[PATCH] gdb: prefere python3 if it is installed
oss at c-mauderer.de
Fri Aug 20 18:08:49 UTC 2021
On 20/08/2021 18:24, Gedare Bloom wrote:
> On Fri, Aug 20, 2021 at 2:02 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 20/8/21 5:42 pm, Christian MAUDERER wrote:
>>> Am 20.08.21 um 09:02 schrieb Chris Johns:
>>>> On 20/8/21 4:48 pm, Christian MAUDERER wrote:
>>>>> Hello,
>>>>> Am 20.08.21 um 03:49 schrieb Chris Johns:
>>>>>> On 20/8/21 3:16 am, Joel Sherrill wrote:
>>>>>>> On Thu, Aug 19, 2021 at 11:51 AM Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>> I have no problem with this. I think it is sensible to look for
>>>>>>>> python3 before python2. At some point we'll have to stop looking for
>>>>>>>> python2 :)
>>>>>>> That is further in the future than I would have thought based on the
>>>>>>> CentOS project changes. I still see user organizations with no plans
>>>>>>> to move off CentOS 7. It will receive maintenance updates through
>>>>>>> 2024-06-30.
>>>>>>> But on CentOS 7, I can load a Python 3.6, newer GCC, etc. so it isn't
>>>>>>> that bad. I had to test something on a true 32-bit distribution this week
>>>>>>> and even CentOS 7 (i386) wasn't as painful as I expected to setup.
>>>>>> There will come a time when a change made cannot be easily tested by us on
>>>>>> python2 and that will in effect end our support. We are not there yet.
>>>>> STOP.
>>>> Please do not do this again.
>>>> That discussion took a wrong direction. We discussed deprecating python2 a
>>>>> few times and I know that we will not do it before the big long living
>>>>> distributions drop it. I can live with that and I don't want to re-start this
>>>>> discussion with this patch.
>>>> If Joel feels the need to make this statement he can and he has more than earned
>>>> the right to do so. His work and those he supports is important.
>>> Sorry, I didn't want to offend you, Joel or Gedare.
>>> I had that with discussions before that the original idea (here: giving priority
>>> to python3 over python2 when building gdb) started to be buried by a similar but
>>> slightly different one which has been already discussed multiple times (here:
>>> deprecating python2). I wanted to avoid that.
>>> I should have worded that different. I'm sorry if I have offended you, Joel or
>>> Gedare or anyone else.
>> Thanks and none taken. I am clear on the focus of your posts so it is ok. :)
> It would be fine without the STOP. Totally acceptable to express your
> opinion and request that we not bikeshed your patch, we just want to
> keep the tone of the list in the right direction which we all know can
> be challenging in virtual, international communications. We understand
> the intent here, but we just want to make sure to keep the list
> friendly to all (who may lack some of our context). Thanks!
Yes, again: sorry. "Let's deprecate python2" is a dangerous topic that
has the tendency to start really long discussions. I pannicked a bit
there that it would hide the topic that I had in mind. I used the wrong
tone to express that. I'll try to be more careful in the future.
>>>>>>>> On Thu, Aug 19, 2021 at 3:24 AM Christian MAUDERER
>>>>>>>> <christian.mauderer at embedded-brains.de> wrote:
>>>>>>>>> PS: I had the problem on the 5 branch of RTEMS source builder. I think
>>>>>>>>> we should apply a patch to both: master and the 5 branch.
>>>>>>>>> Am 19.08.21 um 10:34 schrieb Christian Mauderer:
>>>>>>>>>> More and more systems stop shipping python2. So we should start to
>>>>>>>>>> prefer python3 over python2. For building gdb it is not only necessary
>>>>>>>>>> to have a python binary installed, but also the matching python-devel
>>>>>>>>>> packet. On a lot of hosts that will now be more often python3-devel
>>>>>>>>>> and not python2-devel.
>>>>>>>>>> Note: Please see that patch more as an suggestion / base for
>>>>>>>>>> discussion. I'm open to better solutions.
>>>>>>>>>> My problem that triggered this patch was a build of a toolchain on a
>>>>>>>>>> github CI/CD system that has been originally set up by one of our
>>>>>>>>>> users (see [1] for the log). It seems that on the "macos-latest"
>>>>>>>>>> machines a python2 is installed but no python2 headers are found.
>>>>>> I have just built the latest RSB master GDB on a fully updated MacOS (Big Sur):
>>>>>> config: tools/rtems-gdb-10.cfg
>>>>>> package: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1
>>>>>> building: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1
>>>>>> sizes: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1: 629.086MB
>>>>>> (installed:
>>>>>> 19.586MB)
>>>>>> cleaning: arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1
>>>>>> reporting: tools/rtems-gdb-10.cfg ->
>>>>>> arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1.txt
>>>>>> arm-rtems6-gdb-7ab567f-x86_64-apple-darwin20.1.0-1.xml
>>>>>> I support the latest MacOS with Xcode and have a dedicated Mac machine that
>>>>>> tracks the current RSB. It had wedged itself and I have cleared that so it is
>>>>>> now building the latest.
>>>>> So do I understand that correct: This is a "clean" Mac with no additional python
>>>>> installs or similar and it worked? What python versions are available on this
>>>>> this machine?
>>>> It is working for me and I have not looked into it any more.
>>>>> If I did understand you correctly, it seems that github has made some odd
>>>>> choices about their default config for the macos-latest machines. They seem to
>>>>> have python2 but no devel headers.
>>>> You will need to raise that with them.
