[PATCH 1/1] Implementation / tests for pthread_cond_clockwait()
Matt Joyce mfjoyce2004 at gmail.com
Wed Aug 18 11:17:12 UTC 2021
Added implementation of the pthread_cond_clockwait()
method to cpukit/posix/src/condclockwait.c. Additional
logic added to condwaitsupp.c to implement new method.
pthread_cond_clockwait() has been added to the Issue 8
POSIX Standard.
psx17 test added to testsuites/psxtests to test the
newly added method.
 cpukit/include/rtems/posix/condimpl.h         |   1 +
 cpukit/posix/src/condclockwait.c              |  69 +++
 cpukit/posix/src/condtimedwait.c              |   1 +
 cpukit/posix/src/condwait.c                   |   1 +
 cpukit/posix/src/condwaitsupp.c               |  64 ++-
 spec/build/testsuites/psxtests/grp.yml        |   2 +
 spec/build/testsuites/psxtests/psx17.yml      |  20 +
 testsuites/psxtests/Makefile.am               |   8 +
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psx17/init.c              | 425 ++++++++++++++++++
 testsuites/psxtests/psx17/psx17.doc           |  45 ++
 testsuites/psxtests/psx17/psx17.scn           |  82 ++++
 testsuites/psxtests/psx17/system.h            |  57 +++
 .../psxhdrs/pthread/pthread_cond_clockwait.c  |   2 +-
 14 files changed, 761 insertions(+), 17 deletions(-)
 create mode 100644 cpukit/posix/src/condclockwait.c
 create mode 100644 spec/build/testsuites/psxtests/psx17.yml
 create mode 100644 testsuites/psxtests/psx17/init.c
 create mode 100644 testsuites/psxtests/psx17/psx17.doc
 create mode 100644 testsuites/psxtests/psx17/psx17.scn
 create mode 100644 testsuites/psxtests/psx17/system.h
diff --git a/cpukit/include/rtems/posix/condimpl.h b/cpukit/include/rtems/posix/condimpl.h
index 66e09bf6d8..6efbc3af70 100644
--- a/cpukit/include/rtems/posix/condimpl.h
+++ b/cpukit/include/rtems/posix/condimpl.h
@@ -152,6 +152,7 @@ int _POSIX_Condition_variables_Signal_support(
 int _POSIX_Condition_variables_Wait_support(
   pthread_cond_t            *cond,
   pthread_mutex_t           *mutex,
+  clockid_t                 clock_id,
   const struct timespec     *abstime
diff --git a/cpukit/posix/src/condclockwait.c b/cpukit/posix/src/condclockwait.c
new file mode 100644
index 0000000000..4104235706
--- /dev/null
+++ b/cpukit/posix/src/condclockwait.c
@@ -0,0 +1,69 @@
+ * @file
+ * @ingroup POSIXAPI
+ * @brief Waiting on a Condition
+* Copyright (C) 2021 Matthew Joyce
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions
+* are met:
+* 1. Redistributions of source code must retain the above copyright
+*    notice, this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright
+*    notice, this list of conditions and the following disclaimer in the
+*    documentation and/or other materials provided with the distribution.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+* POSSIBILITY OF SUCH DAMAGE.
+/* Defining to have access to function prototype in libc/include/pthread.h */
+#define _GNU_SOURCE
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/posix/condimpl.h>
+#include <rtems/score/todimpl.h>
+ *  pthread_cond_clockwait() appears in the Issue 8 POSIX Standard
+int pthread_cond_clockwait(
+  pthread_cond_t        *restrict cond,
+  pthread_mutex_t       *restrict mutex,
+  const struct timespec *restrict abstime
+  if ( abstime == NULL ) {
+    return EINVAL; /* not specified */
+  if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC ) {
+  return _POSIX_Condition_variables_Wait_support(
+    cond,
+    mutex,
+    clock_id,
+    abstime
diff --git a/cpukit/posix/src/condtimedwait.c b/cpukit/posix/src/condtimedwait.c
index 0bc8bfc18e..53fd88efc6 100644
--- a/cpukit/posix/src/condtimedwait.c
+++ b/cpukit/posix/src/condtimedwait.c
@@ -38,6 +38,7 @@ int pthread_cond_timedwait(
     cond,
     mutex,
+    NULL,
     abstime
diff --git a/cpukit/posix/src/condwait.c b/cpukit/posix/src/condwait.c
index 09431e216d..6e9ca4854f 100644
--- a/cpukit/posix/src/condwait.c
+++ b/cpukit/posix/src/condwait.c
@@ -54,6 +54,7 @@ int pthread_cond_wait(
     cond,
     mutex,
+    NULL,
     NULL
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index ee2f8a0787..93d6e1c9d1 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -26,6 +26,7 @@
 #include <rtems/score/status.h>
 static void _POSIX_Condition_variables_Mutex_unlock(
   Thread_queue_Queue   *queue,
   Thread_Control       *the_thread,
@@ -94,6 +95,7 @@ static void _POSIX_Condition_variables_Enqueue_with_timeout_realtime(
@@ -107,28 +109,58 @@ int _POSIX_Condition_variables_Wait_support(
   POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT( the_cond, flags );
   _Thread_queue_Context_initialize( &queue_context );
-  if ( abstime != NULL ) {
-    _Thread_queue_Context_set_timeout_argument( &queue_context, abstime, true );
-    if ( _POSIX_Condition_variables_Get_clock( flags ) == CLOCK_MONOTONIC ) {
+  /* If there is a clock_id parameter, this is a call to
+   * pthread_cond_clockwait. Set the clock according to
+   * this parameter. */
+  if ( clock_id ) {
+    _Thread_queue_Context_set_timeout_argument( &queue_context,
+    abstime, true );
+    /* We have already validated supported clocks in condclockwait.c.
