[PATCH v3] Test needed for timer_create with CLOCK_MONOTONIC
Sat Aug 7 15:56:46 UTC 2021
On Fri, Aug 6, 2021 at 11:55 AM zack leung <zakthertemsdev at gmail.com> wrote:
> How do i report the findings of the  psx and  tests?
You can just copy-paste the final part of the log file when you run
rtems-test. Or you can share the full log file as attachment
> Thanks
> Zack
> On Thu, 5 Aug 2021 at 19:23, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Aug 5, 2021 at 12:36 PM Zacchaeus Leung
>> > the timer_create() method can use CLOCK_MONOTONIC but there was  no test for this
>> The commit message needs to be improved, because this patch is doing
>> more than adding a "test", it is implementing the functionality to
>> create a CLOCK_MONOTONIC timer and to gettime() on it.
>> > Closes #3888
>> https://devel.rtems.org/ticket/3888  ??
>> > + if ( rtems_timespec_less_than( &now, &expire ) ) {
>> > +      rtems_timespec_subtract( &now, &expire, &result );
>> > +    } else {
>> > +      result.tv_nsec = 0;
>> > +      result.tv_sec  = 0;
>> The indentation level is wrong in this block.
>> > +  value->it_value = result;
>> > +  value->it_interval = ptimer->timer_data.it_interval;
>> > +  _POSIX_Timer_Release( cpu, &lock_context );
>> > +  return 0;
>> > \ No newline at end of file
>> > diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
>> > index 9f79d33c42..1a79369efb 100644
>> > --- a/testsuites/psxtests/psxtimer02/psxtimer.c
>> > +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
>> > @@ -126,6 +126,32 @@ void *POSIX_Init (
>> >    puts( "timer_delete - bad id - EINVAL" );
>> >    status = timer_delete( timer );
>> >    fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>> > +  puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
>> > +  status = timer_create( CLOCK_MONOTONIC, &event, NULL );
>> > +  fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>> > +  puts( "timer_create (monotonic) - OK" );
>> > +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
>> > +  posix_service_failed( status, "timer_create OK" );
>> > +  puts( "timer_create (monotonic) - too many - EAGAIN" );
>> > +  status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
>> > +  fatal_posix_service_status_errno( status, EAGAIN, "too many" );
>> > +  clock_gettime( CLOCK_MONOTONIC, &now );
>> > +  itimer.it_value = now;
>> > +  itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
>> > +  puts( "timer_settime (monotonic) - bad itimer value - previous time - EINVAL" );
>> > +  status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
>> > +  fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
>> > +  itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
>> > +  puts( "timer_settime (monotonic) - bad id - EINVAL" );
>> > +  status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
>> > +  fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>> Please provide updated psxtimer02.scn and report the results for
>> running rtems-test for at least the sparc/erc32 with sis including the
>> sptests and psxtests. If you need help how to run rtems-test, consult
>> the documentation and ask questions.
>> https://docs.rtems.org/branches/master/user/testing/index.html
>> >    TEST_END();
>> >    rtems_test_exit (0);
>> > 2.32.0
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
