[PATCH rtems-libbsd] ppp: Fix transmitting data
Gedare Bloom
gedare at rtems.org
Thu Aug 12 17:45:34 UTC 2021
looks ok, but hold until chris pushes his big patches through I think.
(Not that it should conflict, but I think it will be better this way.)
On Thu, Aug 12, 2021 at 5:42 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> The pppstart expected that a driver write would somehow magically
> process all data passed to the write function. Because ppp disables all
> buffering that originally has been in termios, that assumption is not
> true for all but polled drivers.
> With this patch, the pppstart now gets and processes the feedback that
> is returned from the driver via rtems_termios_dequeue_characters.
> Fixes #4493
> rtemsbsd/sys/net/if_ppp.c | 11 ++++++-----
> rtemsbsd/sys/net/if_pppvar.h | 1 +
> rtemsbsd/sys/net/ppp_tty.c | 32 ++++++++++++++++++++++++++++----
> 3 files changed, 35 insertions(+), 9 deletions(-)
> diff --git a/rtemsbsd/sys/net/if_ppp.c b/rtemsbsd/sys/net/if_ppp.c
> index 709f13e04..e134dc760 100644
> --- a/rtemsbsd/sys/net/if_ppp.c
> +++ b/rtemsbsd/sys/net/if_ppp.c
> @@ -313,11 +313,12 @@ static rtems_task ppp_txdaemon(rtems_task_argument arg)
> frag=0;
> /* initialize output values */
> - sc->sc_outfcs = PPP_INITFCS;
> - sc->sc_outbuf = (u_char *)0;
> - sc->sc_outlen = (short )0;
> - sc->sc_outoff = (short )0;
> - sc->sc_outfcslen = (short )0;
> + sc->sc_outfcs = PPP_INITFCS;
> + sc->sc_outbuf = (u_char *)0;
> + sc->sc_outlen = (short )0;
> + sc->sc_outoff = (short )0;
> + sc->sc_outoff_update = false;
> + sc->sc_outfcslen = (short )0;
> /* printf("Start Transmit Packet..\n"); */
> diff --git a/rtemsbsd/sys/net/if_pppvar.h b/rtemsbsd/sys/net/if_pppvar.h
> index fdfb56df0..bd11bcbc4 100644
> --- a/rtemsbsd/sys/net/if_pppvar.h
> +++ b/rtemsbsd/sys/net/if_pppvar.h
> @@ -117,6 +117,7 @@ struct ppp_softc {
> struct ifqueue sc_freeq; /* free packets */
> short sc_outoff; /* output packet byte offset */
> + bool sc_outoff_update; /* outoff needs update in pppstart */
> short sc_outflag; /* output status flag */
> short sc_outlen; /* length of output packet */
> short sc_outfcslen; /* length of output fcs data */
> diff --git a/rtemsbsd/sys/net/ppp_tty.c b/rtemsbsd/sys/net/ppp_tty.c
> index 80d4fee16..2e850dc77 100644
> --- a/rtemsbsd/sys/net/ppp_tty.c
> +++ b/rtemsbsd/sys/net/ppp_tty.c
> @@ -124,7 +124,7 @@ int pppread(struct rtems_termios_tty *tty, rtems_libio_rw_args_t *rw_args);
> int pppwrite(struct rtems_termios_tty *tty, rtems_libio_rw_args_t *rw_args);
> int ppptioctl(struct rtems_termios_tty *tty, rtems_libio_ioctl_args_t *args);
> int pppinput(int c, struct rtems_termios_tty *tty);
> -int pppstart(struct rtems_termios_tty *tp);
> +int pppstart(struct rtems_termios_tty *tp, int len);
> u_short pppfcs(u_short fcs, u_char *cp, int len);
> void pppallocmbuf(struct ppp_softc *sc, struct mbuf **mp);
> @@ -557,7 +557,7 @@ pppasyncctlp(
> * Called at spltty or higher.
> int
> -pppstart(struct rtems_termios_tty *tp)
> +pppstart(struct rtems_termios_tty *tp, int len)
> u_char *sendBegin;
> u_long ioffset = (u_long )0;
> @@ -567,6 +567,13 @@ pppstart(struct rtems_termios_tty *tp)
> /* ensure input is valid and we are busy */
> if (( sc != NULL ) && ( sc->sc_outflag & SC_TX_BUSY )) {
> + /* Adapt offsets if necessary */
> + if ( sc->sc_outoff_update ) {
> + sc->sc_stats.ppp_obytes += len;
> + sc->sc_outoff += len;
> /* check to see if we need to get the next buffer */
> /* Ready with PPP_FLAG Character ? */
> @@ -644,8 +651,25 @@ pppstart(struct rtems_termios_tty *tp)
> /* write out the character(s) and update the stats */
> (*tp->handler.write)(ctx, (char *)sendBegin, (ioffset > 0) ? ioffset : 1);
> - sc->sc_stats.ppp_obytes += (ioffset > 0) ? ioffset : 1;
> - sc->sc_outoff += ioffset;
> + * In case of polled drivers, everything is sent here. So adapt the
> + * offsets. In case of interrupt or task driven drivers, we don't know
> + * whether all characters have been sent. We only get feedback via
> + * rtems_termios_dequeue_characters() function which is the one that is
> + * calling us.
> + if (tp->handler.mode == TERMIOS_POLLED) {
> + sc->sc_stats.ppp_obytes += (ioffset > 0) ? ioffset : 1;
> + sc->sc_outoff += ioffset;
> + } else {
> + if (ioffset > 0) {
> + sc->sc_outoff_update = true;
> + } else {
> + sc->sc_stats.ppp_obytes += 1;
> return (0);
> 2.31.1
> devel mailing list
> devel at rtems.org
