GSOC 2021: USB Device Drivers - Beaglebone Black
Ahamed Husni ahamedhusni73 at gmail.com
Wed Aug 11 12:22:15 UTC 2021
Hello Kevin,
I'm working on porting the CDC Serial device driver to beagle.
(RTEMS is the device and Linux as host)
I see you have ported USB Serial drivers some time back.
I hope that you can help me clear my doubts.
In your case how did you use a USB Serial adapter and how did you start a
shell
on that device?
Do USB Serial adapters need special handling?
I used the umodem driver with the usb modem template.
Isn't umodem for host and device?
Linux host: sees a ttyACM0 and serial programs can open it.
RTEMS device: ttyU0 and cuaU0 devices are created. (But can't communicate.)
ttyU0.lock, ttyU0.init, cuaU0, ... files are also there.
What do these files do?
Github branch: https://github.com/drac98/rtems-libbsd/commits/usb-serial
If someone can help me out with any clue that'll be really helpful.
Best regards,
Husni.
On Sat, Jul 24, 2021 at 3:32 PM Ahamed Husni <ahamedhusni73 at gmail.com>
wrote:
> Hi all,
> In phase one of the GSoC I ported the usb template driver and the CDC
> Ethernet template (Template for Ethernet over USB) to the RTEMS LibBSD. The
> driver was tested in the 6-freebsd-12 and the master branch. I have
> prepared a report for phase one.
> https://drac98.github.io/2021/07/13/gsoc-2021-mid-report.html
> RTEMS LibBSD doesn't have any documentation in the RTEMS Documentation
> Project. So I documented the driver by creating a frame for the LibBSD.
> Please have a look and give me your feedback.
> https://github.com/drac98/rtems-docs/commits/libbsd
> I'm working on TTCP benchmarking for the USB Ethernet.
> For phase two first I'll port the USB Serial template.
> Thank you,
> Husni.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210811/6ea935fe/attachment.html>
