[PATCH v3] Test needed for timer_create with CLOCK_MONOTONIC
Thu Aug 5 19:22:51 UTC 2021
On Thu, Aug 5, 2021 at 12:36 PM Zacchaeus Leung
<zakthertemsdev at gmail.com> wrote:
> the timer_create() method can use CLOCK_MONOTONIC but there was  no test for this
The commit message needs to be improved, because this patch is doing
more than adding a "test", it is implementing the functionality to
create a CLOCK_MONOTONIC timer and to gettime() on it.
> Closes #3888
https://devel.rtems.org/ticket/3888  ??
> + if ( rtems_timespec_less_than( &now, &expire ) ) {
> +      rtems_timespec_subtract( &now, &expire, &result );
> +    } else {
> +      result.tv_nsec = 0;
> +      result.tv_sec  = 0;
The indentation level is wrong in this block.
> +  value->it_value = result;
> +  value->it_interval = ptimer->timer_data.it_interval;
> +  _POSIX_Timer_Release( cpu, &lock_context );
> +  return 0;
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
> index 9f79d33c42..1a79369efb 100644
> --- a/testsuites/psxtests/psxtimer02/psxtimer.c
> +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
> @@ -126,6 +126,32 @@ void *POSIX_Init (
>    puts( "timer_delete - bad id - EINVAL" );
>    status = timer_delete( timer );
>    fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> +  puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
> +  status = timer_create( CLOCK_MONOTONIC, &event, NULL );
> +  fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> +  puts( "timer_create (monotonic) - OK" );
> +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
> +  posix_service_failed( status, "timer_create OK" );
> +  puts( "timer_create (monotonic) - too many - EAGAIN" );
> +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
> +  fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> +  clock_gettime( CLOCK_MONOTONIC, &now );
> +  itimer.it_value = now;
> +  itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
> +  puts( "timer_settime (monotonic) - bad itimer value - previous time - EINVAL" );
> +  status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
> +  fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
> +  itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
> +  puts( "timer_settime (monotonic) - bad id - EINVAL" );
> +  status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
> +  fatal_posix_service_status_errno( status, EINVAL, "bad id" );
Please provide updated psxtimer02.scn and report the results for
running rtems-test for at least the sparc/erc32 with sis including the
sptests and psxtests. If you need help how to run rtems-test, consult
the documentation and ask questions.
https://docs.rtems.org/branches/master/user/testing/index.html
>    TEST_END();
>    rtems_test_exit (0);
> 2.32.0
> devel mailing list
> devel at rtems.org
