[PATCH rtems] arm/xilinx: Fix zynq-uart interrupt receive
    chrisj at rtems.org
    chrisj at rtems.org
    Tue Aug 17 08:39:14 UTC 2021
- Trigger on a single character entering the RX FIFO
- Disable the RX timeout
- Send up to a FIFO full of data
 bsps/include/dev/serial/zynq-uart.h       |  1 +
 bsps/shared/dev/serial/zynq-uart-polled.c | 18 ++-----
 bsps/shared/dev/serial/zynq-uart.c        | 66 +++++++++++------------
 3 files changed, 36 insertions(+), 49 deletions(-)
diff --git a/bsps/include/dev/serial/zynq-uart.h b/bsps/include/dev/serial/zynq-uart.h
index 220d9b7717..b21e16f6de 100644
--- a/bsps/include/dev/serial/zynq-uart.h
+++ b/bsps/include/dev/serial/zynq-uart.h
@@ -52,6 +52,7 @@ extern "C" {
 typedef struct {
   rtems_termios_device_context base;
   volatile struct zynq_uart *regs;
+  int tx_queued;
   bool transmitting;
   rtems_vector_number irq;
 } zynq_uart_context;
diff --git a/bsps/shared/dev/serial/zynq-uart-polled.c b/bsps/shared/dev/serial/zynq-uart-polled.c
index 95c51dea11..201d9070d3 100644
--- a/bsps/shared/dev/serial/zynq-uart-polled.c
+++ b/bsps/shared/dev/serial/zynq-uart-polled.c
@@ -126,30 +126,18 @@ void zynq_uart_initialize(rtems_termios_device_context *base)
   zynq_cal_baud_rate(ZYNQ_UART_DEFAULT_BAUD, &brgr, &bauddiv, regs->mode);
-  regs->control &= ~(ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN);
-  regs->control = ZYNQ_UART_CONTROL_RXDIS
-    | ZYNQ_UART_CONTROL_TXDIS;
+  regs->control = ZYNQ_UART_CONTROL_RXDIS | ZYNQ_UART_CONTROL_TXDIS;
   regs->mode = ZYNQ_UART_MODE_CHMODE(ZYNQ_UART_MODE_CHMODE_NORMAL)
     | ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_NONE)
     | ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_8);
   regs->baud_rate_gen = ZYNQ_UART_BAUD_RATE_GEN_CD(brgr);
   regs->baud_rate_div = ZYNQ_UART_BAUD_RATE_DIV_BDIV(bauddiv);
   /* A Tx/Rx logic reset must be issued after baud rate manipulation */
-    | ZYNQ_UART_CONTROL_RXRES
-    | ZYNQ_UART_CONTROL_TXRES;
+  regs->control = ZYNQ_UART_CONTROL_RXRES | ZYNQ_UART_CONTROL_TXRES;
   regs->rx_fifo_trg_lvl = ZYNQ_UART_RX_FIFO_TRG_LVL_RTRIG(0);
   regs->rx_timeout = ZYNQ_UART_RX_TIMEOUT_RTO(0);
   regs->control = ZYNQ_UART_CONTROL_RXEN
-    | ZYNQ_UART_CONTROL_TXEN
-    | ZYNQ_UART_CONTROL_RSTTO;
-   * Some ZynqMP UARTs have a hardware bug that causes TX/RX logic restarts to
-   * require a kick after baud rate registers are initialized.
