[PATCH] aarch64: Add tests that are failing intermittently
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Aug 19 17:42:32 UTC 2021
I've seen these failures on my local system, in our CI, and on a build
server that I sometimes
use for development/testing so if it's a configuration issue we're being
pretty consistent about
misconfiguration across some pretty different environments (docker,
bare-metal, VM, different
OSs, different QEMU versions). I've seen enough of the spintrcritical
tests fail sporadically on
QEMU to lump them all into this category. These are also tests that I
have seen behave badly
on ARMv7 QEMU on my local system (which doesn't rule out
misconfiguration, but it's another
data point).
As far as your worry about marking these indeterminate, they're only
being marked as such for
QEMU BSPs. The ZynqMP hardware BSP doesn't have these testing carve-outs
and runs all
these tests flawlessly.
These failures become much more common when there is otherwise load on
the system and a
lot of them disappear when you limit the tester to a single QEMU
instance at a time.
Kinsey
On 8/19/2021 11:58, Gedare Bloom wrote:
> Can you explain the process for generating the lists of indeterminate
> test results?
> I hate to circle this subject so many times, but is labeling sporadic
> simulator failures as indeterminate results really the right thing to
> do? Are these indeterminate tests reproducible on different
> systems/qemus/loads? Or is it just what you observe locally when
> running rtems-test on one specific system? I don't think I see nearly
> so many spurious failures when I run rtems-test for example. I really
> need to believe we're not just hiding a system configuration problem.
> I know I OK'd looking at the versal, but on second thought, I'd rather
> leave the xilinx-versal/tstqemu.yml alone until the BSP is finished,
> so revert that part of your patch. Sorry about that.
> Gedare
> On Thu, Aug 19, 2021 at 9:53 AM Ryan Long <ryan.long at oarcorp.com> wrote:
>> - Change status of all spintrcritical tests to indeterminate, expanded upon
>> comments.
>> - Add indeterminate tests to xilinx-versal
>> spec/build/bsps/aarch64/a53/tsta53.yml | 40 ++++++++++++++---
>> spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml | 54 ++++++++++++++++++++++-
>> spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 40 ++++++++++++++---
>> 3 files changed, 120 insertions(+), 14 deletions(-)
>> diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
>> index f263557..6e8f348 100644
>> --- a/spec/build/bsps/aarch64/a53/tsta53.yml
>> +++ b/spec/build/bsps/aarch64/a53/tsta53.yml
>> @@ -1,20 +1,26 @@
>> SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> actions:
>> - set-test-state:
>> - # expected to fail, don't compile these
>> + # This test fails when ran through rtems-tester because it does not
>> + # produce any output.
>> minimum: exclude
>> - # don't compile due to toolchain issues
>> + # These tests do not compile due to an issue with the GNU Assembler.
>> + # The issue has been filed(https://devel.rtems.org/ticket/4218).
>> + # Once the issue has been fixed, these tests will be turned back on.
>> spconfig01: exclude
>> spmisc01: exclude
>> - # tests that are passing intermittently
>> + # These tests may or may not fail, however, they do pass on real hardware.
>> + # It seems to be an issue with QEMU.
>> spcpucounter01: indeterminate
>> + sptimecounter01: indeterminate
>> rtmonuse: indeterminate
>> - sp68: indeterminate
>> sp04: indeterminate
>> sp20: indeterminate
>> + sp68: indeterminate
>> sp69: indeterminate
>> + sp71: indeterminate
>> rtmonusxtimes01: indeterminate
>> spedfsched02: indeterminate
>> spedfsched04: indeterminate
>> @@ -24,12 +30,34 @@ actions:
>> sptimecounter04: indeterminate
>> ttest02: indeterminate
>> - # tests that pass nominally, but fail under Qemu when the host is under
>> - # heavy load
>> + # It seems to be an issue with Qemu, and that this only occurs when the
>> + # host machine is under a heavy load.
>> psx12: indeterminate
>> + spintrcritical01: indeterminate
>> + spintrcritical02: indeterminate
>> spintrcritical03: indeterminate
>> spintrcritical04: indeterminate
>> spintrcritical05: indeterminate
>> + spintrcritical06: indeterminate
>> + spintrcritical07: indeterminate
>> + spintrcritical08: indeterminate
>> + spintrcritical09: indeterminate
>> + spintrcritical10: indeterminate
>> + spintrcritical11: indeterminate
>> + spintrcritical12: indeterminate
>> + spintrcritical13: indeterminate
>> + spintrcritical14: indeterminate
>> + spintrcritical15: indeterminate
>> + spintrcritical16: indeterminate
>> + spintrcritical17: indeterminate
>> + spintrcritical18: indeterminate
>> + spintrcritical19: indeterminate
>> + spintrcritical20: indeterminate
>> + spintrcritical21: indeterminate
>> + spintrcritical22: indeterminate
>> + spintrcritical23: indeterminate
>> + spintrcritical24: indeterminate
>> build-type: option
>> copyrights:
>> - Copyright (C) 2020 On-Line Applications Research (OAR)
>> diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
>> index 43f6b2e..884effc 100644
>> --- a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
>> @@ -1,13 +1,63 @@
>> actions:
>> - set-test-state:
>> minimum: exclude
>> - # don't compile due to toolchain issues, see RTEMS issue #4218
>> spconfig01: exclude
>> spmisc01: exclude
>> + # It seems to be an issue with Qemu.
>> + spcpucounter01: indeterminate
>> + rtmonuse: indeterminate
>> + sp04: indeterminate
>> + sp20: indeterminate
>> + sp69: indeterminate
>> + rtmonusxtimes01: indeterminate
>> + spedfsched02: indeterminate
>> + spedfsched04: indeterminate
>> + psxtimes01: indeterminate
>> + sprmsched01: indeterminate
>> + sptimecounter02: indeterminate
>> + sptimecounter04: indeterminate
>> + ttest02: indeterminate
>> + psx12: indeterminate
>> + spintrcritical03: indeterminate
>> + spintrcritical04: indeterminate
>> + spintrcritical05: indeterminate
>> build-type: option
>> copyrights:
>> - Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
>> index efe0b82..06929ed 100644
>> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
>> @@ -1,20 +1,26 @@
>> actions:
>> - set-test-state:
>> minimum: exclude
>> spconfig01: exclude
>> spmisc01: exclude
>> sp04: indeterminate
>> sp20: indeterminate
>> sp69: indeterminate
>> - # heavy load
>> build-type: option
>> copyrights:
>> 1.8.3.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
