[PATCH rtems-libbsd v3 2/3] rtemsbsd: Add interface support routines
Chris Johns
chrisj at rtems.org
Mon Aug 9 01:21:52 UTC 2021
- Add the ability to check if an interface is up
libbsd.py | 1 +
rtemsbsd/include/rtems/bsd/iface.h | 62 ++++++++++++
rtemsbsd/rtems/rtems-bsd-iface.c | 146 +++++++++++++++++++++++++++++
3 files changed, 209 insertions(+)
create mode 100644 rtemsbsd/include/rtems/bsd/iface.h
create mode 100644 rtemsbsd/rtems/rtems-bsd-iface.c
diff --git a/libbsd.py b/libbsd.py
index 09a1fbc4..6e09a07c 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -253,6 +253,7 @@ class rtems(builder.Module):
'rtems/rtems-bsd-cxx.cc',
'rtems/rtems-bsd-get-ethernet-addr.c',
'rtems/rtems-bsd-ifconfig.c',
+ 'rtems/rtems-bsd-iface.c',
'rtems/rtems-bsd-ifconfig-lo0.c',
'rtems/rtems-bsd-init-dhcp.c',
'rtems/rtems-bsd-rc-conf-net.c',
diff --git a/rtemsbsd/include/rtems/bsd/iface.h b/rtemsbsd/include/rtems/bsd/iface.h
new file mode 100644
index 00000000..9e583b8a
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/iface.h
@@ -0,0 +1,62 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief This file provide a high level interface to simple interface
+ * support calls.
+ * Copyright (c) 2021. Chris Johns <chrisj at rtems.org>. All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _RTEMS_BSD_IFACE_H_
+#define _RTEMS_BSD_IFACE_H_
+#include <stdbool.h>
+#include <sys/socket.h>
+#include <net/if.h>
+#include <net/if_media.h>
+#include <netinet/in.h>
+struct rtems_bsd_iface {
+ char name[IFNAMSIZ];
+ int unit;
+ struct in_addr address;
+ size_t hw_len;
+ uint8_t hw_address[16];
+ struct ifreq ifr;
+ int linkstate;
+ * These calls return 0 is successful and -1 and errno set on error.
+int rtems_bsd_iface_get(const char *name, struct rtems_bsd_iface *iface);
+int rtems_bsd_iface_link_state(const char *name, bool *state);
+#endif
diff --git a/rtemsbsd/rtems/rtems-bsd-iface.c b/rtemsbsd/rtems/rtems-bsd-iface.c
index 00000000..4cf25a9b
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-bsd-iface.c
@@ -0,0 +1,146 @@
+ * @file
+ * @brief Interface support routines
+ * Copyright (c) 2021. Chris Johns <chrisj at rtems.org> All rights reserved.
+ * are met:
+ * SUCH DAMAGE.
+#include <errno.h>
+#include <stdio.h>
+#include <sys/ioctl.h>
+#include <ifaddrs.h>
+#include <net/if_dl.h>
+#include <rtems/bsd/iface.h>
+#if !defined(RTEMS_BSD_IFACE_TRACE)
+#define RTEMS_BSD_IFACE_TRACE 0
+#endif
+int
+rtems_bsd_iface_get(const char *name, struct rtems_bsd_iface *iface)
+ struct ifaddrs *ifap, *ifa;
+ bool found = false;
+ memset(iface, 0, sizeof(*iface));
+ if (getifaddrs(&ifap) != 0) {
+ if (RTEMS_BSD_IFACE_TRACE) {
+ printf("bsd: iface: getifaddrs failed: %s\n", strerror(errno));
+ return -1;
+ for (ifa = ifap; ifa != NULL; ifa = ifa->ifa_next) {
+ if ((ifa->ifa_flags & IFF_LOOPBACK) ||
+ (ifa->ifa_flags & IFF_POINTOPOINT))
+ continue;
+ if (strcmp(name, ifa->ifa_name) != 0)
+ continue;
+ found = true;
+ if (ifa->ifa_addr->sa_family == AF_LINK) {
+ struct sockaddr_dl *sa;
+ sa = (struct sockaddr_dl *)ifa->ifa_addr;
+ iface->unit = sa->sdl_index;
+ iface->hw_len = sa->sdl_alen;
+ memcpy(iface->hw_address, LLADDR(sa), sa->sdl_alen);
+ } else if (ifa->ifa_addr->sa_family == AF_INET) {
+ struct sockaddr_in sa;
+ memcpy(&sa, ifa->ifa_addr, sizeof(sa));
+ if (sa.sin_addr.s_addr == htonl(INADDR_LOOPBACK))
+ continue;
+ strlcpy(iface->ifr.ifr_name, ifa->ifa_name, IFNAMSIZ);
+ memcpy(&iface->ifr.ifr_addr, ifa->ifa_addr,
+ ifa->ifa_addr->sa_len);
+ iface->address = sa.sin_addr;
+ freeifaddrs(ifap);
+ if (!found) {
+ printf("bsd: iface: not-found: %s\n", name);
+ return -1;
+ strlcpy(iface->name, name, sizeof(iface->name));
+ return 0;
+int
+rtems_bsd_iface_link_state(const char *name, bool *state)
+ struct rtems_bsd_iface iface;
+ struct ifmediareq ifmr;
+ int s;
+ int rc;
+ *state = false;
+ rc = rtems_bsd_iface_get(name, &iface);
+ if (rc < 0) {
+ return -1;
+ s = socket(iface.ifr.ifr_addr.sa_family, SOCK_DGRAM, 0);
+ if (s < 0) {
+ printf("bsd: iface: link state: socket open failed: %s\n", strerror(errno));
+ return -1;
+ memset(&ifmr, 0, sizeof(ifmr));
+ strlcpy(ifmr.ifm_name, name, sizeof(ifmr.ifm_name));
+ rc = ioctl(s, SIOCGIFMEDIA, (caddr_t)&ifmr);
+ close(s);
+ if (rc < 0) {
+ printf("bsd: iface: link state: socket ioctl failed: %s\n", strerror(errno));
+ return -1;
+ if ((ifmr.ifm_status & IFM_AVALID) != 0) {
+ *state = (ifmr.ifm_status & IFM_ACTIVE) != 0;
+ return 0;
2.24.1
