[PATCH rtems-libbsd] ppp: Fix transmitting data
Chris Johns
chrisj at rtems.org
Fri Aug 13 08:01:07 UTC 2021
On 13/8/21 5:22 pm, Christian MAUDERER wrote:
> Hello Chris,
> Am 13.08.21 um 04:46 schrieb Chris Johns:
>> On 12/8/21 9:42 pm, Christian Mauderer wrote:
>>> The pppstart expected that a driver write would somehow magically
>>> process all data passed to the write function. Because ppp disables all
>>> buffering that originally has been in termios, that assumption is not
>>> true for all but polled drivers.
>>> With this patch, the pppstart now gets and processes the feedback that
>>> is returned from the driver via rtems_termios_dequeue_characters.
>>> Fixes #4493
>>> rtemsbsd/sys/net/if_ppp.c | 11 ++++++-----
>>> rtemsbsd/sys/net/if_pppvar.h | 1 +
>>> rtemsbsd/sys/net/ppp_tty.c | 32 ++++++++++++++++++++++++++++----
>>> 3 files changed, 35 insertions(+), 9 deletions(-)
>>> diff --git a/rtemsbsd/sys/net/if_ppp.c b/rtemsbsd/sys/net/if_ppp.c
>>> index 709f13e04..e134dc760 100644
>>> --- a/rtemsbsd/sys/net/if_ppp.c
>>> +++ b/rtemsbsd/sys/net/if_ppp.c
>>> @@ -313,11 +313,12 @@ static rtems_task ppp_txdaemon(rtems_task_argument arg)
>>> frag=0;
>>> /* initialize output values */
>>> - sc->sc_outfcs = PPP_INITFCS;
>>> - sc->sc_outbuf = (u_char *)0;
>>> - sc->sc_outlen = (short )0;
>>> - sc->sc_outoff = (short )0;
>>> - sc->sc_outfcslen = (short )0;
>>> + sc->sc_outfcs = PPP_INITFCS;
>>> + sc->sc_outbuf = (u_char *)0;
>>> + sc->sc_outlen = (short )0;
>>> + sc->sc_outoff = (short )0;
>>> + sc->sc_outoff_update = false;
>>> + sc->sc_outfcslen = (short )0;
>> This is not the FreeBSD clang-format. Once my changes are pushed you can use the
>> style to reformat this code.
> I touched only a small part of the file and therefore I adapted to the style in
> that file (also it's a bit messy).
Ah ok and yes we are sort of all over the place.
> If we want the code in the ppp parts
> reformatted, I would suggest an extra patch that applies the coding style to the
> complete file. What do you think?
I have only just learnt about this requirement and I think it is a good one. I
am no expert on what is the FreeBSd format so I can only highlight what I have
observed after reformatting my code.
I think it would be good to have a single pass to clean this up but it is
painful because it breaks blame. So I do not know and happy to see what everyone
else thinks.
