GSoC - Code Formatting and Style Checking for RTEMS score
Ida Delphine idadelm at gmail.com
Tue Aug 10 21:21:12 UTC 2021
Hi everyone,
I was able to successfully build LLVM from source using "ninja" instead of
"make" after a couple of failed attempts because I kept running out of
resources.
Is there anything else I am supposed to do as far building LLVM is
concerned? Or will every user first have to clone the llvm repo and build
it from source like I did?
On Fri, 16 Jul 2021, 5:28 am Chris Johns, <chrisj at rtems.org> wrote:
> Hi,
> I will bring the discussion to the devel list and I hope the comments are
> in
> line with the purpose of the project. Please correct what I say if it is
> not.
> The pre-commit script that is in github review is a good base and I
> believe it
> solves that problem for those on Linux. It is a great start and it is nice
> to see.
> The work needs to mature and progress and that means a few things. I was
> approached by Joel about where this would live in rtems-tools. As the
> script
> stands it is not suitable for rtems-tool because the format is specific to
> the
> score code in rtems.git.
> I think a pre-commit script needs to live in the repo it is for in a spot
> a user
> can copy to the hooks directory of their repo. For example `git-hooks`.
> A git hooks script for rtems.git needs to run on all the supported hosts
> or we
> may result in patches being left on the floor. If a contributor's host OS
> is not
> supported and the patch is rejected for formatting reasons picked up by the
> check the contributor may just walk away.
> The script should use `/usr/bin/env python3` and it needs to check for a
> range
> of `clang-format` instances. FreeBSD has a package that installs the format
> command as `clang-format10` for LLVM 10 and `clang-format11` for version
> 11.
> A contributor being able to run the script may depend on the host having a
> package or packages installed. Given this is for RTEMS development that is
> fine.
> The script needs to handle any set up errors nicely if something is
> missing. I
> prefer we avoid the "experts" approach to error management.
> There is possible future work adding a command to rtems-tools. Ida and I
> discussed this on discord and we decided a command called `rtems-style`
> would be
> nice. It would be nice if that command checked, ie `--mode=check`, a style
> as
> well as `--mode=reformat` to automatically reformat a source file.
> A command for rtems-tools has to support python2 and python3 and it has to
> handle errors in suitable manner. Printing uncaught exception is not OK. It
> should also be self contained and not depend on any pip python packages.
> If an `rtems-style` command is created and installed when rtems-tool is
> installed the pre-commit git script could be made to use it and so the
> style is
> held in a single location.
> Finally an rtems-style command could be extended to support python
> (--lang=python) or other styles for other code formats. This is inline
> with our
> other eco-system interfaces we provide.
> I hope this helps.
> Chris
> On 16/7/21 5:13 am, Ida Delphine wrote:
> > I will check on this
> > On Thu, Jul 15, 2021 at 3:39 PM Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>> wrote:
> >     On Thu, Jul 15, 2021 at 5:19 AM Ida Delphine <idadelm at gmail.com
> >     <mailto:idadelm at gmail.com>> wrote:
> >     > Hello everyone,
> >     > From the discussion on discord it looks like clang-format cannot be
> >     installed on MacOS and FreeBSD. Is there any alternative or way to
> have it
> >     on these operating systems?
> >     What are the challenges with them? Can clang-format be built from
> >     source on those hosts?
> >     > On Wed, 5 May 2021, 10:21 pm Ida Delphine, <idadelm at gmail.com
> >     >> Hello everyone,
> >     >> Regarding this project (https://devel.rtems.org/ticket/3860
> >     <https://devel.rtems.org/ticket/3860>) I went with clang-format as
> we all
> >     agreed. I have tested it on some "score" files and it made some
> changes
> >     which I don't think are very much in line with the RTEMS coding
> style.
> >     However, it wasn't really clear if we will chage the RTEMS coding
> style or
> >     try to make changes to clang-format to fit the style.
> >     >> Please will love to know the best option.
> >     >> Cheers,
> >     >> Ida.
> >     > _______________________________________________
> >     > devel mailing list
> >     > devel at rtems.org <mailto:devel at rtems.org>
> >     > http://lists.rtems.org/mailman/listinfo/devel
> >     <http://lists.rtems.org/mailman/listinfo/devel>
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210810/b0384d76/attachment.html>
