[PATCH] eng: Document use of BSP family for defaults
Sebastian Huber
Wed Aug 18 09:29:17 UTC 2021
Update #4468.
eng/build-system.rst | 4 ++--
eng/req/items.rst | 8 ++++++--
2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/eng/build-system.rst b/eng/build-system.rst
index e76b606..030679d 100644
--- a/eng/build-system.rst
+++ b/eng/build-system.rst
@@ -355,8 +355,8 @@ Add a Base BSP to a BSP Family
items ``spec:/build/bsps/arch/family/bsprst``,
``spec:/build/bsps/arch/family/bspuvw``, and
``spec:/build/bsps/arch/family/bspxyz`` just define the name of the base
- BSP and set a link to the group item. The base BSP names can be used for
- example in the ``default-by-variant`` attribute of
+ BSP and set a link to the group item. The base BSP and BSP family names
+ can be used for example in the ``default-by-variant`` attribute of
:ref:`SpecTypeBuildOptionItemType` items. The items linked by the BSP
items are shown using relative UIDs.
diff --git a/eng/req/items.rst b/eng/req/items.rst
index e7727aa..51f3c3d 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -719,8 +719,11 @@ default
default-by-variant
The attribute value shall be a list. Each list element shall be a
- :ref:`SpecTypeBuildOptionDefaultByVariant`. The list is processed from top
- to bottom. If a matching variant is found, then the processing stops.
+ :ref:`SpecTypeBuildOptionDefaultByVariant`. The list is checked two times
+ and processed from top to bottom. Firstly, the base BSP name is used to
+ match with a variant. Secondly, the BSP family name prefixed by ``bsps/``
+ is used to match with a variant. If a matching variant is found, then the
+ processing stops.
description
The attribute value shall be an optional string. It shall be the
@@ -750,6 +753,7 @@ Please have a look at the following example:
default-by-variant:
- value: 9600
variants:
+ - bsps/powerpc/motorola_powerpc
- m68k/m5484FireEngine
- powerpc/hsc_cm01
- value: 19200
2.26.2
