Xilinx Zynq console rx not working
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Aug 13 14:40:37 UTC 2021
On 8/13/2021 03:05, Chris Johns wrote:
> Hi,
> I am bring up a major app on RTEMS 6 and LibBSD on custom Zynq hardware and I am
> not getting any receive interrupts from the console UART. The same hardware
> works with RTEMS 4.11 and RTEMS 5.
> I also do not see any console input with qemu and I thought this was something
> in qemu but I am now not so sure.
> Anyone else seeing this issue?
> There has been a lot of playing with the Zynq UART driver recently.
I just went through and backed out all those changes you mentioned back
to when the polled-only driver was split out and I still don't have
functionality on Zynq under QEMU. Testing using fileio.exe, things are
partially functional until I revert the change that enabled
set_attributes. After the commit that enables set_attributes for the
zynq UART, fileio produces output waiting for user input and will accept
the first character to open the menu, but accepts no further input.
Before that commit, the fileio test doesn't produce the expected output.
A full bisect would probably provide more accurate results, but this is
what I could do quickly.
Note that ZynqMP fileio works on QEMU with current code and is fully
operational. It is almost certainly the exact same emulated peripheral
in QEMU and the hardware is supposed to be very close if not identical
as well.
Kinsey
