[PATCH rtems v1 2/2] bsps/zynqmp: Added I2C support for ZynqMP
Stephen Clark stephen.clark at oarcorp.com
Mon Aug 23 22:24:46 UTC 2021
Added I2C drivers for ZynqMP and updated build system accordingly.
 bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  4 ++
 bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h  | 63 +++++++++++++++++++
 bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h  |  2 +
 bsps/aarch64/xilinx-zynqmp/start/bspstart.c   | 10 +++
 spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |  4 ++
 .../bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml  |  2 +
 .../aarch64/xilinx-zynqmp/objcadencei2c.yml   | 19 ++++++
 .../bsps/aarch64/xilinx-zynqmp/optclki2c0.yml | 19 ++++++
 .../bsps/aarch64/xilinx-zynqmp/optclki2c1.yml | 19 ++++++
 9 files changed, 142 insertions(+)
 create mode 100644 bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
index 83f2e2f4e4..6d49b9ad2a 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
@@ -70,6 +70,10 @@ BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
 void zynqmp_debug_console_flush(void);
+uint32_t zynqmp_clock_i2c0(void);
+uint32_t zynqmp_clock_i2c1(void);
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h b/bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
new file mode 100644
index 0000000000..e09747d414
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
@@ -0,0 +1,63 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2021 On-Line Applications Research (OAR)
+ * are met:
+#ifndef LIBBSP_ARM_XILINX_ZYNQ_I2C_H
+#define LIBBSP_ARM_XILINX_ZYNQ_I2C_H
+#include <dev/i2c/cadence-i2c.h>
+#include <bsp/irq.h>
+#include <bsp.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+static inline int zynqmp_register_i2c_0(void)
+  return i2c_bus_register_cadence(
+    "/dev/i2c-0",
+    0x00FF020000,
+    zynqmp_clock_i2c0(),
+    ZYNQMP_IRQ_I2C_0
+static inline int zynqmp_register_i2c_1(void)
+    "/dev/i2c-1",
+    0x00FF030000,
+    zynqmp_clock_i2c1(),
+    ZYNQMP_IRQ_I2C_1
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_XILINX_ZYNQ_I2C_H */
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h b/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
index b67d7d0f8e..9af41643bd 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
@@ -53,6 +53,8 @@ extern "C" {
 /* Interrupts vectors */
 #define BSP_TIMER_VIRT_PPI 27
 #define BSP_TIMER_PHYS_NS_PPI 30
+#define ZYNQMP_IRQ_I2C_0 49
+#define ZYNQMP_IRQ_I2C_1 50
 #define ZYNQMP_IRQ_UART_0 54
 #define ZYNQMP_IRQ_UART_1 53
 #define ZYNQMP_IRQ_ETHERNET_0 89
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstart.c b/bsps/aarch64/xilinx-zynqmp/start/bspstart.c
index 36194a337d..d75e5a1620 100644
--- a/bsps/aarch64/xilinx-zynqmp/start/bspstart.c
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstart.c
@@ -39,6 +39,16 @@
 #include <bsp/irq-generic.h>
 #include <bsp/linker-symbols.h>
+__attribute__ ((weak)) uint32_t zynqmp_clock_i2c0(void)
+  return ZYNQMP_CLOCK_I2C0;
+__attribute__ ((weak)) uint32_t zynqmp_clock_i2c1(void)
+  return ZYNQMP_CLOCK_I2C1;
 void bsp_start( void )
   bsp_interrupt_initialize();
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
index 03ccdbbc8b..1a356903cd 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
@@ -27,6 +27,10 @@ links:
   uid: optramlen
 - role: build-dependency
   uid: optramori
+- role: build-dependency
+  uid: optclki2c0
+  uid: optclki2c1
   uid: optclkuart
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml
index fa6347b2e4..4727ebddf7 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml
@@ -11,6 +11,8 @@ links:
   uid: grp
   uid: tstzu3eg
+- role : build-dependency
+  uid: objcadencei2c
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml
index 0000000000..fd9d51dfa9
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/include/dev/i2c/cadence-i2c-regs.h
+  - bsps/include/dev/i2c/cadence-i2c.h
+  - bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
+links: []
+source:
+- bsps/shared/dev/i2c/cadence-i2c.c
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
index 0000000000..fd87888ef0
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
@@ -0,0 +1,19 @@
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights: |
+  Copyright (C) 2021 On-Line Applications Research (OAR)
+default: 111111111
+default-by-family: []
+default-by-variant: []
+description: |
+  ZynqMP i2c0 clock frequency in Hz. This is the frequency after the signal
+  has been processed using the values passed to the I2C0_REF_CTRL register.
+enabled-by: true
+format: '{}'
+links: []
+name: ZYNQMP_CLOCK_I2C0
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
index 0000000000..603dd06fb8
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
@@ -0,0 +1,19 @@
+actions:
+- define: null
+build-type: option
+copyrights: |
+default: 111111111
+description: |
+  ZynqMP i2c1 clock frequency in Hz. This is the frequency after the signal
+  has been processed using the values passed to the I2C1_REF_CTRL register.
+enabled-by: true
+format: '{}'
+links: []
+name: ZYNQMP_CLOCK_I2C1
+type: build
2.27.0
