[PATCH v2] score: Replace priority prepend it with an enum
Sebastian Huber
Thu Aug 12 14:25:53 UTC 2021
Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
v2:
Rename Priority_Flags in Priority_Group_order.
cpukit/include/rtems/posix/muteximpl.h | 2 +-
cpukit/include/rtems/score/coremuteximpl.h | 2 +-
cpukit/include/rtems/score/priorityimpl.h | 44 ++++++++++++++-----
cpukit/include/rtems/score/schedulerimpl.h | 12 ++++-
.../include/rtems/score/schedulernodeimpl.h | 30 ++++++-------
cpukit/include/rtems/score/threadimpl.h | 20 +++++----
cpukit/posix/src/pthreadsetschedparam.c | 2 +-
cpukit/posix/src/pthreadsetschedprio.c | 2 +-
cpukit/rtems/src/tasksetpriority.c | 2 +-
cpukit/score/src/scheduleredfreleasejob.c | 2 +-
cpukit/score/src/threadchangepriority.c | 39 +++++++++-------
cpukit/score/src/threadqops.c | 18 ++++----
cpukit/score/src/threadrestart.c | 4 +-
testsuites/smptests/smpscheduler03/test.c | 33 +++++++-------
14 files changed, 126 insertions(+), 86 deletions(-)
diff --git a/cpukit/include/rtems/posix/muteximpl.h b/cpukit/include/rtems/posix/muteximpl.h
index 435b43634d..5d20bc1ef6 100644
--- a/cpukit/include/rtems/posix/muteximpl.h
+++ b/cpukit/include/rtems/posix/muteximpl.h
@@ -273,7 +273,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Mutex_Set_priority(
owner,
&the_mutex->Priority_ceiling,
priority_ceiling,
- false,
+ PRIORITY_GROUP_LAST,
queue_context
_Thread_Wait_release( owner, queue_context );
diff --git a/cpukit/include/rtems/score/coremuteximpl.h b/cpukit/include/rtems/score/coremuteximpl.h
index cbc1e720fb..426c4c5a95 100644
--- a/cpukit/include/rtems/score/coremuteximpl.h
+++ b/cpukit/include/rtems/score/coremuteximpl.h
@@ -375,7 +375,7 @@ RTEMS_INLINE_ROUTINE void _CORE_ceiling_mutex_Set_priority(
owner,
priority_ceiling,
- false,
queue_context
diff --git a/cpukit/include/rtems/score/priorityimpl.h b/cpukit/include/rtems/score/priorityimpl.h
index 7a14ec97b8..2895a0c4a5 100644
--- a/cpukit/include/rtems/score/priorityimpl.h
+++ b/cpukit/include/rtems/score/priorityimpl.h
@@ -37,6 +37,29 @@ extern "C" {
+ * @brief The priority group order determines if a priority node is inserted
+ * as the first or last node into its priority group.
+ * The values of the enumerators matter. The least significant bit of a
+ * ::Priority_Control value is not used for the actual priority of a node.
+ * During insertion the least significant bit is used to determine the
+ * ordering within a priority group based on the enumerator values.
+typedef enum {
+ * @brief Priority group first option requests that the priority node is
+ * inserted as the first node into its priority group.
+ PRIORITY_GROUP_FIRST = 0,
+ * @brief Priority group last option requests that the priority node is
+ * inserted as the last node into its priority group.
+ PRIORITY_GROUP_LAST = 1
+} Priority_Group_order;
* @brief Initializes the priority actions empty.
@@ -465,7 +488,7 @@ typedef void ( *Priority_Add_handler )(
typedef void ( *Priority_Change_handler )(
Priority_Aggregation *aggregation,
- bool prepend_it,
+ Priority_Group_order group_order,
Priority_Actions *actions,
void *arg
@@ -482,19 +505,19 @@ typedef void ( *Priority_Remove_handler )(
* This method does nothing.
* @param aggregation Is ignored by the method.
- * @param prepend_it Is ignored by the method.
+ * @param group_order Is ignored by the method.
* @param actions Is ignored by the method.
* @param arg Is ignored by the method.
