[PATCH 0/1] testsuites: Add Compile Tests for POSIX Clock APIs
Matt Joyce mfjoyce2004 at gmail.com
Fri Aug 6 20:25:48 UTC 2021
Re-submitting based on recommended edits:
(Defined _GNU_SOURCE, initialized timespec struct, added comment
identifying Issue 8 as the origin of the methods)
Thank you!
Added compile only tests in cpukit/testsuites/psxtests/psxhdrs/pthread
for the following APIs:
1) pthread_cond_clockwait()
2) pthread_mutex_clocklock()
3) pthread_rwlock_clockrdlock()
4) pthread_rwlock_clockwrlock()
All four methods are being added to the Issue 8 POSIX Standard.
Matt Joyce (2):
  testsuites: added compile tests for new APIs
 spec/build/testsuites/psxtests/libpsxhdrs.yml |  4 ++
 .../psxhdrs/pthread/pthread_cond_clockwait.c  | 54 +++++++++++++++++
 .../psxhdrs/pthread/pthread_mutex_clocklock.c | 56 ++++++++++++++++++
 .../pthread/pthread_rwlock_clockrdlock.c      | 59 +++++++++++++++++++
 .../pthread/pthread_rwlock_clockwrlock.c      | 59 +++++++++++++++++++
 5 files changed, 232 insertions(+)
 create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
 create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_mutex_clocklock.c
 create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockrdlock.c
 create mode 100644 testsuites/psxtests/psxhdrs/pthread/pthread_rwlock_clockwrlock.c
2.31.1
