[PATCH] gdb: prefere python3 if it is installed
Thu Aug 19 16:51:40 UTC 2021
I have no problem with this. I think it is sensible to look for
python3 before python2. At some point we'll have to stop looking for
python2 :)
On Thu, Aug 19, 2021 at 3:24 AM Christian MAUDERER
<christian.mauderer at embedded-brains.de> wrote:
> PS: I had the problem on the 5 branch of RTEMS source builder. I think
> we should apply a patch to both: master and the 5 branch.
> Am 19.08.21 um 10:34 schrieb Christian Mauderer:
> > More and more systems stop shipping python2. So we should start to
> > prefer python3 over python2. For building gdb it is not only necessary
> > to have a python binary installed, but also the matching python-devel
> > packet. On a lot of hosts that will now be more often python3-devel
> > and not python2-devel.
> > Note: Please see that patch more as an suggestion / base for
> > discussion. I'm open to better solutions.
> > My problem that triggered this patch was a build of a toolchain on a
> > github CI/CD system that has been originally set up by one of our
> > users (see [1] for the log). It seems that on the "macos-latest"
> > machines a python2 is installed but no python2 headers are found.
> > Homebrew - which could be used earlier on MacOS to install the
> > necessary headers - dropped the python at 2 packet. So it seems that on a
> > modern MacOS there is no possibility to get python2 headers. If
> > python2 is still installed on the machine (for whatever reason), it is
> > not possible to successfully use RTEMS source builder to build a gdb.
> > If python3 is preferred instead, that should solve the problem.
> > Note that at the moment I only tried it on my OpenSUSE-Linux machine.
> > For that I made sure that I have python2 and python3 installed but no
> > python-devel (which is python2 on OpenSUSE). Earlier I know that I
> > needed python-devel to build gdb. With this patch, I can build with
> > only python3-devel.
> > I'll try to add that patch to the CI too to see whether it works on
> > MacOS. But I'm a bit unsure what other problems this patch could
> > trigger and therefore I want to start a discussion early.
> > Best regards
> > Christian
> > [1] https://github.com/grisp/grisp2-rtems-toolchain/runs/3362717606
> >      Note: The "Get Errorinfo" step prints the rsb-report-*.txt
> >   source-builder/config/gdb-common-1.cfg | 6 +++---
> >   1 file changed, 3 insertions(+), 3 deletions(-)
> > diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
> > index 397d44d..42fe263 100644
> > --- a/source-builder/config/gdb-common-1.cfg
> > +++ b/source-builder/config/gdb-common-1.cfg
> > @@ -42,7 +42,7 @@
> >   # 2. Does the version of gdb specify a version of python that must be
> >   #    used. Override with '%define gdb-python-version python2'.
> > -# 3. Search for 'python2' and if not found search for 'python3'.
> > +# 3. Search for 'python3' and if not found search for 'python2'.
> >   %if %{defined gdb-python2}
> >     %define gdb-enable-python %{gdb_python2}
> > @@ -53,9 +53,9 @@
> >       %if %{defined gdb-python-version}
> >         %define gdb-enable-python %(command -v %{gdb-python-version} || true)
> >       %else
> > -      %define gdb-enable-python %(command -v python2 || true)
> > +      %define gdb-enable-python %(command -v python3 || true)
> >         %if %{gdb-enable-python} == %{nil}
> > -        %define gdb-enable-python %(command -v python3 || true)
> > +        %define gdb-enable-python %(command -v python2 || true)
> >         %endif
> >             %define gdb-enable-python %(command -v python || true})
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