>>> Yes, of course. I didn't want to raise it as a problem here. It was more a
>>> statement than a question or a complain.
>> Yeap, I understand.
>>>>>>>>>> Homebrew - which could be used earlier on MacOS to install the
>>>>>>>>>> necessary headers - dropped the python at 2 packet.
>>>>>> Homebrew and MacPorts are a personal choice and I am fine with users heading
>>>>>> down this path however it is beyond this project's scope to support those
>>>>>> frameworks. I have posted the reasons in the past and the MacPorts maintainers
>>>>>> are aware of those reasons.
>>>>> No problem. I'm not a Mac user so I don't really have an opinion or experience
>>>>> what is the right way to install the requirements on a MacOS system. I'm really
>>>>> happy that it just works most of the time (a lot of it most likely thanks to
>>>>> you).
>>>> Actually, all I do is politely raise issues with those that do the real work. I
>>>> think Homebrew and Macports are awesome projects but they bring in packages and
>>>> with that issues and when our users have a mix of package versions the level of
>>>> complexity exploded. I have no capacity to cover this.
>>>>>>>>> So it seems that on a
>>>>>>>>>> modern MacOS there is no possibility to get python2 headers.
>>>>>> As I have just built GDB this does not appear to be true. I would prefer we do
>>>>>> not overreach until we all agree there is a problem. If there is an issue I
>>>>>> would raise the problem in Apple'd developer bug system. I have raised a number
>>>>>> of issues over the years and to Apple's credit they have dealt with them all.
>>>>> Maybe I haven't made it enough clear: I had to do some guess work here. I have
>>>>> put it here as a basis for discussion. I'm completely OK if you can tell me that
>>>>> my conclusion has been wrong.
>>>> I think the switch is a good idea. It may break something things but that is
>>>> also OK because we can then fix them well before a release.
>>>>> It seems that it really is just an odd choice of defaults on github then.
>>>> Sorry, again I am not sure.
>>> Found the documentation on github. If someone is interested:
>>> https://github.com/actions/virtual-environments/blob/main/images/macos/macos-10.15-Readme.md
>>> https://github.com/actions/virtual-environments/blob/main/images/macos/macos-11-Readme.md
>>> So all github macOS runners have some Python 2.7 installed.
>> Big Sur still ships Python2.
>> FYI the MacOS build reports have started to appear on the build list.
>>>>>>>>>> If
>>>>>>>>>> python2 is still installed on the machine (for whatever reason), it is
>>>>>>>>>> not possible to successfully use RTEMS source builder to build a gdb.
>>>>>>>>>> If python3 is preferred instead, that should solve the problem.
>>>>>> The change seems sensible.
>>>>> I think even if a clean MacOS doesn't have a problem (like I assumed), I still
>>>>> think it would be a good idea to prefer python3 if it is available. We are not
>>>>> talking about preferring it in our python-scripts but only to build gdb.
>>>> I agree, lets switch.
>>> Thanks.
>>>>> Do I have a "go" to:
>>>>> - create tickets for 5 and 6
>>>>> ("RSB: Prefer python3 to build gdb if it is there" with some explanation in
>>>>> the description)
>> The 6 patch is OK to push when you are ready.
> Agreed for 6.
I will do some tests on 5 like Chris suggested. If something comes up
there, it is nearly sure that it is a problem for 6 too. So I'll wait
for the results of these tests.
>>>>> - push that patch to 5 and 6 and close the tickets with it
>>>> The 5 needs to be check on Windows before we switch. I think it will be fine but
>>>> it is a release hurdle if it does not as it makes a dot release a major piece of
>>>> work.
>>>> Do you need a hand with Windows? If so please ask.
>>> What would you see as the more difficult Windows build environment that should
>>> be tested? We have MSYS2 and Cygwin in our documentation. Do you test both on
>>> releases?
>> I only test MSYS2 and on real hardware with Windows 10. Cygwin is important to
>> Joel and DEOS and so I leave this task to him.
> +1 @Joel
> Also given our relationship with cygwin via newlib, I think it is a
> good platform for us to be supporting to some extent. But as always,
> time is the enemy.
Started to test both (MSYS2 and Cygwin) and I start to suspect that our
manual needs some minor updates. I'm taking notes ...
Best regards
Christian
>>>>>>>>>> Note that at the moment I only tried it on my OpenSUSE-Linux machine.
>>>>>>>>>> For that I made sure that I have python2 and python3 installed but no
>>>>>>>>>> python-devel (which is python2 on OpenSUSE). Earlier I know that I
>>>>>>>>>> needed python-devel to build gdb. With this patch, I can build with
>>>>>>>>>> only python3-devel.
>>>>>>>>>> I'll try to add that patch to the CI too to see whether it works on
>>>>>>>>>> MacOS. But I'm a bit unsure what other problems this patch could
>>>>>>>>>> trigger and therefore I want to start a discussion early.
>>>>>>>>>> Best regards
>>>>>>>>>> Christian
>>>>>>>>>> [1] https://github.com/grisp/grisp2-rtems-toolchain/runs/3362717606
>>>>>> I am looking forward to their hardware being shipped.
>>>>> I think there will be an official update soon. You most likely noted that the
>>>>> CI-run belongs to a pull request that updates the toolchain to work with the
>>>>> first final board that had been on my desk this week.
>>>> Great and no I had not looked. Sorry, deep in libbsd (again and eval_path grr).
>>> Good luck with the libbsd problems.
>> Thanks.
>> Chris
> devel mailing list
> devel at rtems.org
