RTEMS Tools on 5 release can't be build with modern LLVM
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Aug 16 15:17:26 UTC 2021
Am 16.08.21 um 17:12 schrieb Joel Sherrill:
> On Mon, Aug 16, 2021 at 10:08 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de> wrote:
>> Hello Joel,
>> Am 16.08.21 um 17:03 schrieb Joel Sherrill:
>>> On Mon, Aug 16, 2021 at 9:49 AM Christian MAUDERER
>>>> Hello,
>>>> I noted that I can't build the RTEMS 5 toolchain if I have a modern LLVM
>>>> installed using the RTEMS source builder. Therefore I would like to
>>>> backport the patch 37ad446d9dce3 ([1]) to the 5 branch. Is that OK? If
>>>> someone acknowledges it, I would do the following steps without further
>>>> review (but of course with testing):
>>>> 1. Create a ticket for the problem.
>>>> 2. In rtems-tools: Cherry pick the patch 37ad446d9dce3 to the 5 branch.
>>>> 3. In rtems-source-builder: Backport the patch 91932d0a0 [2] to the 5
>>>> branch (or rather re-create it because it will be a different commit and
>>>> a different hash).
>>> I'm ok with this. I remember doing a patch for the opposite direction.
>>> I couldn't
>>> build on an older gcc because it assumed a different language version as
>>> default. gcc 4.8 as on CentOS 7 assumes C++03. Newer versions assume C++11
>>> as the base. Similarly newer gcc's seem to default to C11.
>> Thanks. I'll wait a bit more before adding the patches in case someone
>> else want's to object.
> Good plan.
>>> I posted a few weeks ago that users should really be careful to always use
>>> -std and consciously pick what they want.
>> In this case, the version of the standard depends quite a lot on the
>> LLVM headers. LLVM seems to love using new features.
> Then this is probably not the first time we will face this.
Definitively not. It is only a backport of a patch so I had that problem
already on another system. I only missed to add it to the 5 branch back
then.
Best regards
Christian
> --joel
>> Best regards
>> Christian
>>> --joel
>>>> Best regards
>>>> Christian
>>>> [1]
>>>> https://git.rtems.org/rtems-tools/commit/?id=37ad446d9dce3438d6d32e1caf56d3fdccdd2ad0
>>>> [2]
>>>> https://git.rtems.org/rtems-source-builder/commit/?id=91932d0a0c86400366f9c75a62123b6488ff458a
>>>> embedded brains GmbH
>>>> Herr Christian MAUDERER
>>>> Dornierstr. 4
>>>> 82178 Puchheim
>>>> Germany
>>>> email: christian.mauderer at embedded-brains.de
>>>> phone: +49-89-18 94 741 - 18
>>>> fax: +49-89-18 94 741 - 08
>>>> Registergericht: Amtsgericht München
>>>> Registernummer: HRB 157899
>>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>>> Unsere Datenschutzerklärung finden Sie hier:
>>>> https://embedded-brains.de/datenschutzerklaerung/
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
Dornierstr. 4
82178 Puchheim
Germany