+     * if clock_id is not clock_monotonic, then it is clock_realtime. */
+    if ( clock_id == CLOCK_MONOTONIC ) {
       _Thread_queue_Context_set_enqueue_callout(
         &queue_context,
         _POSIX_Condition_variables_Enqueue_with_timeout_monotonic
-    } else {
-      _Thread_queue_Context_set_enqueue_callout(
+    else {
+        _Thread_queue_Context_set_enqueue_callout(
         &queue_context,
-  } else {
-      &queue_context,
-      _POSIX_Condition_variables_Enqueue_no_timeout
+  /* If there is no clock_id parameter, this is either a call to
+   * cond_timedwait or cond_wait. */
+  else {
+    /* If there is an abstime parameter, this is a call to cond_timedwait. */
+    if ( abstime != NULL ) {
+      _Thread_queue_Context_set_timeout_argument( &queue_context, abstime, true );
+      if ( _POSIX_Condition_variables_Get_clock( flags ) == CLOCK_MONOTONIC ) {
+          &queue_context,
+          _POSIX_Condition_variables_Enqueue_with_timeout_monotonic
+      } else {
+          &queue_context,
+          _POSIX_Condition_variables_Enqueue_with_timeout_realtime
+    /* If there is no abstime parameter, this is a call to cond_wait. */
+    } else {
+        &queue_context,
+        _POSIX_Condition_variables_Enqueue_no_timeout
   executing = _POSIX_Condition_variables_Acquire( the_cond, &queue_context );
   if (
@@ -138,9 +170,8 @@ int _POSIX_Condition_variables_Wait_support(
     _POSIX_Condition_variables_Release( the_cond, &queue_context );
     return EINVAL;
   the_cond->mutex = mutex;
   _Thread_queue_Context_set_thread_state(
     &queue_context,
     STATES_WAITING_FOR_CONDITION_VARIABLE
@@ -151,8 +182,9 @@ int _POSIX_Condition_variables_Wait_support(
     executing,
     &queue_context
   error = _POSIX_Get_error_after_wait( executing );
    *  If the thread is interrupted, while in the thread queue, by
    *  a POSIX signal, then pthread_cond_wait returns spuriously,
@@ -177,7 +209,7 @@ int _POSIX_Condition_variables_Wait_support(
       _Assert( mutex_error == EINVAL );
       error = EINVAL;
   return error;
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index fb7ce465ae..fe945fe7b8 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -47,6 +47,8 @@ links:
   uid: psx15
 - role: build-dependency
   uid: psx16
+- role: build-dependency
+  uid: psx17
   uid: psxaio01
diff --git a/spec/build/testsuites/psxtests/psx17.yml b/spec/build/testsuites/psxtests/psx17.yml
index 0000000000..94f7567fc6
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psx17.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psx17/init.c
+- cpukit/posix/src/condclockwait.c
+stlib: []
+target: testsuites/psxtests/psx17.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a35f00b665..a8d2351e49 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -162,6 +162,14 @@ psx16_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psx16) \
 	$(support_includes) -I$(top_srcdir)/include
 endif
+if TEST_psx17
+psx_tests += psx17
+psx_screens += psx17/psx17.scn
+psx17_SOURCES = psx17/init.c psx17/system.h include/pmacros.h
+psx17_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psx17) \
+	$(support_includes) -I$(top_srcdir)/include
+endif
 if HAS_POSIX
 if TEST_psxaio01
 psx_tests += psxaio01
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 3f95010cd3..cdfa349ae4 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -59,6 +59,7 @@ RTEMS_TEST_CHECK([psx13])
 RTEMS_TEST_CHECK([psx14])
 RTEMS_TEST_CHECK([psx15])
 RTEMS_TEST_CHECK([psx16])
+RTEMS_TEST_CHECK([psx17])
 RTEMS_TEST_CHECK([psxaio01])
 RTEMS_TEST_CHECK([psxaio02])
 RTEMS_TEST_CHECK([psxaio03])
diff --git a/testsuites/psxtests/psx17/init.c b/testsuites/psxtests/psx17/init.c
index 0000000000..bc284af94d
--- /dev/null
+++ b/testsuites/psxtests/psx17/init.c
@@ -0,0 +1,425 @@
+* are met:
