[PATCH] bsps/raspberrypi: Add SEV instruction to Pi SMP
Joel Sherrill
joel at rtems.org
Fri Aug 6 13:54:21 UTC 2021
On Fri, Aug 6, 2021 at 5:11 AM pranav <dangipranav at gmail.com> wrote:
> Add Send Event instruction to get the SMP working on the Pi. Patch
> doesn't work for SMP on Pi 2 v1.1
> bsps/arm/raspberrypi/include/bsp/irq.h | 1 +
> bsps/arm/raspberrypi/start/bspsmp.c | 1 +
> 2 files changed, 2 insertions(+)
> diff --git a/bsps/arm/raspberrypi/include/bsp/irq.h b/bsps/arm/raspberrypi/include/bsp/irq.h
> index a363e7ce90..2c0d0d82b2 100644
> --- a/bsps/arm/raspberrypi/include/bsp/irq.h
> +++ b/bsps/arm/raspberrypi/include/bsp/irq.h
> @@ -24,6 +24,7 @@
> #include <rtems.h>
> #include <rtems/irq.h>
> #include <rtems/irq-extension.h>
> +#include <dev/irq/arm-gic-irq.h>
> * @defgroup raspberrypi_interrupt Interrrupt Support
> diff --git a/bsps/arm/raspberrypi/start/bspsmp.c b/bsps/arm/raspberrypi/start/bspsmp.c
> index 44f7a1d376..9dcfb0fb03 100644
> --- a/bsps/arm/raspberrypi/start/bspsmp.c
> +++ b/bsps/arm/raspberrypi/start/bspsmp.c
> @@ -42,6 +42,7 @@ bool _CPU_SMP_Start_processor( uint32_t cpu_index )
> if (cpu_index != cpu_index_self) {
> BCM2835_REG(BCM2836_MAILBOX_3_WRITE_SET_BASE + 0x10 * cpu_index) = (uint32_t)_start;
> + _ARM_Send_event();
Perhaps a bit pedantic but you didn't add an SEV instruction directly.
You added a call to send an event which is implemented (I guess) as an
SEV instruction.
Subject of patch might be better as something like "add sending event to ..."
and maybe add a comment as to what the send event is intended to convey.
> * Wait for secondary processor to complete its basic initialization so
> 2.30.2
> devel mailing list
> devel at rtems.org
