[PATCH rtems-tools 2/2] misc: Add rtems-style command
Ida Delphine
idadelm at gmail.com
Mon Aug 16 22:13:38 UTC 2021
Signed-off-by: Ida Delphine <idadelm at gmail.com>
This command helps to check for style issues or reformat code given a file
or directory. There are 4 flags:
* -c, --check : Checks for style issues
* -r, --reformat : Reformats the code
* -p, --path : Path to file or dir to be checked or reformatted
* -i, --ignore : Files to be ignored when checking or reformatting
* -v, --verbose : Produces a more detailed output.
misc/rtems-style | 16 +++++
misc/tools/style.py | 144 ++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 160 insertions(+)
create mode 100644 misc/rtems-style
create mode 100644 misc/tools/style.py
diff --git a/misc/rtems-style b/misc/rtems-style
new file mode 100644
index 0000000..5a3e0e8
--- /dev/null
+++ b/misc/rtems-style
@@ -0,0 +1,16 @@
+#! /usr/bin/env python
+from __future__ import print_function
+import sys, os
+base = os.path.dirname(os.path.dirname(os.path.abspath(sys.argv[0])))
+rtems = os.path.join(base, 'share', 'rtems')
+sys.path = sys.path[0:1] + [rtems, base] + sys.path[1:]
+try:
+ import misc.tools.style
+ misc.tools.style.run()
+except ImportError:
+ print("Incorrect RTEMS Tools installation", file = sys.stderr)
+ sys.exit(1)
\ No newline at end of file
diff --git a/misc/tools/style.py b/misc/tools/style.py
index 0000000..a101146
--- /dev/null
+++ b/misc/tools/style.py
@@ -0,0 +1,144 @@
+import argparse
+import os
+import sys
+import re
+from rtemstoolkit import execute
+from rtemstoolkit import git
+def get_command():
+ from rtemstoolkit import check
+ for version in ['', '8', '9', '10', '11']:
+ if check.check_exe(None, 'clang-format' + version):
+ command = 'clang-format' + version
+ return command
+ print("Clang-format not found in your system")
+ sys.exit(1)
+def arguments():
+ parser = argparse.ArgumentParser(description="Tool for code formatting and style checking \
+ for RTEMS")
+ parser.add_argument("-c", "--check", dest="check", help="Check for style differences and \
+ report the number of issues if found", action="store_true")
+ parser.add_argument("-r", "--reformat", dest="reformat", help="Reformat the file/directory \
+ with any style differences found", action="store_true")
+ parser.add_argument("-p", "--path", dest="path", help="The path to be checked for style issues \
+ or reformatted")
+ parser.add_argument("--ignore", dest="ignore", help="Ignore files to be checked or reformatted")
+ parser.add_argument("-v", "--verbose", dest="verbose", help="A more detailed outline of the \
+ style issues", action='store_true')
+ return [parser.parse_args(), parser.print_usage()]
+def get_diff(path, ignore_file=None):
+ diff = ""
+ ex = execute.capture_execution()
+ def clang_to_git_diff(clang_output, path):
+ import os
+ import tempfile
+ fd, tmp_path = tempfile.mkstemp()
+ try:
+ with os.fdopen(fd, 'w') as tmp:
+ tmp.write(clang_output)
+ repo = git.repo(".")
+ return repo.diff(['--no-index', path, tmp_path])
+ finally:
+ os.remove(tmp_path)
+ if os.path.isfile(path) == True:
+ cmd = get_command() + " --style=file " + path
+ output_clang = ex.command(command=cmd, shell=True)
+ output_clang = output_clang[2]
+ diff = clang_to_git_diff(output_clang, path)
+ else:
+ onlyfiles = [f for f in os.listdir(path)]
+ for file in onlyfiles:
+ file = os.path.join(path, file)
+ if ignore_file is not None and file == ignore_file:
+ continue
+ if file.endswith('.c') or file.endswith('.h'):
+ cmd = get_command() + " --style=file " + file
+ diff += clang_to_git_diff(output_clang, os.path.join(path, file))
+ return diff
+def color_text(string, col, style=1):
+ return f"\033[{style};{col};{col}m{string}\033[0;0m"
+def handle_errors(path, output, verbose=False,):
+ if len(output) < 1:
+ print("Everything is clean - No style issues")
+ else:
+ print(color_text("Checking for style differences...", 34, style=3))
+ out = output.split('\n')
+ files = []
+ num_diff = 0
+ for line in out:
+ if line.startswith("---"):
+ file = str(re.sub('^---\s[ab]', '', line))
+ files.append(file)
+ elif line.startswith('+'):
+ num_diff += 1
+ if verbose == True:
+ print(color_text(line, 34))
+ continue
+ print(line)
+ print(color_text("\nFiles affected:", 33))
+ for file in files:
+ print(file)
+ message = "\nStyleWarning: You have about a total of " + str(num_diff) + \
+ " style issue(s) in the " + str(len(files)) + " file(s) listed above"
+ print(color_text(message, 31))
+def reformat(path, output):
+ if len(output) > 0:
+ cmd = get_command() + " -i -style=file " + os.path.join(path, file)
+ ex.command(command=cmd, shell=True)
+ else:
+ print("Everything is clean. No style issues")
+ return 0
+def run(args = sys.argv):
+ args = arguments()
+ if os.path.exists(args[0].path) == False:
+ print("Please enter a correct path!!")
+ sys.exit(1)
+ output = get_diff(args[0].path)
+ if args[0].check == True:
+ handle_errors(args[0].path, output, verbose=args[0].verbose)
+ elif args[0].reformat == True:
+ reformat(args[0].path, output)
+ else:
+ args[1]
+ sys.exit(1)
+if __name__ == "__main__":
+ run()
2.25.1