RTEMS_INLINE_ROUTINE void _Priority_Change_nothing(
- bool prepend_it,
void *arg
(void) aggregation;
- (void) prepend_it;
+ (void) group_order;
(void) actions;
(void) arg;
@@ -547,7 +570,7 @@ RTEMS_INLINE_ROUTINE void _Priority_Non_empty_insert(
if ( is_new_minimum ) {
aggregation->Node.priority = node->priority;
- ( *change )( aggregation, false, actions, arg );
+ ( *change )( aggregation, PRIORITY_GROUP_LAST, actions, arg );
@@ -619,7 +642,7 @@ RTEMS_INLINE_ROUTINE void _Priority_Extract(
if ( node->priority < min->priority ) {
aggregation->Node.priority = min->priority;
- ( *change )( aggregation, true, actions, arg );
+ ( *change )( aggregation, PRIORITY_GROUP_FIRST, actions, arg );
@@ -654,7 +677,7 @@ RTEMS_INLINE_ROUTINE void _Priority_Extract_non_empty(
@@ -666,8 +689,7 @@ RTEMS_INLINE_ROUTINE void _Priority_Extract_non_empty(
* @param[in, out] aggregation The aggregation to change the node in.
* @param node The node that has a new priority and will be reinserted in the aggregation.
- * @param prepend_it Indicates whether @a change should prepend if the minimal priority is
- * incorrectly set after the change.
+ * @param group_order The priority group order which may be used by @ change.
* @param actions The actions for the case that the minimal priority is incorrectly set
* after the change.
* @param change Is called if the minimal priority is incorrectly set after the change.
@@ -676,7 +698,7 @@ RTEMS_INLINE_ROUTINE void _Priority_Extract_non_empty(
RTEMS_INLINE_ROUTINE void _Priority_Changed(
Priority_Node *node,
- bool prepend_it,
Priority_Change_handler change,
void *arg
@@ -695,7 +717,7 @@ RTEMS_INLINE_ROUTINE void _Priority_Changed(
if ( min->priority != aggregation->Node.priority ) {
- ( *change )( aggregation, prepend_it, actions, arg );
+ ( *change )( aggregation, group_order, actions, arg );
diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
index 595d6291b4..24db4d7818 100644
--- a/cpukit/include/rtems/score/schedulerimpl.h
+++ b/cpukit/include/rtems/score/schedulerimpl.h
@@ -1388,7 +1388,11 @@ RTEMS_INLINE_ROUTINE Status_Control _Scheduler_Set(
&new_scheduler_node->Thread.Scheduler_node.Chain
- _Scheduler_Node_set_priority( new_scheduler_node, priority, false );
+ _Scheduler_Node_set_priority(
+ new_scheduler_node,
+ priority,
if ( _States_Is_ready( current_state ) ) {
_Scheduler_Unblock( the_thread );
@@ -1398,7 +1402,11 @@ RTEMS_INLINE_ROUTINE Status_Control _Scheduler_Set(
#endif
+ priority,
_Scheduler_Update_priority( the_thread );
return STATUS_SUCCESSFUL;
diff --git a/cpukit/include/rtems/score/schedulernodeimpl.h b/cpukit/include/rtems/score/schedulernodeimpl.h
index 5d6f795912..9b5c632d86 100644
--- a/cpukit/include/rtems/score/schedulernodeimpl.h
+++ b/cpukit/include/rtems/score/schedulernodeimpl.h
@@ -46,12 +46,6 @@ extern "C" {
#define SCHEDULER_NODE_OF_WAIT_PRIORITY( node ) \
RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority )
- * @brief Priority append indicator for the priority control used for the
- * scheduler node priority.
-#define SCHEDULER_PRIORITY_APPEND_FLAG 1
* @brief Maps a priority value to support the append indicator.
@@ -66,13 +60,13 @@ extern "C" {
* @brief Clears the priority append indicator bit.
#define SCHEDULER_PRIORITY_PURIFY( priority ) \
- ( ( priority ) & ~( (Priority_Control) SCHEDULER_PRIORITY_APPEND_FLAG ) )
+ ( ( priority ) & ~( (Priority_Control) PRIORITY_GROUP_LAST ) )
* @brief Returns the priority control with the append indicator bit set.
#define SCHEDULER_PRIORITY_APPEND( priority ) \
- ( ( priority ) | SCHEDULER_PRIORITY_APPEND_FLAG )
+ ( ( priority ) | ( (Priority_Control) PRIORITY_GROUP_LAST ) )
* @brief Returns true, if the item should be appended to its priority group,
@@ -80,7 +74,7 @@ extern "C" {
* group.
#define SCHEDULER_PRIORITY_IS_APPEND( priority ) \
- ( ( ( priority ) & SCHEDULER_PRIORITY_APPEND_FLAG ) != 0 )
+ ( ( ( priority ) & ( (Priority_Control) PRIORITY_GROUP_LAST ) ) != 0 )
* @brief Initializes a node.
@@ -173,14 +167,17 @@ RTEMS_INLINE_ROUTINE Priority_Control _Scheduler_Node_get_priority(
* @brief Sets the priority of the node.
