[PATCH v4 0/2] Add MicroBlaze tools to RSB
Fri Aug 20 13:32:44 UTC 2021
On Thu, Aug 19, 2021 at 11:51 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi Alex,
> These patches are OK to push.
> One minor point, the script sha512-base64 in the RSB creates a base64 encoded
> hash and that makes them smaller. I prefer we move to this more and more.
I did that on my patches. Be happy you are teaching this old dog a new trick. :)
--joel
> Chris
> On 19/8/21 1:34 pm, Alex White wrote:
> > Hi,
> > This patch set now depends on Joel's newlib hash bump and should be merged after
> > it.
> > v4:
> >   - Rename to rtems-xilinx-gcc-10-newlib-head.cfg
> >   - Simplify rtems-xilinx-gcc-10-newlib-head.cfg with include
> > v3:
> >   - Follow naming convention for Xilinx .cfg files
> >   - Simplify rtems-xilinx-binutils-2.36.cfg with rtems-binutils-2.36.cfg include
> > v2:
> >   - Add Xilinx QEMU version to .cfg filename
> >   - Exclude GDB configuration with unneeded Xilinx patches
> > This patch set adds the MicroBlaze tools to rtems-source-builder.
> > Thanks,
> > Alex
> > Alex White (2):
> >   rsb: Add MicroBlaze tools
> >   rsb: Add Xilinx QEMU
> >  bare/config/devel/qemu-xilinx-v2020.2-1.cfg   | 23 ++++++++++
> >  bare/config/devel/qemu-xilinx.bset            | 24 ++++++++++
> >  rtems/config/6/rtems-microblaze.bset          | 23 +++++++++-
> >  .../tools/rtems-xilinx-binutils-2.36.cfg      | 40 ++++++++++++++++
> >  .../tools/rtems-xilinx-gcc-10-newlib-head.cfg | 46 +++++++++++++++++++
> >  5 files changed, 155 insertions(+), 1 deletion(-)
> >  create mode 100644 bare/config/devel/qemu-xilinx-v2020.2-1.cfg
> >  create mode 100644 bare/config/devel/qemu-xilinx.bset
> >  create mode 100644 rtems/config/tools/rtems-xilinx-binutils-2.36.cfg
> >  create mode 100644 rtems/config/tools/rtems-xilinx-gcc-10-newlib-head.cfg
> devel mailing list
> devel at rtems.org