+/* Defining in order to access pthread_cond_clockwait in pthread.h */
+#endif
+#define CONFIGURE_INIT
+#include <pthread.h>
+#include <sched.h>
+#include <errno.h>
+#include <rtems.h>
+#include <tmacros.h>
+#include "system.h"
+pthread_cond_t cond = PTHREAD_COND_INITIALIZER;
+pthread_cond_t bad_cond;
+pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER;
+pthread_mutex_t bad_mutex;
+pthread_mutex_t new_mutex = PTHREAD_MUTEX_INITIALIZER;
+clockid_t clock_id1 = CLOCK_MONOTONIC;
+clockid_t clock_id2 = CLOCK_REALTIME;
+clockid_t clock_id3 = CLOCK_MONOTONIC_RAW;
+int count;
+int eno;
+int status;
+const char rtems_test_name[] = "PSX 17";
+void *POSIX_Init(
+  void *argument
+  TEST_BEGIN();
+  empty_line();
+  pthread_t t1;
+  struct timespec abstime;
+  /* Expected pass: Clock Monotonic with sufficient abstime */
+  printf("1st iteration Begin (Clock Monotonic)\n");
+  abstime.tv_sec = 2;
+  abstime.tv_nsec = 1;
+  status = pthread_create( &t1, NULL, thread_func, NULL );
+  if ( status != 0 ) {
+    perror( "pthread_create" );
+  pthread_mutex_lock(&mutex);
+  while ( count == 0 ){
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "Minus called. Count is %d\n", count );
+  pthread_mutex_unlock( &mutex );
+  rtems_test_assert( eno == 0 );
+  printf( "Return value from cond_clockwait is %d\n", eno );
+  pthread_join( t1, NULL );
+  printf( "1st iteration END\n" );
+  empty_line();
+  /* Expected fail: Clock Monotonic with insufficient abstime */
+  printf( "2nd iteration Begin (Clock Monotonic)\n" );
+  abstime.tv_sec = 0;
+  pthread_mutex_lock( &mutex );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  rtems_test_assert( eno == ETIMEDOUT );
+  printf( "2nd iteration END\n" );
+  empty_line();
+  /* Expected pass: Clock Realtime with sufficient abstime */
+  printf( "3rd iteration Begin (Clock Realtime)\n" );
+  status = clock_gettime( clock_id2, &abstime );
+  rtems_test_assert( !status );
+  abstime.tv_sec += 4;
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id2, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "3rd iteration END\n" );
+  empty_line();
+  /* Expected fail: Clock Realtime with insufficient abstime */
+  printf( "4th iteration Begin (Clock Realtime)\n" );
+  abstime.tv_sec += 0;
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "4th iteration END\n" );
+  empty_line();
+  /* Expected fail: Unsupported Clock */
+  printf( "5th iteration Begin (Unsupported Clock)\n" );
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id3, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  rtems_test_assert( eno == EINVAL );
+  printf( "5th iteration END\n" );
+  empty_line();
+  /* Expected fail: Invalid Clock */
+  printf( "6th iteration Begin (Invalid Clock)\n" );
+    eno = pthread_cond_clockwait( &cond, &mutex, (int)NULL, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "6th iteration END\n" );
+  empty_line();
+  printf( "7th iteration Begin (Invalid Abstime)\n" );
+    eno = pthread_cond_clockwait( &cond, &mutex, clock_id1, NULL );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "7th iteration END\n" );
+  empty_line();
+  printf( "8th iteration Begin (Invalid Cond)\n" );
+    eno = pthread_cond_clockwait( NULL, &mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "8th iteration END\n" );
+  empty_line();
+    /* Expected fail: Invalid Mutex */
+  printf( "9th iteration Begin (Invalid Mutex)\n" );
+    eno = pthread_cond_clockwait( &cond, NULL, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  rtems_test_assert( eno != 0 );
+  printf( "9th iteration END\n" );
+  empty_line();
+  /* Expected fail: Uninitialized condition variable */
+  printf( "10th iteration Begin (Uninitialized Condition Variable)\n" );
+    eno = pthread_cond_clockwait( &bad_cond, &mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "10th iteration END\n" );
+  empty_line();