- * @param[in, out] node The node to set the priority of.
- * @param new_priority The new priority for @a node.
- * @param prepend_it Indicates whether the new priority should be prepended.
+ * @param[in, out] node is the scheduler node.
+ * @param new_priority is the priority to set.
+ * @param group_order is the priority group order, see #PRIORITY_GROUP_FIRST
+ * and #PRIORITY_GROUP_LAST.
RTEMS_INLINE_ROUTINE void _Scheduler_Node_set_priority(
- Scheduler_Node *node,
- Priority_Control new_priority,
- bool prepend_it
+ Scheduler_Node *node,
+ Priority_Control new_priority,
#if defined(RTEMS_SMP)
@@ -189,8 +186,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Node_set_priority(
seq = _SMP_sequence_lock_Write_begin( &node->Priority.Lock );
#endif
- new_priority |= ( prepend_it ? 0 : SCHEDULER_PRIORITY_APPEND_FLAG );
- node->Priority.value = new_priority;
+ node->Priority.value = new_priority | ( (Priority_Control) group_order );
_SMP_sequence_lock_Write_end( &node->Priority.Lock, seq );
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index ecc8eee058..c4b6c941a4 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -691,9 +691,10 @@ void _Thread_Priority_remove(
* @param the_thread The thread.
* @param[out] priority_node The thread priority node to change.
- * @param prepend_it In case this is true, then the thread is prepended to
- * its priority group in its home scheduler instance, otherwise it is
- * appended.
+ * @param priority_group_order The priority group order determines if the
+ * thread is inserted as the first or last node into the ready or scheduled
+ * queues of its home scheduler, see #PRIORITY_GROUP_FIRST and
+ * #PRIORITY_GROUP_LAST.
* @param queue_context The thread queue context to return an updated set of
* threads for _Thread_Priority_update(). The thread queue context must be
* initialized via _Thread_queue_Context_clear_priority_updates() before a
@@ -704,7 +705,7 @@ void _Thread_Priority_remove(
void _Thread_Priority_changed(
Thread_Control *the_thread,
Priority_Node *priority_node,
- bool prepend_it,
+ Priority_Group_order priority_group_order,
Thread_queue_Context *queue_context
@@ -718,9 +719,10 @@ void _Thread_Priority_changed(
* @param new_priority The new thread priority value of the thread priority
* node to change.
- * appended.
@@ -732,7 +734,7 @@ RTEMS_INLINE_ROUTINE void _Thread_Priority_change(
- bool prepend_it,
@@ -740,7 +742,7 @@ RTEMS_INLINE_ROUTINE void _Thread_Priority_change(
the_thread,
priority_node,
- prepend_it,
+ priority_group_order,
queue_context
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index e9be24b417..1c207e7887 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -96,7 +96,7 @@ static int _POSIX_Set_sched_param(
the_thread,
&the_thread->Real_priority,
- false,
queue_context
#if defined(RTEMS_POSIX_API)
diff --git a/cpukit/posix/src/pthreadsetschedprio.c b/cpukit/posix/src/pthreadsetschedprio.c
index 72c7dab273..ae2add6232 100644
--- a/cpukit/posix/src/pthreadsetschedprio.c
+++ b/cpukit/posix/src/pthreadsetschedprio.c
@@ -49,7 +49,7 @@ int pthread_setschedprio( pthread_t thread, int prio )
the_thread,
new_priority,
- true,
+ PRIORITY_GROUP_FIRST,
&queue_context
diff --git a/cpukit/rtems/src/tasksetpriority.c b/cpukit/rtems/src/tasksetpriority.c
index 50d1bc156c..532848ea52 100644
--- a/cpukit/rtems/src/tasksetpriority.c
+++ b/cpukit/rtems/src/tasksetpriority.c
@@ -50,7 +50,7 @@ static rtems_status_code _RTEMS_tasks_Set_priority(
the_thread,
core_new_priority,
- false,
queue_context
cpu_self = _Thread_queue_Dispatch_disable( queue_context );
diff --git a/cpukit/score/src/scheduleredfreleasejob.c b/cpukit/score/src/scheduleredfreleasejob.c
index 443fdaeed5..4cccffc952 100644
--- a/cpukit/score/src/scheduleredfreleasejob.c
+++ b/cpukit/score/src/scheduleredfreleasejob.c
@@ -66,7 +66,7 @@ void _Scheduler_EDF_Release_job(
the_thread,
