[PATCH] GcovData.cc: Remove ampersands where not needed
Gedare Bloom
gedare at rtems.org
Mon Aug 23 17:45:11 UTC 2021
ok
On Mon, Aug 23, 2021 at 9:49 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> Removed some ampersands that were left in on accident.
> tester/covoar/GcovData.cc | 6 +++---
> 1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/tester/covoar/GcovData.cc b/tester/covoar/GcovData.cc
> index 44928a9..59412a6 100644
> --- a/tester/covoar/GcovData.cc
> +++ b/tester/covoar/GcovData.cc
> @@ -404,7 +404,7 @@ namespace Gcov {
> // Read the gcov preamble and make sure it is the right length and has the
> // magic number
> - gcovFile.read( (char *) &preamble, sizeof( gcov_preamble ) );
> + gcovFile.read( (char *) preamble, sizeof( gcov_preamble ) );
> if ( gcovFile.gcount() != sizeof( gcov_preamble ) ) {
> std::cerr << "Error while reading file preamble" << std::endl;
> return -1;
> @@ -429,7 +429,7 @@ namespace Gcov {
> char buffer[512];
> char intBuffer[16384];
> - gcovFile.read( (char *) &intBuffer, 8 );
> + gcovFile.read( (char *) intBuffer, 8 );
> if ( gcovFile.gcount() != 8 ) {
> std::cerr << "ERROR: Unable to read Function ID & checksum" << std::endl;
> return false;
> @@ -443,7 +443,7 @@ namespace Gcov {
> function->setFunctionName( buffer, symbolsToAnalyze_m );
> header.length -= readString( buffer, gcovFile );
> function->setFileName( buffer );
> - gcovFile.read( (char*) &intBuffer, 4 * header.length );
> + gcovFile.read( (char*) intBuffer, 4 * header.length );
> if (gcovFile.gcount() != 4 * header.length ) {
> std::cerr << "ERROR: Unable to read Function starting line number"
> << std::endl;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
