[PATCH] GcovData.cc: Fix out-of-bounds access errors
Ryan Long
ryan.long at oarcorp.com
Thu Aug 12 13:54:12 UTC 2021
Would you need to check if length < sizeof(gcov_preamble) since length is assigned that value?
-----Original Message-----
Sent: Wednesday, August 11, 2021 11:13 AM
To: Ryan Long <ryan.long at oarcorp.com>
Cc: devel at rtems.org
Subject: Re: [PATCH] GcovData.cc: Fix out-of-bounds access errors
On Wed, Aug 11, 2021 at 8:06 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> Adjusted number of bytes to be read
> CID 1506208: Out-of-bounds access
> CID 1506209: Out-of-bounds access
> Closes #4485
> tester/covoar/GcovData.cc | 6 +++---
> 1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/tester/covoar/GcovData.cc b/tester/covoar/GcovData.cc
> index 02e7489..da0cc2a 100644
> --- a/tester/covoar/GcovData.cc
> +++ b/tester/covoar/GcovData.cc
> @@ -129,7 +129,7 @@ namespace Gcov {
> preamble.timestamp = gcnoPreamble.timestamp;
> //Write preamble
> - gcdaFile.write( (char *) &preamble , 4 * sizeof( preamble ) );
> + gcdaFile.write( (char *) &preamble , sizeof( preamble ) );
> if ( gcdaFile.fail() ) {
> std::cerr << "Error while writing gcda preamble to a file "
> << gcdaFileName << std::endl; @@ -402,8 +402,8 @@
> namespace Gcov {
> int length;
> length = sizeof( gcov_preamble );
> - gcovFile.read( (char *) &preamble, 4 * sizeof( gcov_preamble ) );
> - if ( gcovFile.gcount() != 4 * sizeof( gcov_preamble ) ) {
> + gcovFile.read( (char *) &preamble, length );
Does something ensure that sizeof(preamble) < length?
regardless, the patch looks like an improvement, go ahead.
> + if ( gcovFile.gcount() != length ) {
> std::cerr << "Error while reading file preamble" << std::endl;
> return -1;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
