Using libbsd dhcpcd options
Peter Dufault dufault at hda.com
Thu Aug 19 10:16:49 UTC 2021
I'd like to use the DHCP option 17 (Root Path) to get a mount point for NFS from the DHCP server.
I'm starting dhcp with "rtems_dhcpcd_start(NULL)" so it's starting with only the argv array of {"dhcpcd", NULL }.
I *think* I need to start it with a customized rtems_dhcpcd_config that would maybe include a "--option" argument, and retrieve it in a run hook (I'm using the run hook already to wait for an IP address to be assigned).  The FreeBSD "--option" documentation is:
-o, --option "option"
Request the DHCP "option" variable for use in "/usr/local/libexec/dhcpcd-run-hooks".
which would be an argv of {"dhcpcd", "--option", "17", NULL }.
Or is best practice to do something with "rtems-bsd-rc-conf-net.c"?
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210819/a329fbe8/attachment.bin>
