[PATCH rtems-libbsd v3 2/3] rtemsbsd: Add interface support routines
Chris Johns
chrisj at rtems.org
Tue Aug 10 02:09:43 UTC 2021
On 10/8/21 1:50 am, Gedare Bloom wrote:
> On Sun, Aug 8, 2021 at 7:22 PM Chris Johns <chrisj at rtems.org> wrote:
>> - Add the ability to check if an interface is up
>> libbsd.py | 1 +
>> rtemsbsd/include/rtems/bsd/iface.h | 62 ++++++++++++
>> rtemsbsd/rtems/rtems-bsd-iface.c | 146 +++++++++++++++++++++++++++++
>> 3 files changed, 209 insertions(+)
>> create mode 100644 rtemsbsd/include/rtems/bsd/iface.h
>> create mode 100644 rtemsbsd/rtems/rtems-bsd-iface.c
>> diff --git a/libbsd.py b/libbsd.py
>> index 09a1fbc4..6e09a07c 100644
>> --- a/libbsd.py
>> +++ b/libbsd.py
>> @@ -253,6 +253,7 @@ class rtems(builder.Module):
>> 'rtems/rtems-bsd-cxx.cc',
>> 'rtems/rtems-bsd-get-ethernet-addr.c',
>> 'rtems/rtems-bsd-ifconfig.c',
>> + 'rtems/rtems-bsd-iface.c',
>> 'rtems/rtems-bsd-ifconfig-lo0.c',
>> 'rtems/rtems-bsd-init-dhcp.c',
>> 'rtems/rtems-bsd-rc-conf-net.c',
>> diff --git a/rtemsbsd/include/rtems/bsd/iface.h b/rtemsbsd/include/rtems/bsd/iface.h
>> new file mode 100644
>> index 00000000..9e583b8a
>> --- /dev/null
>> +++ b/rtemsbsd/include/rtems/bsd/iface.h
>> @@ -0,0 +1,62 @@
>> + * @file
>> + * @ingroup rtems_bsd_rtems
>> + * @brief This file provide a high level interface to simple interface
>> + * support calls.
>> + * Copyright (c) 2021. Chris Johns <chrisj at rtems.org>. All rights reserved.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> +#ifndef _RTEMS_BSD_IFACE_H_
>> +#define _RTEMS_BSD_IFACE_H_
>> +#include <stdbool.h>
>> +#include <sys/socket.h>
>> +#include <net/if.h>
>> +#include <net/if_media.h>
>> +#include <netinet/in.h>
>> +struct rtems_bsd_iface {
>> + char name[IFNAMSIZ];
>> + int unit;
>> + struct in_addr address;
>> + size_t hw_len;
>> + uint8_t hw_address[16];
>> + struct ifreq ifr;
>> + int linkstate;
>> + * These calls return 0 is successful and -1 and errno set on error.
>> +int rtems_bsd_iface_get(const char *name, struct rtems_bsd_iface *iface);
>> +int rtems_bsd_iface_link_state(const char *name, bool *state);
>> +#endif
>> diff --git a/rtemsbsd/rtems/rtems-bsd-iface.c b/rtemsbsd/rtems/rtems-bsd-iface.c
>> index 00000000..4cf25a9b
>> --- /dev/null
>> +++ b/rtemsbsd/rtems/rtems-bsd-iface.c
>> @@ -0,0 +1,146 @@
>> + * @file
>> + * @brief Interface support routines
>> + * Copyright (c) 2021. Chris Johns <chrisj at rtems.org> All rights reserved.
>> + * are met:
>> + * SUCH DAMAGE.
>> +#include <errno.h>
>> +#include <stdio.h>
>> +#include <sys/ioctl.h>
>> +#include <ifaddrs.h>
>> +#include <net/if_dl.h>
>> +#include <rtems/bsd/iface.h>
>> +#if !defined(RTEMS_BSD_IFACE_TRACE)
>> +#define RTEMS_BSD_IFACE_TRACE 0
>> +#endif
>> +int
>> +rtems_bsd_iface_get(const char *name, struct rtems_bsd_iface *iface)
>> + struct ifaddrs *ifap, *ifa;
>> + bool found = false;
>> + memset(iface, 0, sizeof(*iface));
> Should you validate arguments? (iface != NULL at least?)
Sure.
>> + if (getifaddrs(&ifap) != 0) {
>> + if (RTEMS_BSD_IFACE_TRACE) {
>> + printf("bsd: iface: getifaddrs failed: %s\n", strerror(errno));
>> + return -1;
>> + for (ifa = ifap; ifa != NULL; ifa = ifa->ifa_next) {
>> + if ((ifa->ifa_flags & IFF_LOOPBACK) ||
>> + (ifa->ifa_flags & IFF_POINTOPOINT))
>> + continue;
>> + if (strcmp(name, ifa->ifa_name) != 0)
>> + continue;
>> + found = true;
>> + if (ifa->ifa_addr->sa_family == AF_LINK) {
>> + struct sockaddr_dl *sa;
>> + sa = (struct sockaddr_dl *)ifa->ifa_addr;
>> + iface->unit = sa->sdl_index;
>> + iface->hw_len = sa->sdl_alen;
>> + memcpy(iface->hw_address, LLADDR(sa), sa->sdl_alen);
>> + } else if (ifa->ifa_addr->sa_family == AF_INET) {
>> + struct sockaddr_in sa;
>> + memcpy(&sa, ifa->ifa_addr, sizeof(sa));
>> + if (sa.sin_addr.s_addr == htonl(INADDR_LOOPBACK))
>> + continue;
>> + strlcpy(iface->ifr.ifr_name, ifa->ifa_name, IFNAMSIZ);
>> + memcpy(&iface->ifr.ifr_addr, ifa->ifa_addr,
>> + ifa->ifa_addr->sa_len);
>> + iface->address = sa.sin_addr;
>> + freeifaddrs(ifap);
>> + if (!found) {
>> + printf("bsd: iface: not-found: %s\n", name);
> This failure case won't set an errno, should it?
>> + return -1;
>> + strlcpy(iface->name, name, sizeof(iface->name));
> If name is larger than the iface->name buffer, then the name gets
> truncated, does this matter to the caller?
>> + return 0;
>> +int
>> +rtems_bsd_iface_link_state(const char *name, bool *state)
>> + struct rtems_bsd_iface iface;
>> + struct ifmediareq ifmr;
>> + int s;
>> + int rc;
>> + *state = false;
>> + rc = rtems_bsd_iface_get(name, &iface);
>> + if (rc < 0) {
> errno?
Already set so being passed back.
>> + return -1;
>> + s = socket(iface.ifr.ifr_addr.sa_family, SOCK_DGRAM, 0);
>> + if (s < 0) {
>> + printf("bsd: iface: link state: socket open failed: %s\n", strerror(errno));
>> + return -1;
>> + memset(&ifmr, 0, sizeof(ifmr));
>> + strlcpy(ifmr.ifm_name, name, sizeof(ifmr.ifm_name));
> Care if the name is truncated?
Not really. If there is an interface that is at the limits then we can revisit
this. :)
>> + rc = ioctl(s, SIOCGIFMEDIA, (caddr_t)&ifmr);
>> + close(s);
> The indentation alignment looks wrong.
Yeah, something happened.
