes an OpenSSL
>>>> implementation, ...
>>> Yes and if you look at the top level you could see something like:
>>> 9 Networking
>>> 10 USB
>>> 11 Graphics
>>> 12 FreeBSD On RTEMS
> +1
>>> The user manual has clear top level sections and I would like it to stay this
>>> way. But yes I understand it is hard to get the breakdown right and it may take
>>> a couple more loops until we have something that is clear.
>> Hm. That would mean that we split up the libbsd documentation to
>> multiple sections (at least networking and USB). Where can we put common
>> parts like "how to init libbsd"?
>> We also have multiple options in every section. For example OpenSSL can
>> be provided by libbsd or by OpenSSL / LibreSSL / *SSL. Could be
>> difficult for a user to find out how and which libs he can combine to
>> get what he wants. For example some user could start with lwIP for
>> networking and then later wants to add USB and SD/MMC and notes that in
>> that case it would have been a better choice to use libbsd for
>> networking in that case too.
>> We could add a chapter "Selecting Add-Ons" or "Selecting Libraries" with
>> a short description of the libs and when they are alternatives or when
> I'd like this as well. A library of libraries :) [technically, an
> index of libraries]
>> they complement each other. Then we can either add the manual of the
>> libs or Add-Ons as subsections (disadvantage: deep nesting) or we can
>> add them with some common prefix so that a user knows that he maybe
>> should first look into the "Selecting <Prefix>".
> +1
> My preference would be to leave the legacy doc where it is,
Just a comment for that point: I know that the doc has been moved around
a bit. But I think we should try to get all similar options onto the
same "level". Otherwise if a user searches for "How to do networking
with RTEMS" and he finds https://docs.rtems.org/ the only manual with
"Networking" is the legacy stack. If it is on the same page (level,
hirarchie, ...) like the headline "libbsd Networking and other cool
stuff" or "lwIP", a user instantly can see that there is more than one
option.
Of course, I'm open for discussion regarding that point.
Best regards
Christian
> and add a
> new libbsd section in the user manual, and cross-reference to it from
> other sections with clear high-level names (like Networking, USB,
> etc.) That is much the same way as we treated the RSB documentation.
> We need to refer to the libbsd too much for it to be in a separate
> manual, since cross-doc linking doesn't work, but we also should try
> not to split up the libbsd content and spread it around too much. I
> think that might be what Chris meant by his listing, with 12. FreeBSD
> on RTEMS.
> I'm open to suggestions though.
> Gedare
>> Best regards
>> Christian
>>> Chris
>> embedded brains GmbH
>> Herr Christian MAUDERER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> phone: +49-89-18 94 741 - 18
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
Dornierstr. 4
82178 Puchheim
Germany
