Xilinx Zynq console rx not working
Gedare Bloom
gedare at rtems.org
Wed Aug 18 18:19:06 UTC 2021
On Mon, Aug 16, 2021 at 11:13 PM Chris Johns <chrisj at rtems.org> wrote:
> On 17/8/21 8:59 am, Chris Johns wrote:
> > On 16/8/21 11:03 pm, Kinsey Moore wrote:
> >> On 8/16/2021 04:45, Chris Johns wrote:
> >>> On 16/8/21 6:38 pm, Chris Johns wrote:
> >>>> I have taken a closer look at the driver. I am receiving RX interrupts and the
> >>>> characters are being queued however the receive FIFO trigger interrupt is only
> >>>> raised when the FIFO reaches the set threshold of half the FIFO size. I suspect
> >>>> there is an assumption the RX timeout will fire but it is not.
> >>> Doing this is questionable ....
> >>> https://git.rtems.org/rtems/tree/bsps/shared/dev/serial/zynq-uart.c#n222
> >>> You cannot send a character when touching the attributes. Where is this hardware
> >>> bug documented by Xilinx?
> >> The attributes are done being touched and the TX/RX enable flags are set again
> >> before sending the character. I was seeing the same behavior on Zynq QEMU even
> >> with this code removed.
> >> I couldn't find the hardware bug documented anywhere, but out of the 3 ZynqMP
> >> boards I have one requires this consistently.
> > I suggest we use chip maker errata when documenting hardware bugs as it could
> > turn out to be a bug in a our code.
> > This smells to me like a set up problem.
> >>> My application does this ...
> >>> if (tcgetattr(fileno(stdout), &term) < 0)
> >>> error_message();
> >>> cfsetispeed (&term, B115200);
> >>> cfsetospeed (&term, B115200);
> >>> if (tcsetattr (fileno(stdout), TCSADRAIN, &term) < 0)
> >>> error_message();
> >>> if (tcgetattr(fileno(stdin), &term) < 0)
> >>> error_message();
> >>> if (tcsetattr (fileno(stdin), TCSADRAIN, &term) < 0)
> >>> error_message();
> >>> and this kills the receive interrupts.
> >> Does removing the null character kick restore functionality for you in this case?
> > No it did not.
> I have read the Zynq-7000 TRM and the Versal ACAP TRM and there is a difference
> in the wording around the RX timeout. It seems the RX timeout has evolved in the
> Versal to a timer that can interrupt if data has entered the FIFO then no more
> within the timeout period and the FIFO trigger level has not been reached. The
> timer on the Zynq does not do this. It is something that can handle inter-gap
> checks for those serial protocols that require this and there a few of them.
> They delimit frames using time domain signalling. To make it work on a zynq-7000
> I think you need to receive the first character (rtrig=1) then in the interrupt
> handler raise the FIFO trigger level and prime the timer to achieve the Versal
> timer functionality. I cannot be bothered doing this.
> All we have is a console and that is a pretty basic use case for a UART. As a
> result I have lowered the RX trigger level to 1 and disabled the RX timer. I
> have also added support to send a FIFO full of data.
> The solution is not as optimal as it could be with the Versal UART. If this
> becomes a problem and someone wants a lower interrupt count we can look
> specialising the driver based on the variant of the UART or implement the timer
> protocol I outlined above.
> I will create a patch and test on qemu and the Versal then post.
We should capture this discussion/outcome in the BSP doco:
https://docs.rtems.org/branches/master/user/bsps/index.html
> Chris
> devel mailing list
> devel at rtems.org
