[PATCH] aarch64: Add tests that are failing intermittently
Ryan Long
ryan.long at oarcorp.com
Thu Aug 19 15:52:59 UTC 2021
- Change status of all spintrcritical tests to indeterminate, expanded upon
comments.
- Add indeterminate tests to xilinx-versal
spec/build/bsps/aarch64/a53/tsta53.yml | 40 ++++++++++++++---
spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml | 54 ++++++++++++++++++++++-
spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 40 ++++++++++++++---
3 files changed, 120 insertions(+), 14 deletions(-)
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index f263557..6e8f348 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -1,20 +1,26 @@
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
- set-test-state:
- # expected to fail, don't compile these
+ # This test fails when ran through rtems-tester because it does not
+ # produce any output.
minimum: exclude
- # don't compile due to toolchain issues
+ # These tests do not compile due to an issue with the GNU Assembler.
+ # The issue has been filed(https://devel.rtems.org/ticket/4218).
+ # Once the issue has been fixed, these tests will be turned back on.
spconfig01: exclude
spmisc01: exclude
- # tests that are passing intermittently
+ # These tests may or may not fail, however, they do pass on real hardware.
+ # It seems to be an issue with QEMU.
spcpucounter01: indeterminate
+ sptimecounter01: indeterminate
rtmonuse: indeterminate
- sp68: indeterminate
sp04: indeterminate
sp20: indeterminate
+ sp68: indeterminate
sp69: indeterminate
+ sp71: indeterminate
rtmonusxtimes01: indeterminate
spedfsched02: indeterminate
spedfsched04: indeterminate
@@ -24,12 +30,34 @@ actions:
sptimecounter04: indeterminate
ttest02: indeterminate
- # tests that pass nominally, but fail under Qemu when the host is under
- # heavy load
+ # It seems to be an issue with Qemu, and that this only occurs when the
+ # host machine is under a heavy load.
psx12: indeterminate
+ spintrcritical01: indeterminate
+ spintrcritical02: indeterminate
spintrcritical03: indeterminate
spintrcritical04: indeterminate
spintrcritical05: indeterminate
+ spintrcritical06: indeterminate
+ spintrcritical07: indeterminate
+ spintrcritical08: indeterminate
+ spintrcritical09: indeterminate
+ spintrcritical10: indeterminate
+ spintrcritical11: indeterminate
+ spintrcritical12: indeterminate
+ spintrcritical13: indeterminate
+ spintrcritical14: indeterminate
+ spintrcritical15: indeterminate
+ spintrcritical16: indeterminate
+ spintrcritical17: indeterminate
+ spintrcritical18: indeterminate
+ spintrcritical19: indeterminate
+ spintrcritical20: indeterminate
+ spintrcritical21: indeterminate
+ spintrcritical22: indeterminate
+ spintrcritical23: indeterminate
+ spintrcritical24: indeterminate
build-type: option
copyrights:
- Copyright (C) 2020 On-Line Applications Research (OAR)
diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
index 43f6b2e..884effc 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
@@ -1,13 +1,63 @@
actions:
- set-test-state:
minimum: exclude
- # don't compile due to toolchain issues, see RTEMS issue #4218
spconfig01: exclude
spmisc01: exclude
+ # It seems to be an issue with Qemu.
+ spcpucounter01: indeterminate
+ rtmonuse: indeterminate
+ sp04: indeterminate
+ sp20: indeterminate
+ sp69: indeterminate
+ rtmonusxtimes01: indeterminate
+ spedfsched02: indeterminate
+ spedfsched04: indeterminate
+ psxtimes01: indeterminate
+ sprmsched01: indeterminate
+ sptimecounter02: indeterminate
+ sptimecounter04: indeterminate
+ ttest02: indeterminate
+ psx12: indeterminate
+ spintrcritical03: indeterminate
+ spintrcritical04: indeterminate
+ spintrcritical05: indeterminate
build-type: option
copyrights:
- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
index efe0b82..06929ed 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
@@ -1,20 +1,26 @@
actions:
- set-test-state:
minimum: exclude
spconfig01: exclude
spmisc01: exclude
sp04: indeterminate
sp20: indeterminate
sp69: indeterminate
- # heavy load
build-type: option
copyrights:
1.8.3.1
