Having a problem with an out of the box setup for STM32F4
Mr. Andrei Chichak
groups at chichak.ca
Tue Aug 10 03:27:05 UTC 2021
In an attempt to make some progress, I’ve gone back to trying to install RTEMS6 built for STM32F4. Should be straight forward.
To make things clean, I don’t do any modifications to any of the code being pulled out of git.
I followed the Quick Start section of the RTEMS User Manual, Release 6 efb8e7c
1)
mkdir -p $HOME/quick-start/src
cd $HOME/quick-start/src
git clone git://git.rtems.org/rtems-source-builder.git <git://git.rtems.org/rtems-source-builder.git> rsb
git clone git://git.rtems.org/rtems.git <git://git.rtems.org/rtems.git>
It looks good here.
2)
cd $HOME/quick-start/src/rsb/rtems
../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 6/rtems-arm
It looks good here too.
3)
$HOME/quick-start/rtems/6/bin/arm-rtems6-gcc --version
This gives me:
arm-rtems6-gcc (GCC) 10.3.1 20210409 (RTEMS 6, RSB ec495e091743061d4e140e2d0bd8aab1a8d69ae7, Newlib 0c0f3df)
Copyright (C) 2020 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
4)
../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 --target=arm-rtems6 --with-rtems-bsp=stm32f4 --with-rtems-tests=yes 6/rtems-kernel
Gives me:
RTEMS Source Builder - Set Builder, 6 (ec495e091743)
Build Set: 6/rtems-kernel
config: tools/rtems-kernel-6.cfg
package: arm-rtems6-kernel-stm32f4-1
download: https://git.rtems.org/rtems/snapshot/rtems-3ec5f20484cc4201e1d7b87844505644533b6148.tar.bz2 <https://git.rtems.org/rtems/snapshot/rtems-3ec5f20484cc4201e1d7b87844505644533b6148.tar.bz2> -> sources/rtems-kernel-3ec5f20484cc4201e1d7b87844505644533b6148.tar.bz2
downloading: sources/rtems-kernel-3ec5f20484cc4201e1d7b87844505644533b6148.tar.bz2 - 8.1MB
building: arm-rtems6-kernel-stm32f4-1
error: building arm-rtems6-kernel-stm32f4-1
Build FAILED
See error report: rsb-report-arm-rtems6-kernel-stm32f4-1.txt
Build Set: Time 0:03:03.592335
Build FAILED
Inside of rsb-report-arm-rtems6-kernel-stm32f4-1.txt the compiles are bombing with :
/Users/andreichichak/quick-start/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: ./../../cpukit/librtemscpu.a(armv7m-context-initialize.o): in function `_CPU_Context_Initialize':
/Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-kernel-stm32f4-1/arm-rtems6-kernel-stm32f4-1-3ec5f20484cc4201e1d7b87844505644533b6148/build/arm-rtems6/c/stm32f4/cpukit/../../../../../rtems-3ec5f20484cc4201e1d7b87844505644533b6148/c/src/../../cpukit/score/cpu/arm/armv7m-context-initialize.c:53: undefined reference to `_TLS_Alignment'
/Users/andreichichak/quick-start/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-kernel-stm32f4-1/arm-rtems6-kernel-stm32f4-1-3ec5f20484cc4201e1d7b87844505644533b6148/build/arm-rtems6/c/stm32f4/cpukit/../../../../../rtems-3ec5f20484cc4201e1d7b87844505644533b6148/c/src/../../cpukit/score/cpu/arm/armv7m-context-initialize.c:53: undefined reference to `_TLS_Size'
/Users/andreichichak/quick-start/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-kernel-stm32f4-1/arm-rtems6-kernel-stm32f4-1-3ec5f20484cc4201e1d7b87844505644533b6148/build/arm-rtems6/c/stm32f4/cpukit/../../../../../rtems-3ec5f20484cc4201e1d7b87844505644533b6148/c/src/../../cpukit/score/cpu/arm/armv7m-context-initialize.c:53: undefined reference to `_TLS_Data_begin'
/Users/andreichichak/quick-start/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-kernel-stm32f4-1/arm-rtems6-kernel-stm32f4-1-3ec5f20484cc4201e1d7b87844505644533b6148/build/arm-rtems6/c/stm32f4/cpukit/../../../../../rtems-3ec5f20484cc4201e1d7b87844505644533b6148/c/src/../../cpukit/score/cpu/arm/armv7m-context-initialize.c:53: undefined reference to `_TLS_Data_size'
/Users/andreichichak/quick-start/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-kernel-stm32f4-1/arm-rtems6-kernel-stm32f4-1-3ec5f20484cc4201e1d7b87844505644533b6148/build/arm-rtems6/c/stm32f4/cpukit/../../../../../rtems-3ec5f20484cc4201e1d7b87844505644533b6148/c/src/../../cpukit/score/cpu/arm/armv7m-context-initialize.c:53: undefined reference to `_TLS_BSS_begin'
/Users/andreichichak/quick-start/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /Users/andreichichak/quick-start/src/rsb/rtems/build/arm-rtems6-kernel-stm32f4-1/arm-rtems6-kernel-stm32f4-1-3ec5f20484cc4201e1d7b87844505644533b6148/build/arm-rtems6/c/stm32f4/cpukit/../../../../../rtems-3ec5f20484cc4201e1d7b87844505644533b6148/c/src/../../cpukit/score/cpu/arm/armv7m-context-initialize.c:53: undefined reference to `_TLS_BSS_size'
/Users/andreichichak/quick-start/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000008018
If I compile with tests turned off, the set builder succeeds and I get a BSP that I can compile against, but a hello program compile bombs with the same missing symbols.
Am I missing some unobvious git command? Is the stm32f4 BSP not converted for 6?
Thank you in advance, I can send the complete log files if it would help.
Andrei (from The Great White North)
Andrei Chichak
Systems Developer
CBF Systems Inc.
225 College Plaza
8215 112 Street.
EDMONTON, ALBERTA
T6G 2C8
CANADA
Phone: 780-628-2072
Skype: andrei.chichak
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210809/01bb64f1/attachment.html>