+  printf( "11th iteration Begin (Uninitialized Mutex)\n" );
+    eno = pthread_cond_clockwait( &cond, &bad_mutex, clock_id1, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  printf( "11th iteration END\n" );
+  empty_line();
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  empty_line();
+  /* Expected pass: Binding new mutex to condition variable */
+  printf( "12th iteration Begin (New Mutex)\n" );
+  status = pthread_create( &t1, NULL, thread_func2, NULL );
+  pthread_mutex_lock( &new_mutex );
+    eno = pthread_cond_clockwait( &cond, &new_mutex, clock_id2, &abstime );
+    if ( eno != 0 ) {
+      break;
+  count -= 1;
+  pthread_mutex_unlock( &new_mutex );
+  printf( "12th iteration END\n" );
+  empty_line();
+  TEST_END();
+  rtems_test_exit( 0 );
+  return NULL;
+void *thread_func( void *arg )
+  if (count == 0) {
+    pthread_cond_signal( &cond );
+  count +=1;
+  printf( "Add called. Count is %d\n", count );
+  return NULL;
+void *thread_func2( void *arg )
+  if ( count == 0 ) {
+  count +=1;
+  return NULL;
diff --git a/testsuites/psxtests/psx17/psx17.doc b/testsuites/psxtests/psx17/psx17.doc
index 0000000000..d1206982c9
--- /dev/null
+++ b/testsuites/psxtests/psx17/psx17.doc
@@ -0,0 +1,45 @@
+* are met:
+This file describes the directives and concepts tested by this test set.
+test set name:  psx17
+directives:
+  pthread_cond_clockwait
+  pthread_create
+  pthread_join
+concepts:
++ Tests the newly-added, Issue 8 POSIX Standard pthread_cond_clockwait method.
+  Tests include valid/supported and invalid/unsupported clocks, sufficient and
+  insufficient timeouts, and invalid or uninitialized condition/mutex
+  parameters.
\ No newline at end of file
diff --git a/testsuites/psxtests/psx17/psx17.scn b/testsuites/psxtests/psx17/psx17.scn
index 0000000000..d3e7fd024f
--- /dev/null
+++ b/testsuites/psxtests/psx17/psx17.scn
@@ -0,0 +1,82 @@
+*** BEGIN OF TEST PSX 17 ***
+1st iteration Begin (Clock Monotonic)
+Add called. Count is 1
+Minus called. Count is 0
+Return value from cond_clockwait is 0
+1st iteration END
+2nd iteration Begin (Clock Monotonic)
+Return value from cond_clockwait is 116
+2nd iteration END
+3rd iteration Begin (Clock Realtime)
+3rd iteration END
+4th iteration Begin (Clock Realtime)
+4th iteration END
+5th iteration Begin (Unsupported Clock)
+Minus called. Count is -1
+Return value from cond_clockwait is 22
+Add called. Count is 0
+5th iteration END
+6th iteration Begin (Invalid Clock)
+6th iteration END
+7th iteration Begin (Invalid Abstime)
+7th iteration END
+8th iteration Begin (Invalid Cond)
+8th iteration END
+9th iteration Begin (Invalid Mutex)
+9th iteration END
+10th iteration Begin (Uninitialized Condition Variable)
+10th iteration END
+11th iteration Begin (Uninitialized Mutex)
+11th iteration END
+10th iteration END
+12th iteration Begin (New Mutex)
+12th iteration END
+*** END OF TEST PSX 17 ***
diff --git a/testsuites/psxtests/psx17/system.h b/testsuites/psxtests/psx17/system.h
index 0000000000..7da50cca7f
--- /dev/null
+++ b/testsuites/psxtests/psx17/system.h
@@ -0,0 +1,57 @@
+* are met:
+/* functions */
+#include <pmacros.h>
+#include <unistd.h>
+#include <errno.h>
+void *POSIX_Init(
+  void *argument
+void *thread_func(
+  void *argument
+  void *argument
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS              4
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs.h>
+/* end of include file */
diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
index 15485eb587..fe91b7954f 100644
--- a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
+++ b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_clockwait.c
@@ -49,7 +49,7 @@ int test( void )
   clockid_t clock_id = CLOCK_REALTIME;
-  abstime.tv_sec = 2;
+  abstime.tv_sec = 1;
   int result;
   /* This method appeared in the Issue 8 POSIX Standard */
2.31.1
