RTEMS Tools on 5 release can't be build with modern LLVM
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Aug 17 11:02:14 UTC 2021
Thanks for having a look at it. I created the ticket and updated
rtems-tools and rtems-source-builder like described.
Best regards
Christian
Am 17.08.21 um 00:20 schrieb Chris Johns:
> Looks good and thank you for sorting this out.
> Chris
> On 17/8/21 1:17 am, Christian MAUDERER wrote:
>> Am 16.08.21 um 17:12 schrieb Joel Sherrill:
>>> On Mon, Aug 16, 2021 at 10:08 AM Christian MAUDERER
>>> <christian.mauderer at embedded-brains.de> wrote:
>>>> Hello Joel,
>>>> Am 16.08.21 um 17:03 schrieb Joel Sherrill:
>>>>> On Mon, Aug 16, 2021 at 9:49 AM Christian MAUDERER
>>>>>> Hello,
>>>>>> I noted that I can't build the RTEMS 5 toolchain if I have a modern LLVM
>>>>>> installed using the RTEMS source builder. Therefore I would like to
>>>>>> backport the patch 37ad446d9dce3 ([1]) to the 5 branch. Is that OK? If
>>>>>> someone acknowledges it, I would do the following steps without further
>>>>>> review (but of course with testing):
>>>>>> 1. Create a ticket for the problem.
>>>>>> 2. In rtems-tools: Cherry pick the patch 37ad446d9dce3 to the 5 branch.
>>>>>> 3. In rtems-source-builder: Backport the patch 91932d0a0 [2] to the 5
>>>>>> branch (or rather re-create it because it will be a different commit and
>>>>>> a different hash).
>>>>> I'm ok with this. I remember doing a patch for the opposite direction.
>>>>> I couldn't
>>>>> build on an older gcc because it assumed a different language version as
>>>>> default. gcc 4.8 as on CentOS 7 assumes C++03. Newer versions assume C++11
>>>>> as the base. Similarly newer gcc's seem to default to C11.
>>>> Thanks. I'll wait a bit more before adding the patches in case someone
>>>> else want's to object.
>>> Good plan.
>>>>> I posted a few weeks ago that users should really be careful to always use
>>>>> -std and consciously pick what they want.
>>>> In this case, the version of the standard depends quite a lot on the
>>>> LLVM headers. LLVM seems to love using new features.
>>> Then this is probably not the first time we will face this.
>> Definitively not. It is only a backport of a patch so I had that problem already
>> on another system. I only missed to add it to the 5 branch back then.
>> Best regards
>> Christian
>>> --joel
>>>> Best regards
>>>> Christian
>>>>> --joel
>>>>>> Best regards
>>>>>> Christian
>>>>>> [1]
>>>>>> https://git.rtems.org/rtems-tools/commit/?id=37ad446d9dce3438d6d32e1caf56d3fdccdd2ad0
>>>>>> [2]
>>>>>> https://git.rtems.org/rtems-source-builder/commit/?id=91932d0a0c86400366f9c75a62123b6488ff458a
>>>>>> embedded brains GmbH
>>>>>> Herr Christian MAUDERER
>>>>>> Dornierstr. 4
>>>>>> 82178 Puchheim
>>>>>> Germany
>>>>>> email: christian.mauderer at embedded-brains.de
>>>>>> phone: +49-89-18 94 741 - 18
>>>>>> fax:   +49-89-18 94 741 - 08
>>>>>> Registergericht: Amtsgericht München
>>>>>> Registernummer: HRB 157899
>>>>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>>>>> Unsere Datenschutzerklärung finden Sie hier:
>>>>>> https://embedded-brains.de/datenschutzerklaerung/
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>> Dornierstr. 4
>>>> 82178 Puchheim
>>>> Germany
Dornierstr. 4
82178 Puchheim
Germany
