[PATCH] cpukit/mghttpd: Support all descriptors in select
Tue Aug 17 13:20:12 UTC 2021
Looks ok.
On Tue, Aug 17, 2021, 3:49 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Support all possible descriptors in a select call. Borrowed
>   from Christain and his mDNS change in LibBSD
> - If select (or poll) fails pause for a bit rather than
>   locking up in a hard loop
>  cpukit/mghttpd/mongoose.c | 28 ++++++++++++++++++++++++++++
>  1 file changed, 28 insertions(+)
> diff --git a/cpukit/mghttpd/mongoose.c b/cpukit/mghttpd/mongoose.c
> index 0736c836ec..5e7e68e7ea 100644
> --- a/cpukit/mghttpd/mongoose.c
> +++ b/cpukit/mghttpd/mongoose.c
> @@ -81,6 +81,12 @@
>  #include <stddef.h>
>  #include <stdio.h>
> +#if __rtems__
> +#include <time.h>
> +#include <sys/param.h>
> +#include <rtems/libio_.h>
> +#endif
>  #if defined(_WIN32) && !defined(__SYMBIAN32__) // Windows specific
>  #undef _WIN32_WINNT
>  #define _WIN32_WINNT 0x0400 // To make it link in VS2005
> @@ -1516,13 +1522,32 @@ static int set_non_blocking_mode(SOCKET sock) {
>  #ifndef HAVE_POLL
>  static int poll(struct pollfd *pfd, int n, int milliseconds) {
>    struct timeval tv;
> +#if __rtems__
> +  #define set (*set_prealloc)
> +  static fd_set *set_prealloc;
> +  static size_t set_size;
> +#else
>    fd_set set;
> +#endif
>    int i, result;
>    SOCKET maxfd = 0;
>    tv.tv_sec = milliseconds / 1000;
>    tv.tv_usec = (milliseconds % 1000) * 1000;
> +#if __rtems__
> +  if (set_prealloc == NULL) {
> +    set_size =
> +      sizeof(fd_set) * (howmany(rtems_libio_number_iops, sizeof(fd_set) *
> 8));
> +    set_prealloc = malloc(set_size);
> +      errno = ENOMEM;
> +      return -1;
> +  memset(set_prealloc, 0, set_size);
> +#else
>    FD_ZERO(&set);
> +#endif
>    for (i = 0; i < n; i++) {
>      FD_SET((SOCKET) pfd[i].fd, &set);
> @@ -5367,6 +5392,9 @@ static void *master_thread(void *thread_func_param) {
>            accept_new_connection(&ctx->listening_sockets[i], ctx);
> +    } else {
> +      struct timespec t = { .tv_sec = 0, .tv_nsec = 500000000L };
> +      nanosleep(&t, &t);
>    free(pfd);
> 2.19.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210817/2977108d/attachment.html>