priority_node,
- false,
queue_context
} else {
diff --git a/cpukit/score/src/threadchangepriority.c b/cpukit/score/src/threadchangepriority.c
index 13e9147916..ac2e9a6d0c 100644
--- a/cpukit/score/src/threadchangepriority.c
+++ b/cpukit/score/src/threadchangepriority.c
@@ -31,13 +31,13 @@
static void _Thread_Set_scheduler_node_priority(
Priority_Aggregation *priority_aggregation,
- bool prepend_it
SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE( priority_aggregation ),
_Priority_Get_priority( priority_aggregation ),
- prepend_it
@@ -55,7 +55,10 @@ static void _Thread_Priority_action_add(
the_thread = arg;
_Thread_Scheduler_add_wait_node( the_thread, scheduler_node );
- _Thread_Set_scheduler_node_priority( priority_aggregation, false );
+ _Thread_Set_scheduler_node_priority(
+ priority_aggregation,
_Priority_Set_action_type( priority_aggregation, PRIORITY_ACTION_ADD );
_Priority_Actions_add( priority_actions, priority_aggregation );
@@ -73,7 +76,10 @@ static void _Thread_Priority_action_remove(
the_thread = arg;
_Thread_Scheduler_remove_wait_node( the_thread, scheduler_node );
- _Thread_Set_scheduler_node_priority( priority_aggregation, true );
_Priority_Set_action_type( priority_aggregation, PRIORITY_ACTION_REMOVE );
@@ -81,12 +87,15 @@ static void _Thread_Priority_action_remove(
static void _Thread_Priority_action_change(
- bool prepend_it,
Priority_Actions *priority_actions,
void *arg
- _Thread_Set_scheduler_node_priority( priority_aggregation, prepend_it );
#if defined(RTEMS_SMP) || defined(RTEMS_DEBUG)
_Priority_Set_action_type( priority_aggregation, PRIORITY_ACTION_CHANGE );
#endif
@@ -97,7 +106,7 @@ static void _Thread_Priority_do_perform_actions(
Thread_queue_Queue *queue,
const Thread_queue_Operations *operations,
- bool prepend_it,
@@ -162,7 +171,7 @@ static void _Thread_Priority_do_perform_actions(
_Priority_Changed(
priority_action_node,
- prepend_it,
&queue_context->Priority.Actions,
_Thread_Priority_action_change,
NULL
@@ -214,7 +223,7 @@ void _Thread_Priority_perform_actions(
the_thread,
queue,
the_thread->Wait.operations,
- false,
queue_context
@@ -244,7 +253,7 @@ static void _Thread_Priority_apply(
Priority_Node *priority_action_node,
Thread_queue_Context *queue_context,
- bool prepend_it,
Priority_Action_type priority_action_type
@@ -263,7 +272,7 @@ static void _Thread_Priority_apply(
the_thread,
queue,
- prepend_it,
queue_context
@@ -288,7 +297,7 @@ void _Thread_Priority_add(
the_thread,
priority_node,
queue_context,
- false,
PRIORITY_ACTION_ADD
@@ -303,7 +312,7 @@ void _Thread_Priority_remove(
the_thread,
priority_node,
queue_context,
- true,
@@ -311,7 +320,7 @@ void _Thread_Priority_remove(
- bool prepend_it,
@@ -319,7 +328,7 @@ void _Thread_Priority_changed(
the_thread,
priority_node,
queue_context,
- prepend_it,
diff --git a/cpukit/score/src/threadqops.c b/cpukit/score/src/threadqops.c
index d6ba9dad57..eb01002679 100644
--- a/cpukit/score/src/threadqops.c
+++ b/cpukit/score/src/threadqops.c
@@ -700,7 +700,7 @@ static void _Thread_queue_Priority_inherit_do_priority_actions_remove(
static void _Thread_queue_Priority_inherit_do_priority_actions_change(
- bool prepend_it,
void *arg
@@ -787,7 +787,7 @@ static void _Thread_queue_Priority_inherit_priority_actions(
_Priority_Changed(
&priority_queue->Queue,
&scheduler_node->Wait.Priority.Node,
- false,
priority_actions,
_Thread_queue_Priority_inherit_do_priority_actions_change,
scheduler_node_of_owner
@@ -884,7 +884,7 @@ static void _Thread_queue_Priority_inherit_do_initialize(
static void _Thread_queue_Priority_inherit_do_enqueue_change(
- bool prepend_it,
void *arg
@@ -1079,7 +1079,7 @@ static void _Thread_queue_Priority_inherit_do_extract_remove(
static void _Thread_queue_Priority_inherit_do_extract_change(
- bool prepend_it,
void *arg
@@ -1231,7 +1231,7 @@ static void _Thread_queue_Priority_inherit_do_surrender_add(
scheduler_node,
