Xilinx Zynq console rx not working
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Aug 16 13:03:05 UTC 2021
On 8/16/2021 04:45, Chris Johns wrote:
> On 16/8/21 6:38 pm, Chris Johns wrote:
>> I have taken a closer look at the driver. I am receiving RX
>> interrupts and the
>> characters are being queued however the receive FIFO trigger interrupt is only
>> raised when the FIFO reaches the set threshold of half the FIFO size. I suspect
>> there is an assumption the RX timeout will fire but it is not.
> Doing this is questionable ....
> https://git.rtems.org/rtems/tree/bsps/shared/dev/serial/zynq-uart.c#n222
> You cannot send a character when touching the attributes. Where is this hardware
> bug documented by Xilinx?
The attributes are done being touched and the TX/RX enable flags are set
again before sending the character. I was seeing the same behavior on
Zynq QEMU even with this code removed.
I couldn't find the hardware bug documented anywhere, but out of the 3
ZynqMP boards I have one requires this consistently.
> My application does this ...
> if (tcgetattr(fileno(stdout), &term) < 0)
> error_message();
> cfsetispeed (&term, B115200);
> cfsetospeed (&term, B115200);
> if (tcsetattr (fileno(stdout), TCSADRAIN, &term) < 0)
> error_message();
> if (tcgetattr(fileno(stdin), &term) < 0)
> error_message();
> if (tcsetattr (fileno(stdin), TCSADRAIN, &term) < 0)
> error_message();
> and this kills the receive interrupts.
Does removing the null character kick restore functionality for you in
this case?
Kinsey