-  zynq_uart_write_polled(base, 0);
+    | ZYNQ_UART_CONTROL_TXEN;
 int zynq_uart_read_polled(rtems_termios_device_context *base)
diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
index 8503e31d49..5906a015d9 100644
--- a/bsps/shared/dev/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -37,24 +37,25 @@ static void zynq_uart_interrupt(void *arg)
   rtems_termios_tty *tty = arg;
   zynq_uart_context *ctx = rtems_termios_get_device_context(tty);
   volatile zynq_uart *regs = ctx->regs;
-  uint32_t channel_sts;
-  if ((regs->irq_sts & (ZYNQ_UART_TIMEOUT | ZYNQ_UART_RTRIG)) != 0) {
-    regs->irq_sts = ZYNQ_UART_TIMEOUT | ZYNQ_UART_RTRIG;
-    do {
-      char c = (char) ZYNQ_UART_TX_RX_FIFO_FIFO_GET(regs->tx_rx_fifo);
-      rtems_termios_enqueue_raw_characters(tty, &c, 1);
-      channel_sts = regs->channel_sts;
-    } while ((channel_sts & ZYNQ_UART_CHANNEL_STS_REMPTY) == 0);
-  } else {
+  if ((regs->irq_sts & ZYNQ_UART_RTRIG) != 0) {
+    char buf[32];
+    int c = 0;
+    regs->irq_sts = ZYNQ_UART_RTRIG;
+    while (c < sizeof(buf) &&
+           (regs->channel_sts & ZYNQ_UART_CHANNEL_STS_REMPTY) == 0) {
+       buf[c++] = (char) ZYNQ_UART_TX_RX_FIFO_FIFO_GET(regs->tx_rx_fifo);
+    rtems_termios_enqueue_raw_characters(tty, buf, c);
-  if (ctx->transmitting && (channel_sts & ZYNQ_UART_CHANNEL_STS_TEMPTY) != 0) {
-    rtems_termios_dequeue_characters(tty, 1);
+  if (ctx->transmitting &&
+      (regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TEMPTY) != 0) {
+    int sent = ctx->tx_queued;
+    regs->irq_dis = ZYNQ_UART_TEMPTY;
+    ctx->transmitting = false;
+    ctx->tx_queued = 0;
+    rtems_termios_dequeue_characters(tty, sent);
 #endif
@@ -76,11 +77,10 @@ static bool zynq_uart_first_open(
   zynq_uart_initialize(base);
 #ifdef ZYNQ_CONSOLE_USE_INTERRUPTS
-  regs->rx_timeout = 32;
-  regs->rx_fifo_trg_lvl = ZYNQ_UART_FIFO_DEPTH / 2;
+  regs->rx_fifo_trg_lvl = 1;
   regs->irq_dis = 0xffffffff;
   regs->irq_sts = 0xffffffff;
-  regs->irq_en = ZYNQ_UART_RTRIG | ZYNQ_UART_TIMEOUT;
+  regs->irq_en = ZYNQ_UART_RTRIG;
   sc = rtems_interrupt_handler_install(
     ctx->irq,
     "UART",
@@ -119,18 +119,22 @@ static void zynq_uart_write_support(
   zynq_uart_context *ctx = (zynq_uart_context *) base;
   if (len > 0) {
-    ctx->transmitting = true;
+    const char *p = &buf[0];
     regs->irq_sts = ZYNQ_UART_TEMPTY;
+    while (ctx->tx_queued < 32 && len > 0) {
+      regs->tx_rx_fifo = ZYNQ_UART_TX_RX_FIFO_FIFO(*p);
+      ++p;
+      ++ctx->tx_queued;
+      --len;
+    ctx->transmitting = true;
     regs->irq_en = ZYNQ_UART_TEMPTY;
-    regs->tx_rx_fifo = ZYNQ_UART_TX_RX_FIFO_FIFO(buf[0]);
-  } else {
-    ctx->transmitting = false;
-    regs->irq_dis = ZYNQ_UART_TEMPTY;
 #else
   ssize_t i;
   for (i = 0; i < len; ++i) {
     zynq_uart_write_polled(base, buf[i]);
@@ -208,22 +212,16 @@ static bool zynq_uart_set_attributes(
     mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_1);
   regs->mode = mode;
   /* Ignore baud rate of B0. There are no modem control lines to de-assert */
   if (baud > 0) {
-    regs->control |= ZYNQ_UART_CONTROL_RXRES
-  regs->control |= ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
-  zynq_uart_write_polled(context, 0);
+  regs->irq_sts = 0xffffffff;
+  regs->control = ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
   return true;
2.24.1
