[PATCH rtems 2/2] termios: Pass number of sent chars to l_start
Thu Aug 12 17:46:30 UTC 2021
This is fine, but should do some testing on a few BSPs if you can.
On Thu, Aug 12, 2021 at 5:42 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> At the moment the line discipline start function (l_start) has no
> possibility to get feedback about the number of characters that have
> been sent. This patch passes that information via an additional
> parameter.
> The change might trigger a warning on existing code because of a pointer
> mismatch but it shouldn't break it. An existing function with the old
> API will just ignore the additional parameter.
> Update #4493
>  cpukit/include/rtems/termiostypes.h | 6 +++++-
>  cpukit/libcsupport/src/termios.c    | 5 +++--
>  2 files changed, 8 insertions(+), 3 deletions(-)
> diff --git a/cpukit/include/rtems/termiostypes.h b/cpukit/include/rtems/termiostypes.h
> index ef2c958271..5821d52775 100644
> --- a/cpukit/include/rtems/termiostypes.h
> +++ b/cpukit/include/rtems/termiostypes.h
> @@ -367,6 +367,10 @@ typedef struct rtems_termios_tty {
>    rtems_id                rxTaskId;
>    rtems_id                txTaskId;
> +   * Information for the tx task how many characters have been dequeued.
> +  int                     txTaskCharsDequeued;
>     * line discipline related stuff
> @@ -482,7 +486,7 @@ struct rtems_termios_linesw {
>    int (*l_read )(struct rtems_termios_tty *tp,rtems_libio_rw_args_t *args);
>    int (*l_write)(struct rtems_termios_tty *tp,rtems_libio_rw_args_t *args);
>    int (*l_rint )(int c,struct rtems_termios_tty *tp);
> -  int (*l_start)(struct rtems_termios_tty *tp);
> +  int (*l_start)(struct rtems_termios_tty *tp,int len);
>    int (*l_ioctl)(struct rtems_termios_tty *tp,rtems_libio_ioctl_args_t *args);
>    int (*l_modem)(struct rtems_termios_tty *tp,int flags);
> diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
> index 829c2bf158..4a4a7e77ac 100644
> --- a/cpukit/libcsupport/src/termios.c
> +++ b/cpukit/libcsupport/src/termios.c
> @@ -1969,6 +1969,7 @@ rtems_termios_dequeue_characters (void *ttyp, int len)
>       * send wake up to transmitter task
> +    tty->txTaskCharsDequeued = len;
>      sc = rtems_event_send(tty->txTaskId, TERMIOS_TX_START_EVENT);
>      if (sc != RTEMS_SUCCESSFUL)
>        rtems_fatal_error_occurred (sc);
> @@ -1980,7 +1981,7 @@ rtems_termios_dequeue_characters (void *ttyp, int len)
>       * call PPP line discipline start function
>      if (rtems_termios_linesw[tty->t_line].l_start != NULL) {
> -      rtems_termios_linesw[tty->t_line].l_start(tty);
> +      rtems_termios_linesw[tty->t_line].l_start(tty, len);
>      return 0; /* nothing to output in IRQ... */
> @@ -2015,7 +2016,7 @@ static rtems_task rtems_termios_txdaemon(rtems_task_argument argument)
>       * call any line discipline start function
> +      rtems_termios_linesw[tty->t_line].l_start(tty, tty->txTaskCharsDequeued);
>        if (tty->t_line == PPPDISC) {
> 2.31.1
> devel mailing list
> devel at rtems.org
