[PATCH 2/2] score: Replace the single use of a sequence lock
Tue Aug 10 14:47:59 UTC 2021
ok
On Tue, Aug 10, 2021 at 8:34 AM Sebastian Huber
> In SMP configurations, on 64-bit architectures use plain atomic
> operations to set/get the priority value of a scheduler node.  On 32-bit
> architectures use an ISR lock.  Using a sequence lock has no real
> benefit since it uses atomic read-modify-write operations for both the
> read and the write lock.  Simply use a ticket lock instead so that only
> one SMP synchronization primitive is used for everything.
>  cpukit/include/rtems/score/schedulernode.h    | 14 ++--
>  .../include/rtems/score/schedulernodeimpl.h   | 64 +++++++++++++------
>  .../score/src/schedulerdefaultnodedestroy.c   |  4 +-
>  3 files changed, 57 insertions(+), 25 deletions(-)
> diff --git a/cpukit/include/rtems/score/schedulernode.h b/cpukit/include/rtems/score/schedulernode.h
> index 1dba200dca..e344479718 100644
> --- a/cpukit/include/rtems/score/schedulernode.h
> +++ b/cpukit/include/rtems/score/schedulernode.h
> @@ -28,7 +28,7 @@
>  #include <rtems/score/basedefs.h>
>  #include <rtems/score/chain.h>
>  #include <rtems/score/priority.h>
> -#include <rtems/score/smplockseq.h>
> +#include <rtems/score/isrlock.h>
>   * @addtogroup RTEMSScoreScheduler
> @@ -197,14 +197,20 @@ struct Scheduler_Node {
>       * least-significant bit which indicates if the thread should be appended
>       * (bit set) or prepended (bit cleared) to its priority group, see
>       * SCHEDULER_PRIORITY_APPEND().
> +     * @see _Scheduler_Node_get_priority() and _Scheduler_Node_set_priority().
> +#if defined(RTEMS_SMP) && CPU_SIZEOF_POINTER == 8
> +    Atomic_Ulong value;
> +#else
>      Priority_Control value;
> +#endif
> -#if defined(RTEMS_SMP)
> +#if defined(RTEMS_SMP) && CPU_SIZEOF_POINTER != 8
> -     * @brief Sequence lock to synchronize priority value updates.
> +     * @brief The lock protects the priority value.
> -    SMP_sequence_lock_Control Lock;
> +    ISR_lock_Control Lock;
>  #endif
>    } Priority;
> diff --git a/cpukit/include/rtems/score/schedulernodeimpl.h b/cpukit/include/rtems/score/schedulernodeimpl.h
> index 3da29bb37e..3f90d4a6f5 100644
> --- a/cpukit/include/rtems/score/schedulernodeimpl.h
> +++ b/cpukit/include/rtems/score/schedulernodeimpl.h
> @@ -100,13 +100,36 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Node_do_initialize(
>    node->Wait.Priority.scheduler = scheduler;
>    node->user = the_thread;
>    node->idle = NULL;
> -  _SMP_sequence_lock_Initialize( &node->Priority.Lock );
> +#if CPU_SIZEOF_POINTER != 8
> +  _ISR_lock_Initialize( &node->Priority.Lock, "Scheduler Node Priority" );
> +#endif
>  #else
>    (void) scheduler;
>    (void) the_thread;
>  #endif
> + * @brief Destroys a node.
> + * @param scheduler is the scheduler of the node.
> + * @param[in, out] node is the node to destroy.
> +RTEMS_INLINE_ROUTINE void _Scheduler_Node_do_destroy(
> +  const struct _Scheduler_Control *scheduler,
> +  Scheduler_Node                  *node
> +  (void) scheduler;
> +  _ISR_lock_Destroy( &node->Priority.Lock );
> +#else
> +  (void) node;
> +#endif
>   * @brief Gets the scheduler of the node.
> @@ -148,17 +171,18 @@ RTEMS_INLINE_ROUTINE Priority_Control _Scheduler_Node_get_priority(
>    Priority_Control priority;
> -  unsigned int     seq;
> -  do {
> -    seq = _SMP_sequence_lock_Read_begin( &node->Priority.Lock );
> -#endif
> -    priority = node->Priority.value;
> +  priority = _Atomic_Fetch_add_ulong(
> +    &node->Priority.value,
> +    0,
> +    ATOMIC_ORDER_RELAXED
> +#else
> +  ISR_lock_Context lock_context;
> -  } while ( _SMP_sequence_lock_Read_retry( &node->Priority.Lock, seq ) );
> +  _ISR_lock_Acquire( &node->Priority.Lock, &lock_context );
> +  priority = node->Priority.value;
> +  _ISR_lock_Release( &node->Priority.Lock, &lock_context );
>  #endif
>    return priority;
> @@ -180,16 +204,18 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Node_set_priority(
>    Priority_Flags    flags
> -  unsigned int seq;
> -  seq = _SMP_sequence_lock_Write_begin( &node->Priority.Lock );
> -#endif
> +  _Atomic_Store_ulong(
> +    new_priority | (Priority_Control) flags,
> +#else
>    node->Priority.value = new_priority | ( (Priority_Control) flags );
> -  _SMP_sequence_lock_Write_end( &node->Priority.Lock, seq );
>  #endif
> diff --git a/cpukit/score/src/schedulerdefaultnodedestroy.c b/cpukit/score/src/schedulerdefaultnodedestroy.c
> index 796896d854..33cdfd4c69 100644
> --- a/cpukit/score/src/schedulerdefaultnodedestroy.c
> +++ b/cpukit/score/src/schedulerdefaultnodedestroy.c
> @@ -21,12 +21,12 @@
>  #endif
>  #include <rtems/score/scheduler.h>
> +#include <rtems/score/schedulernodeimpl.h>
>  void _Scheduler_default_Node_destroy(
>    const Scheduler_Control *scheduler,
> -  (void) scheduler;
> -  (void) node;
> +  _Scheduler_Node_do_destroy( scheduler, node );
> 2.26.2
> devel mailing list
> devel at rtems.org
