[PATCH] gdb: prefere python3 if it is installed
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Aug 20 06:48:56 UTC 2021
Hello,
Am 20.08.21 um 03:49 schrieb Chris Johns:
> On 20/8/21 3:16 am, Joel Sherrill wrote:
>> On Thu, Aug 19, 2021 at 11:51 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> I have no problem with this. I think it is sensible to look for
>>> python3 before python2. At some point we'll have to stop looking for
>>> python2 :)
>> That is further in the future than I would have thought based on the
>> CentOS project changes. I still see user organizations with no plans
>> to move off CentOS 7. It will receive maintenance updates through
>> 2024-06-30.
>> But on CentOS 7, I can load a Python 3.6, newer GCC, etc. so it isn't
>> that bad. I had to test something on a true 32-bit distribution this week
>> and even CentOS 7 (i386) wasn't as painful as I expected to setup.
> There will come a time when a change made cannot be easily tested by us on
> python2 and that will in effect end our support. We are not there yet.
STOP. That discussion took a wrong direction. We discussed deprecating
python2 a few times and I know that we will not do it before the big
long living distributions drop it. I can live with that and I don't want
to re-start this discussion with this patch.
>>> On Thu, Aug 19, 2021 at 3:24 AM Christian MAUDERER
>>> <christian.mauderer at embedded-brains.de> wrote:
>>>> PS: I had the problem on the 5 branch of RTEMS source builder. I think
>>>> we should apply a patch to both: master and the 5 branch.
>>>> Am 19.08.21 um 10:34 schrieb Christian Mauderer:
>>>>> More and more systems stop shipping python2. So we should start to
>>>>> prefer python3 over python2. For building gdb it is not only necessary
>>>>> to have a python binary installed, but also the matching python-devel
>>>>> packet. On a lot of hosts that will now be more often python3-devel
>>>>> and not python2-devel.
>>>>> Note: Please see that patch more as an suggestion / base for
>>>>> discussion. I'm open to better solutions.
>>>>> My problem that triggered this patch was a build of a toolchain on a
>>>>> github CI/CD system that has been originally set up by one of our
>>>>> users (see [1] for the log). It seems that on the "macos-latest"
>>>>> machines a python2 is installed but no python2 headers are found.
> I have just built the latest RSB master GDB on a fully updated MacOS (Big Sur):
> config: tools/rtems-gdb-10.cfg
> package: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1
> building: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1
> sizes: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1: 629.086MB (installed:
> 19.586MB)
> cleaning: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1
> reporting: tools/rtems-gdb-10.cfg ->
> arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1.txt
> arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1.xml
> I support the latest MacOS with Xcode and have a dedicated Mac machine that
> tracks the current RSB. It had wedged itself and I have cleared that so it is
> now building the latest.
So do I understand that correct: This is a "clean" Mac with no
additional python installs or similar and it worked? What python
versions are available on this this machine?
If I did understand you correctly, it seems that github has made some
odd choices about their default config for the macos-latest machines.
They seem to have python2 but no devel headers.
>>>>> Homebrew - which could be used earlier on MacOS to install the
>>>>> necessary headers - dropped the python at 2 packet.
> Homebrew and MacPorts are a personal choice and I am fine with users heading
> down this path however it is beyond this project's scope to support those
> frameworks. I have posted the reasons in the past and the MacPorts maintainers
> are aware of those reasons.
No problem. I'm not a Mac user so I don't really have an opinion or
experience what is the right way to install the requirements on a MacOS
system. I'm really happy that it just works most of the time (a lot of
it most likely thanks to you).
>>>>> So it seems that on a
>>>>> modern MacOS there is no possibility to get python2 headers.
> As I have just built GDB this does not appear to be true. I would prefer we do
> not overreach until we all agree there is a problem. If there is an issue I
> would raise the problem in Apple'd developer bug system. I have raised a number
> of issues over the years and to Apple's credit they have dealt with them all.
Maybe I haven't made it enough clear: I had to do some guess work here.
I have put it here as a basis for discussion. I'm completely OK if you
can tell me that my conclusion has been wrong.
It seems that it really is just an odd choice of defaults on github then.
>>>>> If
>>>>> python2 is still installed on the machine (for whatever reason), it is
>>>>> not possible to successfully use RTEMS source builder to build a gdb.
>>>>> If python3 is preferred instead, that should solve the problem.
> The change seems sensible.
I think even if a clean MacOS doesn't have a problem (like I assumed), I
still think it would be a good idea to prefer python3 if it is
available. We are not talking about preferring it in our python-scripts
but only to build gdb.
Do I have a "go" to:
- create tickets for 5 and 6
   ("RSB: Prefer python3 to build gdb if it is there" with some
explanation in the description)
- push that patch to 5 and 6 and close the tickets with it
>>>>> Note that at the moment I only tried it on my OpenSUSE-Linux machine.
>>>>> For that I made sure that I have python2 and python3 installed but no
>>>>> python-devel (which is python2 on OpenSUSE). Earlier I know that I
>>>>> needed python-devel to build gdb. With this patch, I can build with
>>>>> only python3-devel.
>>>>> I'll try to add that patch to the CI too to see whether it works on
>>>>> MacOS. But I'm a bit unsure what other problems this patch could
>>>>> trigger and therefore I want to start a discussion early.
>>>>> Best regards
>>>>> Christian
>>>>> [1] https://github.com/grisp/grisp2-rtems-toolchain/runs/3362717606
> I am looking forward to their hardware being shipped.
I think there will be an official update soon. You most likely noted
that the CI-run belongs to a pull request that updates the toolchain to
work with the first final board that had been on my desk this week.
Best regards
Christian
> Chris
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