- false
@@ -1254,7 +1254,7 @@ static void _Thread_queue_Priority_inherit_do_surrender_remove(
static void _Thread_queue_Priority_inherit_do_surrender_change(
- bool prepend_it,
void *arg
@@ -1270,14 +1270,14 @@ static void _Thread_queue_Priority_inherit_do_surrender_change(
SCHEDULER_NODE_OF_WAIT_PRIORITY( priority_aggregation ),
- prepend_it
static void _Thread_queue_Priority_inherit_do_surrender_change_2(
- bool prepend_it,
void *arg
@@ -1285,7 +1285,7 @@ static void _Thread_queue_Priority_inherit_do_surrender_change_2(
- prepend_it
#endif
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 79a154e3d3..4b1907a2d9 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -70,7 +70,7 @@ static void _Thread_Raise_real_priority(
the_thread,
priority,
- false,
&queue_context
@@ -576,7 +576,7 @@ Status_Control _Thread_Restart(
the_thread,
the_thread->Start.initial_priority,
- false,
&queue_context
_Thread_Wait_release( the_thread, &queue_context );
diff --git a/testsuites/smptests/smpscheduler03/test.c b/testsuites/smptests/smpscheduler03/test.c
index 3f6b9e3fd8..8411f3ca2c 100644
--- a/testsuites/smptests/smpscheduler03/test.c
+++ b/testsuites/smptests/smpscheduler03/test.c
@@ -33,7 +33,7 @@ static Scheduler_SMP_Node *get_scheduler_node(Thread_Control *thread)
static void apply_priority(
Thread_Control *thread,
- bool prepend_it,
@@ -49,7 +49,7 @@ static void apply_priority(
thread,
&thread->Real_priority,
new_priority,
- prepend_it,
queue_context
_Thread_Wait_release(thread, queue_context);
@@ -58,12 +58,12 @@ static void apply_priority(
static void change_priority(
- bool prepend_it
Thread_queue_Context queue_context;
- apply_priority(thread, new_priority, prepend_it, &queue_context);
+ apply_priority(thread, new_priority, priority_group_order, &queue_context);
_Thread_Priority_update(&queue_context);
@@ -110,7 +110,7 @@ static void test_case_change_priority(
Scheduler_SMP_Node *executing_node,
Scheduler_SMP_Node_state start_state,
Priority_Control prio,
- bool prepend_it,
Scheduler_SMP_Node_state new_state
@@ -131,7 +131,7 @@ static void test_case_change_priority(
rtems_test_assert(executing_node->state == start_state);
- change_priority(executing, prio, prepend_it);
+ change_priority(executing, prio, priority_group_order);
rtems_test_assert(executing_node->state == new_state);
change_priority(executing, 1, true);
@@ -147,7 +147,10 @@ static const Scheduler_SMP_Node_state states[2] = {
static const Priority_Control priorities[2] = { 2, 5 };
-static const bool prepend_it[2] = { true, false };
+static const Priority_Group_order priority_group_order[2] = {
static void test_change_priority(void)
@@ -165,13 +168,13 @@ static void test_change_priority(void)
for (i = 0; i < RTEMS_ARRAY_SIZE(states); ++i) {
for (j = 0; j < RTEMS_ARRAY_SIZE(priorities); ++j) {
- for (k = 0; k < RTEMS_ARRAY_SIZE(prepend_it); ++k) {
+ for (k = 0; k < RTEMS_ARRAY_SIZE(priority_group_order); ++k) {
executing,
executing_node,
states[i],
priorities[j],
- prepend_it[k],
+ priority_group_order[k],
states[j]
@@ -186,7 +189,7 @@ static void update_priority_op(
Scheduler_SMP_Node *scheduler_node,
- bool prepend_it
const Scheduler_Control *scheduler;
@@ -194,7 +197,7 @@ static void update_priority_op(
ISR_lock_Context scheduler_lock_context;
_Thread_State_acquire( thread, &state_lock_context );
scheduler = _Thread_Scheduler_get_home( thread );
@@ -216,7 +219,7 @@ static void test_case_update_priority_op(
Thread_Control *other,
- bool prepend_it,
@@ -237,7 +240,7 @@ static void test_case_update_priority_op(
- update_priority_op(executing, executing_node, prio, prepend_it);
+ update_priority_op(executing, executing_node, prio, priority_group_order);
if (start_state != new_state) {
@@ -279,14 +282,14 @@ static void test_update_priority_op(void)
executing,
executing_node,
other,
states[i],
priorities[j],
- prepend_it[k],
states[j]
2.26.2
