[PATCH v2] rtems-utils: Change data type definition
Fri Aug 6 05:46:01 UTC 2021
On 6/8/21 6:43 am, Ryan Long wrote:
> Remove typedef of ostream_guard and change datatype of ostream_guards to
> have the namespace in the variable declarations.
>  linkers/rtems-exeinfo.cpp        | 6 ++----
>  tester/covoar/CoverageMapBase.cc | 4 +---
>  tester/covoar/ReportsHtml.cc     | 4 +---
>  tester/covoar/ReportsText.cc     | 4 +---
>  4 files changed, 5 insertions(+), 13 deletions(-)
> diff --git a/linkers/rtems-exeinfo.cpp b/linkers/rtems-exeinfo.cpp
> index c9bf5b6..caae168 100644
> --- a/linkers/rtems-exeinfo.cpp
> +++ b/linkers/rtems-exeinfo.cpp
> @@ -53,8 +53,6 @@
>  #define kill(p,s) raise(s)
>  #endif
> -typedef rtems::utils::ostream_guard ostream_guard;
>  namespace rld
>    namespace exeinfo
> @@ -369,7 +367,7 @@ namespace rld
>        rld::strings all_flags;
> -      ostream_guard old_state( std::cout );
> +      ::rtems::utils::ostream_guard old_state( std::cout );
>        size_t source_max = 0;
> @@ -636,7 +634,7 @@ namespace rld
>      void image::output_tls ()
Why the global namespace prefix, ie `::` at the start? I have only seen this
when referencing a global symbol that is not in a namespace, ie a C call.
